Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-31-2008, 05:12 PM   #41
Koni Kroo
95maxrider's Avatar
Send a message via AIM to 95maxrider
So....if you don't plan on installing these, would you want to mail me the beam axle with them already installed?
__________________
-----5-speed DE-K with 205 whp and 199 wtq SAE corrected-----
-------Shortened Koni Yellows/Eibachs, Cobra/Q45/Hawk/SS-------
--SFC S.2, LTB S.2, RSB, FSTB, TB's (removed!), all ES bushings--
-------------Enkei RPM2/Michelin Pilot Sport A/S Plus-------------
95maxrider is offline   Reply With Quote
Old 08-02-2008, 06:35 PM   #42
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
Damn I know but I have been really lazy lately. I haven't really worked any of my cars in the last 3-4 weeks. I finally got an air compressor so I tossed in my ES motor mounts. Thats about the extent of my wrenching in the past month. My buddy took back his torches which I planned on using to use for the trailing arm bushings. I will get to them sooner than later.
__________________
-Jon
Daily driver: 98 Maxima SE ... 14.9 @ 95
09 Drag car: 94 Sentra E ... 1/8: 8.2 @ 94, 2.1 60' 356whp/322wtq
06 Drag car: 91 Sentra SE-R ... 1/8: 8.6@ 86, 1/4: 13.1 @ 110, 2.2 60' 250whp
JSutter is offline   Reply With Quote
Old 08-03-2008, 02:28 AM   #43
ZHP
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
hmm I am interested in how this turns out as well. Did ES ever release the bushings?
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
4DRSpeed.com - It's coming!
4DRSpeed is offline   Reply With Quote
Old 08-03-2008, 02:12 PM   #44
JSutter's Avatar
not for the a32, es made them for the a33
__________________
-Jon
Old 07-10-2009, 06:55 PM   #45
Send a message via AIM to sergofast
did you ever put these on? I know that on my sentra, i actually removed the superpro ones i had installed and replaced with stock because of the bind it put on that suspension.
im curious to find out how this works on the maxima.
also where in the heck did you find a superpro dealer!!! i cant seem to find one anywhere on google :/
sergofast is offline   Reply With Quote
Old 07-11-2009, 09:31 AM   #46
Thinks he owns a sports car
What bind? These reduce the smaller OEM rubber bushing's slop and alignment changes under cornering and even vertical suspension movement. Side to side play should all come from the lateral link, not where the ScottR bolts to the frame. I can't prove it yet but I'd think this would help a saavy driver better "feel" snap oversteer beforehand.
Try Tein channels now for SuperPro products. Chuck/Octotat is out of the loop.
BEJAY1 is offline   Reply With Quote
Old 07-11-2009, 10:06 AM   #47
The bind I was talking about was on the b13 sentra. with the front poly control arm bushings (essentially the same thing as what is mentioned in this thread), and all of the rest of the independent rear suspension control arm bushings (there are 8 total, 4 per side), the suspension binds when you compress it and will not allow the full range of motion. There is so much tension, it acts as a shock itself....providing for an unbearable and noisy ride. On that car it is best to leave the front control arm bushings stock and change the rest of them (unless you go all out and install/fab custom heim joint control arms)
But that is a sentra....I was curious how this worked on the maxima because of the different rear suspension setup with the beam that is on these cars.
Old 07-11-2009, 10:09 PM   #48
JSutter's Avatar
I hate to say it, but no I never installed these. Ive kicked myself many of times as its been so long. I haven't worked on my max for almost a year now. Im still running winter rubber!
Funny I have full poly ES setup on the front of my A32 and full ES setup on the rear of my B13. No noises on either.
__________________
-Jon
Old 07-11-2009, 11:29 PM   #49
swap out the front control arm (the one that runs from front to rear and has the large 2.5" bushing) for a stock one and drive it around....you will immediately notice the difference.
if you still havent installed these on your max...wanna sell em?
Old 07-26-2009, 09:53 AM   #50
JSutter's Avatar
I finally installed them. Installation was done with beam on the car. I unbolted the bottom shock bolt to let the trailing arms hang better. I had a hole saw that fit perfectly around the old bushings. After drilling them out I burned and scraped the rest of the rubber out. Much easier than when I test fit them using a torch to burn them out completely. It was still awkward working with the beam installed.
No review now, probably never will be able to give an accurate review on handling either. Ive had so many suspensions and I cant remember the last time I actually flogged it around turns with a similar setup to what I have now sans the bushings. I guess I should have done so before I installed them. I do know Id rather have the bushings over a RSB. The RSB was not a comfortable mod. For daily driving I cant tell these bushings are in.
Now I just need to install the WSP sub frame connectors Ive had for ever.
__________________
-Jon
Old 07-26-2009, 02:14 PM   #51
Im in for a review....mine are already in the mail. You know the price on these skyrocketed to 87.00 for a set! Superpro changed/upped their prices on eveything.
Old 07-26-2009, 06:33 PM   #52
Koni Kroo
95maxrider's Avatar
I'm just glad you finally installed them How long did the entire install take? Did you notice any difference in ride quality? Post up a handling review if you can at a later date....
__________________
Old 07-26-2009, 08:18 PM   #53
JSutter's Avatar
I didnt keep track of time, 3 hrs maybe. I must have fumbled 1/2 the time on getting out the 1st old bushing and another 1/4 on installing the it. The other side was cake. If I had to redo the whole thing it would take about an hour.
__________________
-Jon
Old 07-26-2009, 08:34 PM   #54
Send a message via AIM to 98SEBlackMax
I'll put mine in after two years.
I track this car heavily so I should get a good idea what they improve on. I'm not planning on another track event this year, but I can test them out on my hometown "track".
oh and sergofast Haven't seen you around since the beam bending party in '06.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
2007 KH3 Frontier NISMO 4x4 - ??? WHP / ??? WTQ
(6 spd - daily driver)
98SEBlackMax is offline   Reply With Quote
Old 07-26-2009, 09:08 PM   #55
I know...i disappeared off the forum for awhile. I got the itch to do stuff to the max again... how have you been?
Old 07-26-2009, 09:21 PM   #56
Koni Kroo
95maxrider's Avatar
Oh god, please don't get me thinking about beam bending.....if only there was a place near me that could do it....what type of machine do people use?
Old 07-26-2009, 09:27 PM   #57
Quote:
Oh I see. The max has been good, full on corner balanced coilovers and R-compound tires make for a fun track car. The beam bending has helped a bit with combating understeer without the binding and poor ride quality of a RSB. I forget how it's like until I drive a non treated 4th gen. Granted the car still has a bit of understeer and always will.
Old 07-26-2009, 09:28 PM   #58
Quote:
There was a guy named Steve that does all sorts of suspension stuff (shortened koni struts, beam bending ect) on the sr20forum. He used to live here in VA but moved out west somewhere. We got about 10 members together (from the org and the sr20forum) and he flew back and did all our cars back to back. His screen name is 98sr20ve on sr20forum.com
You cant just bend it....you have to have a special jig and know what your doing or you will ruin your beam and have to replace it.
If you can get it done...do it....it makes the max come alive!
Old 07-26-2009, 09:28 PM   #59
Search the Sentra forums and see if they still do the beam bending parties. I drove all the way to Virginia beach to get mine done. You have to make the effort.
Old 07-27-2009, 11:53 AM   #60
Koni Kroo
95maxrider's Avatar
So how many Maximas have their beam bent? I've never seen a real review of it being done on our cars....
Old 07-29-2009, 04:15 AM   #61
Thats because the majority of the users here; 1. have no idea what it is, 2. dont care because they dont really drive that spirited other than in a straight line, 3. this is a mod that is only applicable to two different nissan cars - the a32 and the b14 (that I know of) 4. and if they do want it done there are only two people in the country (I know of) that can do it correctly.
Take a look over on sr20forum.com there is alot of information on it in the chassis &suspension and b14 section.
Old 07-29-2009, 11:35 PM   #62
I finally got around to trying to install them tonight. I bought a 2" hole saw and cut the bushings out. Burned off all the left over rubber and I cleaned up all the metal until it was shiny, but the bushings will not pop in. I'm wondering if I missed something.
Anyways I put them in the freezer and will try again tomorrow when I have some time.
__________________
- Joe
Old 07-30-2009, 07:40 PM   #63
JSutter's Avatar
They were a tight fit. I greased the heck out of them and used a screw driver to "shoe horn" them in.
__________________
-Jon
Old 07-30-2009, 07:41 PM   #64
JSutter's Avatar
dont forget the 99-02 G20
__________________
-Jon
Old 07-30-2009, 11:41 PM   #65
Ok I got them in tonight. I used some 60 grit sandpaper to clean up the metal sleeves of any residual old bushing and then greased them up. The new bushings popped in with the help of the screwdriver and I was able to bolt the rear suspension back together. I will set the final TQ on the trailing arms when the car is back on the ground. I'm waiting for some other parts to come in and finish the work on my car. Sometime next week it should be back on the road and I will post back my results.
Even better in September I may go back to the same road course I just drove recently. The only difference in the suspension will be these bushings, so it should be a good back to back test.
Old 08-07-2009, 07:45 AM   #66
I have the ES bushing on my 5 the gen and all I can say is this was an improvement over the stock marshmallow bushing.
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
doublea is offline   Reply With Quote
Old 08-22-2009, 01:16 AM   #67
Got the car on the road last weekend. These bushings feel a little bit better on turns and there isn't much change in the ride quality. I would say it's somewhat like having an RSB without the drawbacks. I was worried it would be to harsh but im happy with the results. However I still need to reduce the spring rate in the rear to make the rear suspension more compliant.
Old 08-22-2009, 09:07 AM   #68
JSutter's Avatar
RSBs are for suckers!
__________________
-Jon
Old 08-25-2009, 12:30 PM   #69
Koni Kroo
95maxrider's Avatar
How long ago did you buy them? It looks like the guy on the Sentra boards no longer sells them, and can only be bought through Tein. I checked their website and # SPF1942K lists for $87......
Old 09-25-2009, 12:43 PM   #70
I though you would have said " RSB's are for Sutter. Lol
__________________
2004 BMW X5 4.4i
Old 09-25-2009, 07:50 PM   #71
Went back to NJMP the other weekend with the bushings. Car felt like it had less understeer and almost neutral on corners that were giving me definite understeer with the stock bushings. However I had to replace some suspension parts up front and re-did the alignment. I wanted more front grip so camber was changed from -1.4 to -2.1 so that would also account for less understeer.
All in all it provides some improvement and I am glad these things are no longer sitting around unused in my garage.
Old 09-26-2009, 04:15 PM   #72
Koni Kroo
95maxrider's Avatar
I forget, is your beam bent? I'm getting my beam bent soon, and have ordered these bushings, and I'm wondering if I will need my RSB when both things are done. Thoughts?
Old 09-26-2009, 04:51 PM   #73
Put the bushings in first also check to make sure all rear suspension parts are in good condition. Then remove the RSB cause you can't have an RSB when the beam gets bent. See how the beam bending feels afterwards then you can decide on the RSB. Mine has been out since Nov '06 and I'm not putting it back on.
Old 11-05-2009, 09:10 AM   #74
I LOVE these things! completly tightened up the rear end....PIA to install (especially with a hangover) and wasnt easy finding a suplyier but completely worth the effort!
Old 11-05-2009, 11:18 AM   #75
Koni Kroo
95maxrider's Avatar
I'm gonna be installing mine when I get the time...any tips to make the install smoother?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
