Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-25-2006, 12:58 PM   #1
2 Qs- loosening PS belt, and removing crank pulley
Happy holidays everyone! Nothing like Christmas to get some work done.
So, I'm installing the UDP that's been in my garage for a year and changing the passenger side axle- and I'll tell you what, it's a heck of a lot easier to get at the power steering bolts while the axle's out
Q1- I've loosened the lock bolt and the adjustment bolt on the PS pump to the point I can loosen by hand, and loosened the rotator bolt on the driver's side of the pump out about a half inch (though it's nowhere close to finger-loose). The pulley won't budge. By what mechanism will the pump/pulley move? Does it rotate (I'm sure they don't call it the rotator bolt for nothing)- and which direction? Should I try and force it, or keep loosening the rotator bolt? The AC/alternator belt is already off- thanks to all the how-tos and great posts out there.
Q2- Since the y pipe and driver's side axle weekends of the past, I picked myself up a big-boy electric torque wrench (Ridgid R6300). Regardless of whether the torque capabilities of the wrench are correct (400+ ft-lbs), I know what it can do- it spins off axle hub nuts in about 3 seconds that I've personally killed myself on loosening and tightening with 3 feet of breaker bar. But, the crank pulley bolt won't budge, even after 30 seconds of going at it. Soaked it in PB Blaster overnight and same thing. Any ideas on this one?
Thanks!
texasmax is offline   Reply With Quote
Old 12-26-2006, 12:22 AM   #2
as far as Q1 one goes, there is another bolt on the back/driver side of the PS pump that your suppose to loosen to allow the whole pump to rotate, but i've done it with out loosing that back bolt.
i know its laid out in the MA section of the FSM
you also have to lock the flywheel when trying to take off the bolt holding the crank pulley, so the crank shaft can't spin. just making sure you covered that basis.
if your 5spd have an assistant put the car into 5th gear and hold brake pedal firmly while you loosen the bolt.
if your auto it should tell you how to take it off in the FSM or in a haynes manual
gen4maxima536 is offline   Reply With Quote
Old 12-26-2006, 10:29 AM   #3
Maintenance Monster
Q1: I agree - you need to find the pivot bolt and loosen it. Definitely much more do-able with the PS axle outof the way.
See this pic of the bolt:
Q2: I've never done the crank pulley, but consider these general ideas: You might need to apply some heat to the nut in case it's loc-tited. Be careful though - I would search and read the FSM to be sure that's safe to do or you might fry an oil seal or bearing nearby. I would also confirm if these nuts are loc-tited (see the FSM or Haynes). Usually though a propane torch on the nut only will not get the surrounding parts hot if you only do it for a few minutes, and that's enough to kill loc-tite.
Dave
dgeesaman is offline   Reply With Quote
Old 12-26-2006, 02:54 PM   #4
The Dirty Pearl
pmohr's Avatar
For the crank pulley bolt, you can put a breaker bar on it and bump the engine over once or twice, that'll break it loose.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 12-26-2006, 05:04 PM   #5
Thanks for the replies everyone! Was interested about the heat idea- was about to go that route, but ended up soeaking it in PB for another few hours and then the impact took it right off no problem. Have read all the threads about locking the flywheel and wrenching it and the blip method as well, just felt like I wanted to get the investmnet out of the impact
And as far as the PS pump, I just wasn't loosening the adjustment bolt enough- had already loosened the pivot bolt.
Problems solved- thanks!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
