Radiator Recommendations
Old 12-12-2006, 06:53 AM
Sounbwoy's Avatar
May I have a few recommendations on radiators and where to purchase them? Would also like recommendations on hoses. Anything to watch for when installing?
I noticed a a couple wisps of vapor from the front of the car this morning at a light, so when I stopped to get gas I checked it. At the top of the radiator where the plastic meets the metal seam, I saw a very SMALL amount of liquid. The hose was fine and there were no obvious cracks-so it's probably a small hairline fracture right at the seam. No overheating or any drama.
Considering this is the original radiator (263,xxx miles), I'd say I got my money's worth.
Thanks for your help.
Sounbwoy is offline
Old 12-12-2006, 07:22 AM
SHIFT_up
99se5speed's Avatar
Koyo i believe makes quality OE replacements. Check the GD section because i believe there's a deal on them.
99se5speed is offline
Old 12-12-2006, 07:27 AM
Maxima Owner
MaximaSE96's Avatar
Calsonic yo...but yes Koyo would be a good choice...hoses...get a one them from the dealer...autozones will be cheaper an most likely the same rubber..
MaximaSE96 is offline
Old 12-22-2006, 08:42 AM
Sounbwoy's Avatar
OK. My Koyo radiator is on the way....Are there any details I need to know when installing it?
Do those rubber washers just pop out of the tabs on the top to remove the radiator or is there more involved?
Sounbwoy is offline
Old 12-22-2006, 05:35 PM
Sounbwoy's Avatar
First time doing this...
Bump.....
Sounbwoy is offline
Old 12-22-2006, 09:26 PM
Difficult is NOT impossible!
Jellyfishian's Avatar
Its pretty simple, I think there is a write up but I'm not sure... I did flush the system and replaced with Honda Blue coolant. Thats no fair you got 2xx,xxx out of your radiator and I got like 7x,xxx..
Jellyfishian is offline
Old 12-22-2006, 11:21 PM
Sounbwoy's Avatar
MAJOR knocking on wood...other than the transmission, I have had no mechanical issues. Even some of the bulbs are original!
Sounbwoy is offline
Old 12-23-2006, 01:22 PM
Sounbwoy's Avatar
Radiator Update
The radiator came today. Purchased thru the GD for Koyo radiators offered by Jeff at IRP. Good people to work with by the way.
After looking at things, it didn't look very difficult so I went ahead and switched it out. Very easy job, so I'm back in business. Don't forget to transfer the rubber "bump stops" from the old rad to the new one!. Total time with refilling and bleeding the system was MAYBE two hours, and I took my time about it. I'll have some pictures up later.
Sounbwoy is offline
Old 12-24-2006, 01:47 PM
Sounbwoy's Avatar
I have some pictures of the new and old radiator (in and out of the car) up. Feel free to look if interested.
http://target.new.photos.yahoo.com/s...60762373221081
Sounbwoy is offline
Old 12-24-2006, 02:48 PM
Sweet! Mine started to crack like that too I went through JB weld like nobodys business trying to fix it... I just broke down and bought a new one
hcarter1112
42
07-18-2022 03:35 PM
Miket2006
03-01-2021 03:55 AM
Unclejunebug
04-02-2016 05:42 AM
MaxLvr21
10-17-2015 12:11 PM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: Radiator Recommendations
