Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-29-2006, 07:39 PM   #1
nick's Avatar
Send a message via AIM to nick
Finally fixed stalling issue by grounding MAF sensor
What a relief, after weeks of dealing with stalling max, she purrs like a kitten again. The fix took 10 min, by simply running extra grounding wire from MAF to the chassis.
All stalling when coming to stop , shaking at idle, stalling in reverse and running rich is now gone !!!
If you experience stalling issues (with no CEL) and have tried all the basic troubleshooting like: clean TB, IACV, ECTS, plugs, fliters, coils etc and nothing seemed to help, you need to check your MAF sensor ground.
Simply back probe the black wire on MAF connector with positive lead of the voltmeter and negative lead pressed to one of the ground connections on the engine block.
The voltage at idle should be less than 9mv (0.009v), if it is above the value the sensor should be regrounded.
once the sensor is regrounded , the voltage should drop significantly.
Mine was around 0.277 at idle and 0.187 with ignition on ( engine not running)
after the fix the vlotage dropped to 0.005 at idle and 0.002 with ignition ON.
I'm glad that i was able to fix without having to take the car the mechanic/dealer.
I would still like to know what has caused my MAF sensor ground go out of specs, The sensor itself has passed the output voltage test listed in Haynes manual.
Also the manual says that the MAF can develop voltage signal problems that can't be seen on the voltmeter, the PCM can see such signal faults and driveability problems will result.
in cliff notes, if you Max stalls when comig to stop, check the ground to MAF it should be less than 0.009mv
Nick.
__________________
Lower control arm & sway bar bushings replacement WRITE UP
http://www.cardomain.com/ride/348507/15
Inner tie rod WRITE UP
http://www.cardomain.com/ride/348507/13
nick is offline   Reply With Quote
Old 11-29-2006, 09:46 PM   #2
IM OUT
95turbo gxe's Avatar
Send a message via AIM to 95turbo gxe Send a message via Yahoo to 95turbo gxe
great ill check it out tommorow
__________________
Currnent MODS:_______
TURBO 6SPEED DEK_________
Hx35w turbo______________Z32 BBK with 04 Rotors
Emanage Ulitimate______________D2 coilovers
E01 boost controller__________
Jwt flywheel_________________18" Anv z wheels
under drive pulley____________Duel fx35 Projectors
95turbo gxe is offline   Reply With Quote
Old 11-29-2006, 09:59 PM   #3
Boosted like Snipes tax refund
Send a message via AIM to RichMax
BTW.. I saw something similar in the Haynes manual. How do you "back-probe" a connector? In this case, do you strip the insulation on the MAF ground wire, or what?
I have a multimeter and am wondering based on your instructions what the positive probe should be contacting.
RichMax is offline   Reply With Quote
Old 11-30-2006, 12:28 AM   #4
nick's Avatar
to backprobe the connector you simply push the needle end of your positive lead through the weatherpack (jelly like substance inside the connector)
and wiggle the needle probe until you make contact with pin inside the connector.
there is no need to cut, expose or strip insulation in order to obtain readings for given circuit.
caution - repe***ive backprobing could damage the weahterpack and allow moisture to enter the connector, so be gentle with it.
the negative lead should be touching good engine ground ( there are two 10 mm screws in front of the engine, next to wire harness and front injectors)
or just use battery neg terminal
Old 11-30-2006, 12:27 PM   #5
Hi,
I need more info on this. Sorry about this, but i'm french, so I dont understand all of yours explanations.
To be sure: you have a connector on the MAF, the plug with 3 wires? So to ground this you have to split your balck wire and connect one on the car or the negative terminal?
oVeRdOsE is offline   Reply With Quote
Old 11-30-2006, 01:42 PM   #6
nick's Avatar
yes, just strip some plastic insulation from the BLACK wire on the MAF sensor connector, than solder new wire to it and attach it to any chassis ground
I've used the 10mm bolt that secures drop resistor to the shock tower
or just attach it to neg battery terminal
make sure to wrap your connections with electrical tape
Old 12-27-2006, 04:34 AM   #7
The original VQ...
maxspeed96CT's Avatar
Send a message via AIM to maxspeed96CT
Im gona try this tonight , but my car doesnt idle funny like yours, it just starts and then shuts off , i cant even save it if i give it full throttle or anything
I guess its worth a try ause it wont cost me anything....
__________________
-05 Cadilac CTSV w/ kooks 1 7/8 headers, comp 220-224 cam, stage 3+ spec, DMH cutout +other minor stuff
LSx motor > all others
-94 toyota pickup 4cyl 4x4 daily work truck
-97 camaro z28 [ sold]
-06 -g35 sedan 6MT [sold]
-02 merlot red 6mt full bolt ons [sold]
-97 - maxima 5MT [ hit bambi at 75mph]
maxspeed96CT is offline   Reply With Quote
Old 01-03-2007, 12:36 AM   #8
Send a message via AIM to shadyonedeath
nvm :edit:
shadyonedeath is offline   Reply With Quote
Old 01-03-2007, 05:43 AM   #9
I just had the codes for MAP and MAF and it ended up being a short in the wire. Had to take it to the dealer too that sucked
jacobmh27 is offline   Reply With Quote
Old 01-03-2007, 01:01 PM   #10
might have to give this a try, mine doesnt stall, just has a rough spot when abruptly letting off throttle and when lugging the engine at low speeds.
mbandit is offline   Reply With Quote
Old 01-03-2007, 02:31 PM   #11
tried it today after replacing my ETCS didnt work, still stalled...
Old 01-03-2007, 02:47 PM   #12
mine stalls sometimes as well as sometime when i let off the gas it stutters. has anyone had this problem?
cbjja428 is offline   Reply With Quote
Old 12-04-2008, 08:03 PM   #13
hmm I think I will try this tomorrow. when I tap on the mass MAF it stalls...tried using MAF cleaner and seems to be the same.
4thGMax is offline   Reply With Quote
Old 12-05-2008, 01:22 PM   #14
For those with stalling issues even if you give it gas, I just had an issue where my car would start but immediately die. Finally I was able to get it into gear and begin driving and it would stay running but idle very rough around 400 rpm. Turns out the IACV was bad and now the car runs much better.
NCSUpilot is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
