left headlight doesn't work and can't figure it out
Alright, well my drivers side headlight went out last night randomly. It's not the bulbs, and it's not the Left or right headlight fuse. All my wiring seems fine and for the life of me I can't figure out why it won't work. I'm resetting my computer right now but I doubt that will do anything. my fogs and parking lights and turn signals all still work. Now my brights indicator in the gauges is on all the time when my headlights are turned on. Anyone have any clue on why this would be happening?
Originally Posted by JSMax
I'm betting it's the headlight switch that has failed...
if it is, you have to remove the steering wheel and airbag to change it.
good luck.
good luck.
OT: if just the switch has failed, i dont think you have to take off the steering wheel and airbag, i've replaced on you just have to take off the stuff around the steering column and the piece of dash below the steering column which is all pretty easy
well I think I figured it out. I checked the plug that connects to the bulbs and it looks like it's the connector. I'll post up a pic tomorrow to show what I'm talking about. Now I have to get a new one somehow and install it.
Originally Posted by GraveDigger611
I actually had the same thing happen twice... I just switched my bulbs around and it worked for me ... weird ... good luck
Originally Posted by KsuMax
ya it's weird that it happened out of no where. I've switched around 3 different bulbs and nothing works.
Originally Posted by rufrufryder
Is it a regular bulb or cool blue or other white bulbs? If something other than the regular bulb, it may be burning out the socket each time.
jerrod99_se-l
08-27-2015 08:27 PM
