3.5 swap cell codes
Old 11-12-2015, 04:35 PM
P0tter7's Avatar
3.5 swap cell codes
hey guys I did a 3.5 swap last feb. I did the timing case swap with the cam adapters and all that. few things I don't like is it runs really rich when im middle of the throttle but if I turn the fuel pressure down it gets lean at idle. I need more time to play with it. other then that it is fast. I pull away on my buddys 3.0 all day.
anyway. I got a few sell codes I want get rid of. to start off with I have a 97 computer. I was thinking about getting a 95 ecu(5 speed) so I can get rid of some codes that I eliminated. but I been on the edge to boost so in that case ima need nistune so I can tune the car.
codes that I have are
p0446
emission system vent control circuit. (this is new and the only one that came up diff from when I cleared it before)
ones I need help with \/
p1400
egr solenoid( I deleted it from the system but I want to know what throws this code. is it the egr temp sensor that's in the tub< cause I welded a nut that and threaded that into the port on the rear manifold so it sees the heat. but I believe it only sees the heat when the valve is open so the computer see its cold then when valve is open it sees the heat and then closes gets cold again. well where I have it it sees heat all the time. so is that the issue.)
p1105
manifold absolute pressure/bar switch circuit
p0105
manifold pressure barometric circuit.
now are these circuit codes coming up because there is a break in the lines(haven't tested yet its been raining) or is that what just comes up when it throws a code it says circuit
this would help me out a lot. its gonna get me closer to boosting the car. I don't want the cel code on and make sure everything is good. thanks guys
P0tter7 is offline
Old 11-12-2015, 06:29 PM
JvG
JvG's Avatar
Check the Advanced Performace section of the main forum.
JvG is offline
Old 11-23-2015, 02:45 PM
P0tter7's Avatar
That's all the reponse ?
P0tter7 is offline
Old 11-23-2015, 10:17 PM
JvG
JvG's Avatar
This section of the forum generally is not about engine internal performance enhancements.
This section is generally used by folks who just want to keep the car on the road.
The Advanced Performance forum is about the kind of things you are into.
People there can be more helpful for your purpose.
This section can be very helpful for the rest of your car.
JvG is offline
Steven Orozco
09-12-2015 10:41 PM
tardrex
09-11-2015 07:35 PM
lux97Max
09-11-2015 01:12 PM
Quick Reply: 3.5 swap cell codes
