A year later.
Old 10-22-2006, 03:04 PM
Wild for Width
Fr33way™'s Avatar
A year later.
Can you spot the changes in the bay?
Last Summer
This Fall
Fr33way™ is offline
Old 10-22-2006, 03:09 PM
99grnmaxgxe's Avatar
Nice polishing.
99grnmaxgxe is offline
Wild for Width
Fr33way™'s Avatar
Another angle not seen from the dead-on shot. (horn relocated, washer fluid delete)
Fr33way™ is offline
Old 10-22-2006, 05:15 PM
I support for what?
Mxrider52's Avatar
Struts and not coilovers...FTW
Mxrider52 is offline
Old 10-22-2006, 05:21 PM
Needs non-Maxima Friends
nismo2020's Avatar
added some kind of breather.
nismo2020 is offline
Old 10-22-2006, 05:23 PM
Wild for Width
Fr33way™'s Avatar
It has a breather in both pics.
Fr33way™ is offline
Old 10-22-2006, 05:24 PM
OnEBadAsSi30's Avatar
Your oil cap is turned 15 degrees? And i'm pretty sure your master cylinder cap is different color?
OnEBadAsSi30 is offline
Old 10-22-2006, 05:25 PM
MDeezy's Avatar
added longer breather
intake filter is angled
brake cap is different colors
Purple by the top of the strut tower, now its different ( )
something blocking the front of the battery in the other pic
a little more power steering fluid this fall.
Coolant resevoir about the same.
MDeezy is offline
Old 10-22-2006, 05:27 PM
I Broke OT
86maxima96's Avatar
ok, enlighten me. that filter that you have coming off of the right of the valve cover, what's that for? some cars have that being sent back into the intake, while others have a filter like you do. is it exhaust gasses that are coming out?
86maxima96 is offline
Old 10-22-2006, 05:28 PM
Custom User Title
Nismo3112's Avatar
Spark plug cover is gone.
Are those 5th gen coil packs?
Nismo3112 is offline
Old 10-22-2006, 05:30 PM
B!tch We Got a Problem
Gismo-T's Avatar
painted radiator brackets, hood alarm switch bracket & the hood latch locking assembly black.
Gismo-T is offline
Old 10-22-2006, 05:36 PM
I'm nutty for Nissans
JSutter's Avatar
Having the breather like that makes the car idle pretty lean, not that it matters. Basically the other end of the PCV system thats still connected to the IM sucks unmetered air throught that breather.
Nice MAP sensor relocation.
Oh and the coil cover is missing!
you painted the oil dip stick
you zip tied the grille on
Hey loose the green tape on the wires. That was my 1st mod!
I thought you installed the other IM with out the 98 90* vac line just after the TB?
JSutter is offline
Old 10-22-2006, 07:14 PM
nismo2020's Avatar
i had a breather once but it made my car idle like crap,, so i just re-routed it the orginal way.
Old 10-22-2006, 07:16 PM
Wild for Width
Fr33way™'s Avatar
Prize goes to JSutter.
It was a timing thing with the other intake mani. I had just finished it the day before I hit the track. Rather than do the install I took weight off the car and did a few other prep items.
-Stillen strut bar is refinished, notice the ends (but will be poilished soon)
-boost sensor mount
-black caps (coolant,brake)
-battery cover delete
-polished valve cover
-polished timing chain cover
-D2's swapped for spring/strut setup (lack of camber plates in 2nd pic)
-sparkplug cover is off (probably for good)
-black radiator brackets
-washer fluid reservoir and all lines removed
-horn relocated (easier access to tensioner,cleaner look)
-hood latch assembly is painted black
-VC breather relocated to fit larger Mr.Gasket breather
-shorter coolant overflow hose
As usual Sutter you are the voice of reason and now those little harmless tags on all the lines will bug the hell out of me. I have a breather because of my mid-pipe BTW.
Fr33way™ is offline
Old 10-22-2006, 07:26 PM
ethnic6's Avatar
nice, feel any gains from it?
ethnic6 is offline
Old 10-22-2006, 07:30 PM
matts95max's Avatar
why did you ditch the coilovers for struts? Looks good by the way!
matts95max is offline
Old 10-22-2006, 07:38 PM
Wild for Width
Fr33way™'s Avatar
If you mean the breather, it is only there because my mid-pipe has no place for the VC tube. If you mean the mid-pipe, probably nothing measurable. I feel as though it is a more direct path but opinions will differe.
It DOES snarl like hell. A friend has the exact same setup minus the mid-pipe and breather and it doesn't have the cammy VQ35 sound mine does up top.
Down low it makes for a little bit of a motor boat sound, hard to describe.
Fr33way™ is offline
Old 10-22-2006, 07:41 PM
Wild for Width
Fr33way™'s Avatar
For noise/maintenance issues. I will be switching back by next summer, I am leaning toward Tein basics.
For you KEEN observers my D2 decal is still in the bay. I loved those things.
Fr33way™ is offline
Old 10-23-2006, 05:48 AM
R34
nexgenmax's Avatar
I had experience with Ksport, I would definetly swap to Tein basic in the future.
nexgenmax is offline
Old 10-23-2006, 09:20 AM
Wild for Width
Fr33way™'s Avatar
D2 and KSport are manufactured by the same parent company so I hadn't really considered them. If I am able to have seperate setups I would possible think about going back to D2 but I would like to have the higher linear spring rate year round.
Fr33way™ is offline
Old 10-23-2006, 09:59 AM
tdbak's Avatar
Where did you get the strut support bar?
tdbak is offline
Old 10-23-2006, 10:07 AM
JSutter's Avatar
The colors are so far off between pix its hard to tell the painted parts. I was eyeing the pieces on the rad support, but they still look like that corroded grey/greenish/brown.
Having no weasle pissers sucks in the winter.
JSutter is offline
Old 10-23-2006, 01:43 PM
Wild for Width
Fr33way™'s Avatar
Yeah, the 2nd shot does have a gold tint to it thanks to Mr. Sun.
I envy your black coolant reservoir but I am such a baby about keeping an eye on my fluids...
Fr33way™ is offline
Old 10-23-2006, 01:45 PM
Wild for Width
Fr33way™'s Avatar
The front strut tower bar is from Stillen.
Fr33way™ is offline
Old 10-23-2006, 04:46 PM
JSutter's Avatar
1st time i did the overflow I kept a small window unpainted, but its just as wasy to look inside so I painted over it. You could always add a clear tube gauge thingy on the outside like the them sik "JDM" ones lol.
JSutter is offline
Old 10-23-2006, 04:51 PM
Wild for Width
Fr33way™'s Avatar
I may do something with it in the future. If it pops up in a thread ("show off your engine bay summer '07") you can tear me to shreads for copying you.
JSutter JDM hyper-black coolant tanks $59.99.
You really should have sold some of those amber corners you made. Could have rode the JDM wave all the way to the bank.
Fr33way™ is offline
Old 10-23-2006, 04:52 PM
Nissan 6's Avatar
Looks good, but you need to do some jdm poses next to the bay.
Nissan 6 is offline
Old 10-24-2006, 04:21 AM
JSutter's Avatar
Its your car, it will always be different. They just *look* similar, paint all you want.
I cant afford $60, can you lower you price? My mom said she would give me only $45, can we work out a trade.
I still have the corners, but its not that hard to do. Some kid on sr20 forum is selling the paint. Hes getting like 2-3 times retail price for a can of it. What a rip, that is unless you cant find it locally I guess.
JDM wave
JSutter is offline
Old 10-24-2006, 10:23 AM
Wild for Width
Fr33way™'s Avatar
<<<<<<<< Can't wait until the GayDM wave is over.
Fr33way™ is offline
Old 10-24-2006, 10:25 AM
Supermax95's Avatar
After you put on the breather did you notice your car louder towards redline at wot?
Supermax95 is offline
Old 10-24-2006, 10:33 AM
Wild for Width
Fr33way™'s Avatar
I'll take page two please.
Fr33way™ is offline
Old 10-24-2006, 10:34 AM
Wild for Width
Fr33way™'s Avatar
No, the breather on the crankcase has nothing to do with sound.
My flipped box and mid-pipe do make a very cammy G/Z sound through the midrange but in the top end (past 5k) it snarls.
Fr33way™ is offline
Old 10-24-2006, 10:46 AM
Supermax95's Avatar
I dunno, i had ram air intake's on both of my 4th gens and when i put on the breather at about 6000 rpm it seemed louder...
Old 10-24-2006, 10:48 AM
Wild for Width
Fr33way™'s Avatar
Ram air intake? Elaborate.
I suppose it is possible that more cam/valve noise is heard out of the opening than if it went through a rubber hose?
Fr33way™ is offline
Old 10-24-2006, 10:50 AM
Supermax95's Avatar
I mean short-ram, sorry since i sold the old maxipad i havent beenon the boards much.
and yes when it runs back into the intake it deadens the sound a bit....i bet if you took off the breather and fabricated a place in your midpipe for a hose you'd hear a big difference towards redline....
Old 10-24-2006, 05:05 PM
Wild for Width
Fr33way™'s Avatar
Perhaps, I like the idea of the vapors staying out of the intake path on low/no vaccum situations though.
Fr33way™ is offline
AcuraLegend
10-17-2016 08:47 PM
220k+ A32
09-23-2015 03:38 PM
AcuraLegend
09-22-2015 04:22 PM
JoshG
51
09-21-2015 10:41 PM
markevans999
09-10-2015 04:29 PM
Quick Reply: A year later.
