Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-24-2006, 08:30 AM   #1
Push Button Start
I know that there was a long thread on this in the past. There was a write up of how to wire up a push button start. My ignition switch is fed up that it takes me 5mins just to try to find the spot to start the car. I want to juse wire a push button start where you have to put key on "ON" then push the button. I have searched for the last 2 days an didn't come up with anything. Anyone with any information please chip in!
Biggs_02 is offline   Reply With Quote
Old 09-24-2006, 09:57 AM   #2
Send a message via AIM to jxkim
make it that much easier for someone to steal your car?
__________________
jxkim - 1996 KH3 Maxima -
[CarDomain Link]
[Hear the SP2]
jxkim is offline   Reply With Quote
Old 09-24-2006, 09:58 AM   #3
hmm yeah im pretty sure they can steal my car without the key...
Old 09-24-2006, 10:33 AM   #4
JFP in PA
Quote:
Why not replace the switch? Putting a push button in requires butchering the dash, adding a relay, etc............that will do a lot for any resale value....
Old 09-24-2006, 10:35 AM   #5
yeah good luck selling a car with a 3.5 swap. I rather do the push button switch even with the hassle. adds to the "wow" factor lol along with the 3.5
Old 09-24-2006, 10:35 AM   #6
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
This is all off memory......
You need 2 relays, 1 momentary switch, 12 gauge wire, 18 gauge wire, and some crimp on terminals. Get the wiring diagram for your car, find the 2 starter wires, connect each to relay pin 87 using separate relays (use the 12 gauge wire). Connect 12v+ to pin 30 on each relay (again with 12 gauge wire). Connect the ignition (hot with key on) wire to pin 85 on each relay (18 gauge wire here. Then run a wire from pin 86 to the switch then to ground(18 gauge again).
__________________
-Jon
Daily driver: 98 Maxima SE ... 14.9 @ 95
09 Drag car: 94 Sentra E ... 1/8: 8.2 @ 94, 2.1 60' 356whp/322wtq
06 Drag car: 91 Sentra SE-R ... 1/8: 8.6@ 86, 1/4: 13.1 @ 110, 2.2 60' 250whp
JSutter is offline   Reply With Quote
Old 09-24-2006, 10:35 AM   #7
aight cool!!! i'll give that a try!! gonna draw it out and see if that will work
Old 09-24-2006, 10:41 AM   #8
MDeezy's Avatar
Send a message via AIM to MDeezy
sounds like a pretty good memory!
__________________
Quote:
Originally Posted by MDeezy View Post
I guess this was payback for Skeeting on Minivans Bimmer
Quote:
Originally Posted by MinervaMaxxxima View Post
YES! That **** is still there, by the way.....
Quote:
Originally Posted by Crusher103 View Post
befoer i go ro seep n **** FCUK DEESY
MDeezy is online now   Reply With Quote
Old 09-24-2006, 11:15 AM   #9
wow.
Anyway, I like the idea, but I'd like something I can push momentarily and have it disengage the starter automatically when it's started up instead of having to hold it the entire duration of a few cranks. Seems a bit ridiculous, I guess, but I'm all about subtle things/details.
MorpheusZero is offline   Reply With Quote
Old 09-24-2006, 11:31 AM   #10
how many amp would i need for the switch and the relays? sounds like 30amp will do right?
Old 09-24-2006, 03:07 PM   #11
JSutter's Avatar
30 amp bosch relays are the way to go.
Old 09-25-2006, 02:36 AM   #12
Send a message via AIM to ethnic6
he can't find the hole...
ethnic6 is offline   Reply With Quote
Old 09-25-2006, 04:23 AM   #13
Send a message via AIM to scrhale Send a message via MSN to scrhale
I suggested this in a random thread, but isn't it possible to get some sort of proximity sensor and keep it on us (ie. our keychain) and then wire a push start. Basically if you aren't within range of the proximity sensor then your push start doesn't work. I stole this idea from the new Miata's. You have to carry that card around and then the key just sits in the ignition.
On a side note, if you wire a push start then do you lose the ACC part of your ignition?
scrhale is offline   Reply With Quote
Old 09-25-2006, 09:04 AM   #14
you don't lose anything....you have to put the key in the ignition and turn it to "on" and then push the button.
Old 07-04-2009, 01:15 AM   #15
is there anyway to do the push button with two switches for the "acc" and "on" positions? or is the chip and all that deals with that not bypass-able?
Brandon8965 is offline   Reply With Quote
Old 07-04-2009, 01:16 AM   #16
and i just realized i'm asking questions on an extremely old thread lol
Old 07-04-2009, 10:46 AM   #17
The Dirty Pearl
pmohr's Avatar
Quote:
The immobilizer system isn't easily disabled, that's the entire point of it.
You could do what you're saying, but the key would still have to be in the ignition (or the chip in close proximity to the NATS reader, if you wanted to dig the chip out and leave it taped on there). That's all to start the engine, of course. If you're not worried about that, then go to it.
Indeed.
__________________
A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-04-2009, 11:04 AM   #18
thanks man... you wouldn't happen to know what wires it is that go to those points and the ignition? the schematic says somethin bout more than one wire from the cylinder to some relay and from there to the starter
Old 07-04-2009, 11:05 AM   #19
The Dirty Pearl
pmohr's Avatar
What schematic are you looking at?
Look at the wiring diagrams in the FSM, they explain everything.
__________________
Old 07-04-2009, 11:15 AM   #20
sorry for my newness to this forum but what is fsm?
Old 07-04-2009, 11:20 AM   #21
The Dirty Pearl
pmohr's Avatar
It's not this forum specifically, you can find an FSM for most any vehicle.
Factory Service Manual.
Search FSM, you'll find it.
Or, look at my sig.
__________________
Old 07-04-2009, 11:23 AM   #22
o haha if that's the case then that's what i'm looking at.. i have the entire thing it is just a wee bit confusing
Old 07-04-2009, 11:29 AM   #23
The Dirty Pearl
pmohr's Avatar
The ignition switch has 6 pins.
Pin 1 is B+ in, W/PU - found on EL-11, EL-12
Pin 2 is ACC output, W/L - found on EL-12
Pin 3 is the primary IGN circuit, B/R - found on EL-12
Pin 4 is the secondary IGN circuit, R/Y - found on EL-14
Pins 5 and 6 are the two start wires, B/W and R/L respectively - found on EL-14.
All it takes is a little looking through the pages, you'll find what you need.
Also if you google for a remote start install (or search here), it'll show you what all of the wires are and their colors. Or search here for ignition switch pinout, you'll also find it.
The page numbers and wire colors are specific to the '99, other years FSMs will have different page numbers and may or may not have different wire colors.
__________________
Old 07-04-2009, 11:32 AM   #24
again thank you so much
Old 07-05-2009, 02:15 AM   #25
everything works great.. thanks for all the help
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
