Emission Test Help
Old 08-18-2006, 12:24 PM
Dev
Dev's Avatar
Emission Test Help
I just went for an emission test on a 95 auto maxima SE with about 110k miles on it. It passed on "HC ppm" and "CO%" but failed on "NO ppm". The limit was 435 and the car read 799. The mechanic wants about $500 to clean the PCV valve and replace the EGR solenoid. Do you guys think that these are the problems leading to the failed emission test?
Do you know what "NO ppm" stands for? I know ppm stands for parts per million...but what about NO?
What do you guys recommend I do...I want to try and fix this myself.
I am going to try and clean the IACV, check for codes (no SES light), and try using Seafoam through the brake booster line.
Dev is offline
Old 08-18-2006, 12:30 PM
MDeezy's Avatar
PCV valve is about $3 at local parts store. You can even let the pcv valve sit in a cup of carb cleaner and it will clear up blockage.
Do it all yourself and save about ~$450.
MDeezy is offline
Old 08-18-2006, 04:40 PM
JwaxMax99's Avatar
EGR system is not functioning correcty.
JwaxMax99 is offline
Old 08-18-2006, 08:19 PM
Dev
Dev's Avatar
What do you recommend I do to remedy the problem?
Is replacing the EGR solenoid the only way to fix the problem? Or is there anything else I can/should do?
Thanks for your input
Dev is offline
Old 08-19-2006, 09:28 AM
Dev
Dev's Avatar
bump......
Dev is offline
tarun900
19
12-20-2021 06:57 PM
knight_yyz
11-01-2015 01:34 PM
DC_Juggernaut
09-28-2015 04:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Emission Test Help
