rear brakes grinding noise
Hi, I got new drilled/slotted rotors and PBR Utlimates on my car like three weeks ago and eveything was fine until I realized the mechanic messed up the E-brake, so I went back to him and he took care of that, but now a new problem devolped in the rear passenger side where most of the time when I apply the brakes slightly, a metal on metal sound occurs. (a dragging sound)
It only occurs when I tap the brakes slightly...I also can feel it in the brake pedal. I took it back to them 4 times and nothing appears to be wrong, but they can't seem to find out what's making the noise.
I took it to another shop and he said just wait until the pads wear down and get new ones.
dont know the exact problem but here a try
did they check the retaining clip for the pads (could be rubbing against the rotor) ?
if everything ok then jack up the car, spin the tire with a friend pulling the ebrake and pin point the noise
or maybe even a lack of antisquel on the backside of the pad? (i never use it and i dont have the noise but just trying to help
i know this isnt the best of help but im trying since you seem so desprite. anyways good luck
problem is back after greasing everything in the rear... oh and its a groaning sound, not grinding
now, when the mechanic raised the car, we checked both rear tires and it seems that the left side wheel is a lil tighter than the other. Should I replace the parking brake cable? do you think that's the problem
Same problem, I 've been trying to solve this groan for over a year. It doesn't make noise everyday, but often enough. You name it, I've replaced it, tried everything, same noise. Now I just live with it.
I have a 99 Maxima and I have the exact same problem nart and it amazes me that my mechanic doesn't even know what the hell it is. well I think I narrowed it down. I took of the wheel and inspected the braking system my self and observed that on the side that the moaning is coming from (or so I think) the caliper piston is not sitting flush behind the brake pad. It's actually resting on top of a raised surface or what appears to be one of three "bump" that's built into the design of the shim. I think this could be the problem as it's applying additional pressure to the pad causing uneven pressure as you brake.
Let me know if you handled the situation
Huttig2009
09-25-2015 03:31 PM
carlosvq30
08-17-2015 11:32 AM
