Help newbie to choose a torque wrench
Old 07-24-2006, 02:21 PM
svojs's Avatar
New to these fun DIY stuff. Decide to re-grease my starter pretty soon. In two months or so, I would clean TB, replace spark plugs/coil packs and KS.
A lot of bolts of the DIY works above need properly torqued. My question is, what size of torque wrench should I have? There are different head sizes and wrench length available on the market. How and what should I choose one (for all the works I mentioned above)?
TIA
svojs is offline
Old 07-24-2006, 02:37 PM
Maintenance Monster
dgeesaman's Avatar
I used a torque wrench for none of those, but if you do I'd get the 1/4" drive that measures in in-lb.
IMO it's most important when torquing fasteners that require 10+ ft-lb, since they are often under greater load. Smaller fasteners that hold the KS or intake together really just need to be snug, and not overtightened. Spark plugs are usually finger tight + 1/2 turn or something like that - if they're new that's just enough to partially crush the metal washer that comes on the plug. You might want to look up the plug tightening procedure yourself.
Dave
dgeesaman is offline
Old 07-24-2006, 02:39 PM
southeast_first's Avatar
+1 on not really needing a torque wrench for those projects. you will need one if you're serious about working on your car, though, and i think that a half-inch drive that measures up to 200+ ft/lbs would be the best choice for you.
southeast_first is offline
Old 07-24-2006, 09:39 PM
RaWr!!! ('''_(o_O)_''')
Vlasic's Avatar
The only thing you need a torque wrench for are lug nuts and the bolts inside your engine, everything else just needs common sense. A torque wrench is a good thing to have, but you have to learn to not rely on it for everything. Lots of people will waste so much time looking up torque specs and setting their wrench to tighten things like strut tower bolts, or manifold bolts when you really can just do it by hand.
Ive replaced just about everything on my car (minus the motor) at one point and the ONLY thing I have ever used my torque wrench on are the lug nuts.
Vlasic is offline
Old 07-24-2006, 09:45 PM
svojs's Avatar
Thanks, fellow Maximaers. Looks like it's time to create some common senses.
svojs is offline
Old 07-24-2006, 09:49 PM
grandmastr's Avatar
I use the torque wrench when im gasket work on teh cars, like replacing the valve cover gaskets.
grandmastr is offline
Old 07-25-2006, 10:08 AM
Vlasic's Avatar
Another good example of something you DONT need a torque wrench for.
Vlasic is offline
Old 07-25-2006, 12:06 PM
grandmastr's Avatar
Well the one time I didn't use a torque wrench for replacing a gasket, I had a leak.
Old 07-25-2006, 12:20 PM
Maxima Owner
MaximaSE96's Avatar
i would torque KS to spec.....over torquing could damage it...that and wheel bearing HUB bolts....but a nice Craftsman are fine...i have a 3/8" and 1/2" Craftsman TWs
MaximaSE96 is offline
Old 07-25-2006, 01:12 PM
日産
hasei's Avatar
It's true that it's important to use common sense and you don't really "need" torque wrenches for a lot of tasks. I have torque wrenches but I don't always use them. But nothing wrong or bad comes from using it or relying on it in order to torque to spec.
I agree with southeast_first that a half-inch drive that measures up to 200+ ft/lbs would be the best choice, especially if you don't have a half-inch drive rachet or breaker bar. Maybe 150 ft/lbs one might suffice.
hasei is offline
Old 07-25-2006, 01:35 PM
ThurzNite's Avatar
holy crap, what requires 200 lb/ft?!
Jae
ThurzNite is offline
Old 07-25-2006, 03:55 PM
日産
hasei's Avatar
The only one I can think of is axle nuts - 175 lb/ft.
hasei is offline
Old 07-26-2006, 01:22 PM
ThurzNite's Avatar
Is 175 min or max?
Jae
Old 07-26-2006, 01:35 PM
4x4Max's Avatar
crank pulley is 140...thats kinda a lot for such a small bolt
4x4Max is offline
Old 07-26-2006, 02:04 PM
日産
hasei's Avatar
Originally Posted by ThurzNite
Is 175 min or max?
Jae
Minimum. It's actually 174 according to FSM. Max is 231.
hasei is offline
Old 07-26-2006, 09:18 PM
ThurzNite's Avatar
oh yeah, you're right. I don't weigh much... definitely less than 174. I guess I really jumped on my torque wrench to make it click. Haha.
I'm not so worried. The cotter pin holds the king nut which prevents the nut from backing out. All good!
Jae
Old 07-26-2006, 11:23 PM
nismology's Avatar
The crank pulley requires angle tightening. <-----
nismology is offline
RinconI30
11-10-2015 10:55 PM
TxBroncosFan
09-21-2015 06:54 PM
Hdnseek
09-09-2015 05:55 AM
carid
09-09-2015 05:06 AM
Quick Reply: Help newbie to choose a torque wrench
