4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
The compressor when not activated acts as a idler and spins with little if no drag on the belt/motor. The only increase I felt is the in-cabin temperature.
All my equipment is still there, just no belt running the compressor. I bypassed because my pulley bearing started to make some noise. I'm very particular about how my car sounds and didn't feel like rebuilding the compressor pulley. I'll end pulling all the parts off when I do my 3.5 swap.
FYI:
I bought NAPA part number 25-060355 and it works perfectly. I had tried the 25-060365 and it will work, but does not leave much idler adjustment.
I don't mean to revive an old thread, but I just bought the 25-060355 (napa had to special order it) but the box says 920mm, not 890mm. The belt model is 6PK903. I'm thinking that this might still work, though, with a little more adjustment of the tensioner. I will try it either tomorrow or Friday and reply here.
__________________ Originally Posted by PetitFrereMaxima:
Here I am after church walking to my car. And this guy parked next to me is walking to his car too. As I am about to get into my car, he looks at my stickers and start smiling then says, "Nice car! And nice choice of psalm! You must be blessed."
Reply Posted by perkman87:
I think Jesus is going to come down from heaven and remove the vinyl himself.
Ok, the 6PK903 belt worked perfectly. So, for the record, if anyone winds up having to do this, a 920mm 6-groove belt will also do the trick. Horrible a/c compressor bearing noise is gone, all is good (until the summer when I have to fix the a/c).
im getting this same awful sound from my a/c compressor the outside pully spins freely but the inside seems like its engaged all the time trying to spin. it spins once then stops then struggales to spin again 2 secs later
__________________
00 max 5spd Injen CAI, Flowmaster 40 series.....RMT dreams
Has anyone that bypassed their A/C compressor had any bad experiences / problems afterward? I've done this twice, with two 4th gen maximas, and had problems. First time, shortly after installing the shorter belt, I burned up my original alternator (@~130k miles). It happened instantly after a round of spirited acceleration. I'm starting to think that maybe the alternator pulley was overstressed by the increase in contact area with the belt and also the new angle that the shaft of the alternator was now pulled towards may have caused the coils inside to short out somehow. This is all just a guess, but it's my best guess. The second time I bypassed the A/C compressor I let the noise go on and on, and one day starting my maxima, I heard a loud thump and checked outside, my outer ring of the crankshaft pulley along with the belt was shot off the car. If anyone else has had issues with this bypass, I'd really like to know. Thanks in advance.
Rezinflux - I doubt the issues you had with your car after by-passing the A/C were caused by that mod. Our Alty's our known to crap out, and they sometimes go instantly. The outer ring of the flywheel deterioates as time goes by. It's nothing more then a rubber insulator. There have been quite a few reports of this happening, my buddies I30 had completely dried out and split as well.
If you tightened up the belt a bit to much after the mod, then yes, this could have accellerated the failures, but not caused them.
__________________
As the 4th gen ages, its owners get younger.
Old thread new question. I want to do the ac delete but while I'm at it I dont need the power steering either. Anyone know what belt to use. Mind you its a Vq30 but its not in a max or anything that would need ps.
evo
Use the belt shown above then just don't put the PS belt on...
Sorry to dredge up an old thread but this is exactly the information that I needed for the temp A/C compressor bypass belt. NAPA's part number 25-06355 is currently displayed as NBH 2506355 on their website and a cross reference number for an equivalent Gates belt for the same application is K060355 in the event you don't have a NAPA parts house in your area.
Just did this past weekend. Auto Zone Duralast belt 360K6. How your read it is 360 at the beginning is 36.0 inches length, K6 is 6 ribs(grooves) which what you need to fit the grooves of the pulleys correctly. This is the perfect size, belt was ~$14. Great relief, i had a whining sound which went up and down with revs and at some point had me thinking could be timing chain, whew.
Im going to do this mod this weekend. I've read before on here it may make the dfrost not work, is that true/ will the heat still work for the winter?
Also, do I need to unplug the compressor as well?
Why would you do this? Not worth it.
Either way, the defroster worked fine, since I did it in the winter, and all the windows needed was heat, not the compressor. And I never unplugged my compressor either.
When WOT, even if the AC was on, there is a relay that will shut it off. It's only minimal drag.
__________________ 03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
Quote:
It's like killing ants with a rocket launcher ....
Compressor makes to much noise and needs replacement/doesn't work. This is temporary until I can afford a rebuilt, or new one...but I don't care for an AC to much..
Thanks.
__________________
"I Have wet more people than the pool and the beach" - Shyheim
thanks for the help. this is the one that worked on my 99 maxima SE:
25-060355 (35.5 inch).
the 37 inch was too loose, maybe my alt or idler pulley is a different diameter from someone who said it fit.
now that the ac is out of the loop, notice the crank pulley wobbling, wtf
this pos is killing me.
