Help!!!!! I get a noise in front 1999 maxima
Old 07-18-2006, 02:23 PM
hobokenkid's Avatar
I have been to 2 dealerships and they cannot find the problem. It sounds like rocks rolling around when I do a slow turn mostly a right. When I go through a tunnel you can also hear the noise. ANY IDEA what to look for or even tell these guys. One told me it was the brakes but we changed them a few weeks ago and still a noise. Thank you ...
hobokenkid is offline
Old 07-18-2006, 02:27 PM
maltonboy's Avatar
ur rotors are probably touching the back shield... that supports the rotors... could be something like that i suspect...
maltonboy is offline
Old 07-18-2006, 02:30 PM
Maintenance Monster
dgeesaman's Avatar
It's hard to say, without doing some basic tests to narrow down the location.
1) Does it vary with RPM, or rolling speed?
2) Does it happen only when in gear, or when on the throttle, or idling?
3) Does it happen when you're turning the steering wheel?
4) Can you tell where the noise is coming from? High, low, a wheel well, etc?
5) Does it change if you apply the brakes?
Offhand, it could be a wheel bearing, tranny bearing, throwout bearing, or a bad bearing on one of the accessories.
Dave
dgeesaman is offline
Old 07-18-2006, 03:41 PM
hobokenkid's Avatar
Usually when I start out it is very loud only when in gear and moving
yes gets louder as i turn
aahhh I would say it ounds like its in the wheel., but actuaaly both it was louder on passengerside a few months ago
No only happens when I am moving
Thanks Dave
Old 08-08-2006, 09:09 AM
cab
cab's Avatar
That sounds like classic CV-joint noise to me. I've always described it to people like this "It sounds like you have a hubcap full of rocks in it when you are making a turn - the tighter the turn, the louder the noise".
cab is offline
maxinout93
10-27-2015 01:29 PM
Stagnet04
09-02-2015 07:53 AM
Greenmaxspeed
08-08-2015 12:39 PM
kirkhilles
08-08-2015 10:53 AM
laparka66
08-06-2015 09:36 AM
Quick Reply: Help!!!!! I get a noise in front 1999 maxima
