?Jack-Stand position?
you can also hit the two chassis/frame rails inside the four jack points. (the runners inboard of the jacking points in the diagram above.) This decouples the rolling stock from the support point.
Makes a difference when you set up your suspension
then jusr use the rear beam and front crossmember...there are spots for lift points under the car...the front are the "frame rails" the rear and little spots for stands of lift arms in front of the rear tires...not the notches but little spots u cant miss them
Sounds like a bad experience!!! I couldn't use the rear because of my RSB. Anyhow, I managed to lift it from the front. As for the back, I lifted it up 1 side at a time. Thanks for the help guys.
DC_Juggernaut
09-28-2015 04:07 PM
