Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 07-06-2006, 07:29 PM   #1
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
Building GOOD coilovers on a budget
1st I want to thank Poowill for the camber plates, Soybeanz for the Koni's, MZMTG for the rear mounts, and IIRC ne max for the ground controls.
Now before you go off and say I should have bought D2 or Ksport let me say this: Konis.... period.
Its been a long time gathering the parts to do this, but I finally have everything. My new suspension consists of shortened Koni yellows up front, B14 AGX out back, G/C with ERS springs (450f/ 350r), Stillen camber plates, and Bens rear mounts. I dont have the rears installed yet, as I ran out of day light putting this stuff together. You may wonder why the rears are off a B14, you just have to wait and see.
For now Ill leave you with pix of the front setup. Tomorrow I will post up the rears, along with more info. I havent driven much at all, but the car is lower and I have more wheel travel. Like 3x the travel, its pretty nice. Oh and the ride is not much different than the AGX/Eibachs.
Just so you know heres the cost break down:
Ground controls: $100
Koni Yellows: $200 (full set plus an extra front)
B14 AGX: $60
Camber plates: $120
Bens mounts: $75
For a grand total of $555, thats less than the AGX and Eibachs new! Crazy huh? I should add about $15 for misc screws, RTV, paint, and such.
__________________
-Jon
Daily driver: 98 Maxima SE ... Best E/T: 14.9, Best trap: 95
06 Drag car: 91 Sentra SE-R ... Best E/T: 13.1, Best trap: 110, 2.2 60' R.I.P.
09? Drag car: 94 Sentra E ... In the making
JSutter is offline   Reply With Quote
Old 07-06-2006, 08:03 PM   #2
JSutter's Avatar
Quote:
Originally Posted by Stagnet04
is it me or did you put these on with no dust boots? Damn good set up by the way...
I never thought about the boots. I should get the rancho boots! I used them on my winter suspension. They are like $3 each, so its not a bad investment.
Some day when I get the one rear koni fixed (bent piston) i may use them, but for now its B14's!
Quote:
Originally Posted by MaximaSE96
arnt they a lil shorter for more travel as well
The b14's are 1" shorter, so that cats out of the bag lol.
Old 07-06-2006, 08:26 PM   #3
JSutter's Avatar
MaximaSE96 go shorten your front koni's NOW! BTW B14 rear konis are reds, not that it matters much, still no external adjustments. Also the red will lower you car that 1" on traditional springs, so you would need coilovers. Like I said I will post up more pix tomorrow.
Quote:
Originally Posted by madmax95se
how is the ride quality affected?
its improved...more travel = more gooder for crappy rear suspensions such as 4th gen maximas
There really isnt much different of a ride because A) AGX are harsh B) there is more wheel travel to keep off the bump stops. Even a mild drop like Eibachs have very little wheel travel. Every one out there on Stechs, Sprints, etc. think their car rides so great and couldnt be better. EVERY lowered Max needs to buy Konis and shorten them. You will get an extra 1". If you buy 3rd gen Maxima Koni reds you can gain much, much more since they are shorter. I was going to get them, but they are not externally adjustable. I also got a super deal on the yellows. Also some type of rear mount is needed, weather it be Motivational Engineering, Bens, or others, travel is the key here.
The best thing you can do it get more travel. I really couldnt tell much of a difference in ride quality even when adjusting it. I was about as high as stock, and then 2" lower and it rides the same.
Old 07-06-2006, 11:34 PM   #4
JSutter's Avatar
Quote:
Originally Posted by Fr33way
Very interested in the full setup. Noises?
There is a slight rattle and it could be many things. Koni's use a plastic disc that sits on the gland nutt, and I can hear that, but there is another noise. Its either Stillens crappy bearing or I didnt get the Konis tight inside the strut housing. Its not loud at all, but with the radio off and the windows down its noticable. No worries seeing as it can be cured. Its nothing like my Sentra.
Something I would love to get is either helper springs or tender springs. I just need to keep my eye out. Also seeing as the front is threaded entirely I could get longer springs, especially good if these ever coil bind.
__________________
-Jon
Old 07-07-2006, 04:07 AM   #5
Camber Plates
Quote:
Originally Posted by JSutter
There is a slight rattle..........Its either Stillens crappy bearing or......................
You may be on to something there about that spherical bearing on the Stillen camber plate.........I know from experience having bought a pair of used plates. Could only hear the slight knock on something like a gravel driveway or crossing railroad tracks. Drove me nuts! Changed over to the Eibach camber bolts and found an expert alignment shop that was able to bring the front camber into spec. With 8" front rims and expensive, unidirectional rubber, too much negative camber can really wipe out good tires.
BTW, this same alignment shop found the left-rear to have too much toe-in. I've owned the car since day-one and have never had any experience that could account for that. But within a few months of buying the car (new) I was back to the stealership with complaints about the car having a very slight, almost unnoticable "drift" to the left. They never could account for that, and finally told me that it was my imagination. But now with this finding of the left-rear toe-in being too excessive (and seeing that tire wear with a slight cupping to the tread), I know what's causing the drift. Too bad it's not easily correctable.
Curt is offline   Reply With Quote
Old 07-07-2006, 05:08 AM   #6
Spec V Sell Out
MaximaSE96's Avatar
Send a message via AIM to MaximaSE96
i will prolly shorten them up over the winter....when i have my own garage to work in.....i have ben's mounts i just have to put on....i want to get soem prices on b14 rears.......i have only hit the bump stops in front a couple of time on larger bumps but i woudl still like the travel....to be honest i kinda was thinking about going with rear illuminas for a while because of the external adj. but i have my Yellows set about in the middle and its very livable on the street and with fronts full stiff....RSB the oversteer is still greatly reduced...so i might just wait and save my money until i really need new ones
__________________
I sold out and bought a Spec V...I miss my 4th Gen Maxima...
MaximaSE96 is offline   Reply With Quote
Old 07-07-2006, 10:36 AM   #7
Ichiban King
Apparition's Avatar
Send a message via AIM to Apparition
speaking of Bens mounts I should look into that I suppose.. as far as camber plates, a good amount of orgers said I wouldnt need them for my setup. Egh anyways I cn't get enough of that J. its good stuff, esp. for that price it's a blessing.
- Eibach
- AGX
Apparition is offline   Reply With Quote
Old 07-07-2006, 10:45 AM   #8
JSutter's Avatar
Quote:
Originally Posted by Zack342
Why did you paint the fronts pink..
HAA HAAAAA......i am assuming he wanted to match the rears.....seingas yellows use stock housings they would be black and yellow....so he painted them a wierd shade of red to try and match the AGXs
OOOh pink, yea thats a cheap threaded sleve I had from another coilover setup. Its more of a magenta maybe. I didnt paint it thats for sure.
Quote:
Originally Posted by DR-Max
1) How do you shorten the Koni Yellows? For what Maxima should the Koni's be?
2) What brand of camber plates are those?
3) Where can I get the ERS springs?
Please take pix of the front drive axles once the car is back on the ground with the entire setup in place. I want to see how much angling as a result of the shortened struts + coilovers.
I tore down one of the camber plates and the bearings are not anything special, no teflon lining which would help. They are about $40 each for the ones in there already, so I'm not going to get into those anytime soon.
The camber plates are from Stillen and as far as I know Cusco made them, OR Stillen made one hell of a copy.
These Konis are for the 4th gen and are the same length as stock to begin with. To shorten the Koni you must cut some of the end off (VOIDS WARRANTY!), drill out the bottom of the strut to 1" and let the threaded part stick out. It will gain you 1", which seems like nothing right? Well if you did this with a mild drop spring you would pretty much get all the travel back. Like I have said countless times, the 3rd gen (89-94) Koni reds are 3.5" shorter. They can handle a 500in/lb spring no problem. They are also what Motivational Engineering used for just about all their shortened setups. Koni does make shorter externally adjustable struts as well. But they take much more work to install, cost more, and for the average person dont have any other benifits really.
For a good Koni install check this out (including shortening them): http://www.johnandtracey.com/gallery/struts
ERS stands for Eibach Race Spring, Ground control uses Eibach exclusively on its kits. Eibach makes springs of all types, their ERS line covers all sizes for coilover applications. They are quality, no piss poor Ebay unknown rates that bind up because of the crappy wire used. IIRC Boss Chens use Eibachs.
For those who would like to get into this, good luck. None of these part are cheap when new. Its also a pain to find a good deal on them. The camber plates are discontinued already so that will be the hardest. These parts are very under rated, and not to many people have them, let alone to sell used.
Old 07-07-2006, 12:24 PM   #9
Blown
Send a message via AIM to cardana24
Thanks for the reply, I am very interested in this aspect on a car that I drive daily. Do you have anything locking that lower collar?
the collars have allen bolts in them to pinch to collar when you have it where you want it. There is not another ring to lock it into place like D2's and K-sport.
__________________
Hey Karim, you still on Blackplanet?
cardana24 is offline   Reply With Quote
Old 07-07-2006, 12:42 PM   #10
JSutter's Avatar
GC uses an allen screw to tighten the collar, like a clamp. It squeezes around the threaded sleeve. You can see the screw in the 3rd pic.
Driving from my apartment to my parents garage with the a/c on, windows down, and radio up the noises are faint, but there. Its kind of a clunk, I'll dive into it sometime. In honesty its no where near as bad as an early 4th gen. They have so many interior rattles its rediculous.
***I still need to do the other side, so dont ask me how it rides.***
Forgive me and my shotty camera skills. Pics of the B14 rears. Those who dont know the B14 is a 95-99 200sx/Sentra. The same rear shock is used in the 99-02 Infiniti G20, and also the newer B15 Sentras.
[img]
Good shot of Bens mounts on the left, and ME mounts on the right. They both do the same thing, more rear travel. As you can see the Eibach spring was slipping off....my guess is because I didnt use poly bushings.
As you can see its quite abit shorter. With the coilover adjusted to the top. Right now its about a finger gap. You could easily use the stock mount to raise the car about 1".
More info comming after I finish.
Old 07-07-2006, 01:15 PM   #11
JSutter's Avatar
Quote:
Originally Posted by cardana24
did you use the rubber spring isolator in the rear?
Part Number: 55034-31U00 http://www.kcmaximas.org/tech/suspension/index.html
second from the bottom. Its the part I was telling you that my upper GC perch was pushing thru...I was just curious if you were still able to use the long travel rear mounts, and not get noise from the isolator pushing thru the rubber "seat"/isolator. After a few days of driving on them please let me know how yours is holding up.
You dont need those with coilovers, as you can see in my last post.
oh really....maybe I will put mine back on then, and not sell them, then again the way you have it set up would bother me . I feel as if the spring could move side to side just pusing against that bushing. The top of the GC perch is domed so its made to fit inside the stock mount....I'm not saying your set up is not going to work...just raising some questions.
Its resting on the big spot on the piston, Im pretty certin this is the correct way. It fits around it perfectly.
Old 07-07-2006, 02:00 PM   #12
JSutter's Avatar
Well for all you slammed lovers, the B14 rears will do you good. They will lower the car 1" from what ever you have now. Problem is IMO they are too low to use with even the shortened Koni yellows. They will work best with 3rd gen Koni reds. This way you can even the stance, while retaining good travel. I cant get a measurement of the wheel travel up front right now. There is not enough room to get up in there.
Right now the rears are all the way up. There is 1 finger gap. So I had to lower the front to even it out. It was my only fear, the car being too low I mean. I could toss in the stock upper mounts to raise the rear, which I may, or I could use regular A32 shocks. We'll see. I wasnt trying to slam the car, but I cant raise the rear. Sure it looks good, but the ride is starting to suffer.
Old 07-07-2006, 03:45 PM   #13
JSutter's Avatar
Thanks guys. The ride is much better than the AGX/Eibachs on full stiff. Its slightly rougher at this height than before. I did put the konis to fill stiff, up from 1.5 turns. The rear AGX are on 3. Idealy raising the car up about 1" would make me happy. Maybe Ill put those rear konis you use in the near future. Im going to test this setup out for some time before making any changes and Ill get used to it. I have only driven in town and less than 40 mph. Maybe I can get some highway runs in tonight. There is a bridge on 295 that I hated driving on with the AGX and even more so with a RSB.
Its also funny to note that the noises are very faint now. The rear make a noise similar to the front, possibly an error on my part with the sleeves.
I still have the amber lights, but like always something gets changed frequently. You'll see them again be sure of it.
Old 07-07-2006, 11:17 PM   #14
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Damn that is low, how is your rear camber? With camber plates I was able to keep great camber up front with no accelated wear but if I slammed the rear I would notice the inside of the tires wearing at a very quick pace.
__________________
Fr33way™ is offline   Reply With Quote
Old 07-08-2006, 09:43 AM   #15
JSutter's Avatar
Its definetly too low. But Ill test this setup out a bit before changing the rear.
I have civic rear camber adjusters, i totally forgot.
But seriously, you know it doesnt change.
Old 07-09-2006, 01:15 PM   #16
JSutter's Avatar
Quote:
Originally Posted by kingrukus
I would be weary of using a B14 strut. Isn't that strut designed to hold a much lighter vehicle vs an A32 strut?
The B14 strut looks just as solid as the A32. The only thing I was worried of was the valving.
Im going to try a few different things with the B14 rears. The initial reason for using the B14's was the length. The spring wouldnt move around under full droop, and Id get a drop without having to crank the collar down. What I knew, but aparently forgot, was Bens mounts will drop the car roughly 1" when using the GC coilovers. So the 1" shorter strut plus bens mounts dropped the rear too much. Im tucking now that its settled. With the yellows shortend 1" up front it cant be lowered safely that low. No travel. The 3rd gen reds would solve that problem, but going this low or lower brings up more geometry issues than I want to deal with. The axles are probably at a harsh angle, the control arm is way high causing positive camber in hard corners, roll center is affected, alignments are off, and I dont even want to think about bump steer. It just make more sence for me and others who are more perfromance oriented to not go this low.
It handles really well on flat pavement, such as the high way. There is no body roll, its very responsive, and is a pretty good ride too. In the city with broken pavement, pot holes, train tracks and all the other fun stuff its not all that nice. Im very uneasy driving this low. For comparison take a look at the Eibach drop and then look at post #35.
Old 07-09-2006, 01:17 PM   #17
JSutter's Avatar
And for the big picture, stock suspension:
I will take some measurement to see how low I really went.
Old 07-27-2006, 04:46 PM   #18
JSutter's Avatar
Update:
Since I couldnt raise the rear I installed the stock upper rear mounts. It brought the car from tucking to about 3 finger gap. (I never wanted to go that low anyhow). Then I brought the front up to match. Thank God, I havent been driving the car much with it that low. It sucked big time. Now it rides well, so well that I cant wait to get my rear Konis fixed and installed. I have the front Konis set 1.5 turns from soft and the rear AGX on 1. I hate AGX now, they are harsh on anything but 1. I also found where the noises are comming from up front. The Koni inserts need to be shimed for a tighter fit. Its been really hot out, so I havent bother tuning anything.
Old 08-05-2006, 07:37 AM   #19
JSutter's Avatar
Quote:
Originally Posted by krismax
Does this mean we can use aftermarket b14 and b15 coilovers?
The rears are the same size in every way, except for length. Depending on how low you want to go you can use the b14/b15/p11 rear stuff. But the b15 rear upper mounts are different, so those wont work. None of the front parts will work off the b13/b14/b15 as they are all smaller. Also the spring rates for the sentras will be lower, so keep that in mind.
Quote:
Originally Posted by Fr33way™
What about Sentra/200SX interchangibility?
The Sentras have a similar designed front end, but all the parts are smaller. The strut off a Sentra wouldnt bolt to a Maxima hub. Also the upper mount, bearing, and insulator are all smaller in size.
Old 08-05-2006, 07:41 AM   #20
Your friend list is empty
Kevlo911's Avatar
Even if we use our upper mount? Or does the lower not bolt on to our hub?
__________________
97 Pearl White Max GLE
191WHP and 201WTQ
Bi-Xenon retro for sale!!!
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 02-21-2007, 06:32 PM   #21
Chassis Freak
VQuick's Avatar
Send a message via ICQ to VQuick Send a message via AIM to VQuick Send a message via MSN to VQuick
Jsutter, with your experience do you know how much suspension travel the stock 4th gen suspension has? I'd really like an exact number. It's got to be 3-4 inches or so...which explains why even 1.5" drop hurts ride so much.
I just ordered Boss Chens... 4"+ of travel, baby!
Any updates on your homemade coilovers? Great idea, by the way.
VQuick is online now   Reply With Quote
Old 02-22-2007, 12:05 AM   #22
Hit 'em with the stun gun
MainSource's Avatar
Send a message via AIM to MainSource Send a message via Yahoo to MainSource
J Sutter, looking back over this thread, I got kinda confused. Are you recommending using B14 konis in the rear and 4th gen koni yellows in the front? I'm looking to go for the best coilover set up I can get, with mucho wheel travel and a nice drop (1-1.5"). Any helpful info is greatly appreciated.
MainSource is offline   Reply With Quote
Old 02-22-2007, 12:14 AM   #23
Old enuf to pick his own gears
