CV Boot just ripped...how long do I have? repairable? PICS
Old 07-11-2006, 02:39 PM
  #41
no more maxima...
kingrukus's Avatar
Originally Posted by happy4444
holy $hit! wut kinda tools??? craftsman?
Definitely not Craftsman. It appeared to be made in china. If it were Craftsman, I would have gotten a replacement for free.
kingrukus is offline
Old 07-11-2006, 03:13 PM
  #42
ThurzNite's Avatar
Werd... I've broken some craftsman sockets and breaker bars before. Great that they just replace them (after u fill out some paperwork).
Jae
ThurzNite is offline
Old 07-11-2006, 03:31 PM
  #43
FEELS GOOD TO BE GANGSTA
semaj3708's Avatar
Buying a new axle and getting it rebuilt costs about the same. If your already in there replace the damn thing.
semaj3708 is offline
Old 07-11-2006, 04:33 PM
  #44
Back from the dead
RockfordMax's Avatar
for replacing it. Not worth the headache of replacing the boot when you can get new axles for 60 bucks a piece. I removed the ball joint, but needed a new one either way so I wasnt gentle with it at all.
RockfordMax is offline
Old 07-11-2006, 04:38 PM
  #45
Frank Fontaine's Avatar
Originally Posted by vsamoylov
yes thats another way of doing it. nissan sells a rebuild kit as well. i have used that before when rebuilding the dust boots. it comes with everything you need to do the job. it is cheaper but require more work and the job will get messy due to all the grease. the more simple way is to replace the axle because all you do is pull the old one out and pop the new one in. in this situation replacing the axle seems like the way for him to go but i may be wrong.
I agree with your philosophy, the more expensive way to me yields more bang for buck. One, it's a permanent-type repair where it's old one out, new one in. The other is a repair of a questionable part, where most people say the repair works, so it probably does. But in scenario A the driver knows he's good for years. Not everyone is looking for that, some people enjoy working on the car and isn't looking to drive forever. To each his own...
Frank Fontaine is offline
Old 07-11-2006, 04:41 PM
  #46
VIP Maxima
i have been riding on ripped cv boots for like 6 months now. i think 3 out of 4 are ripped. i dont have ANY clicking noises when i turn but axles click when i go straight !
Old 07-11-2006, 05:02 PM
  #47
ThurzNite's Avatar
The axles are rebuilt, which can be "questionable". Your boots are just as likely to be torn by debris as someone's w/replaced boot. As for worn bearings, there isn't a significant number of members who have noted destroyed bearings after replacing the boot. In this thread, maybe 1 member had destroyed bearings after replacing only the boot.
Jae
Old 07-11-2006, 06:33 PM
  #48
dabooki's Avatar
i think i have to replace the passenger side axle. a while back the 2 strut bolts came loose causing steering to wiggle after bumps, so i popped off the tire and tightened them back up. but after that the tire was riding on the inner edge and after months now, it wore through the metal mesh and created a big bubble there.
now i changed the tire out and loosened the strut bolts and pushed the wheele hub in a little to make it sit level. the alignment seems good now but after i did this, its making an awful noise.. squeeking creaking constantly when driving slow. when i turn at a certain angle, it stops..
my question is, is this the axle that needs to be replaced?
dabooki is offline
Old 07-12-2006, 09:40 PM
  #49
ThurzNite's Avatar
How is the bearing and hub? Is steering sloppy?
Jae
Old 07-13-2006, 08:39 AM
  #50
dabooki's Avatar
the wheele has no up and down play in it when off the ground.
dabooki is offline
Old 07-13-2006, 08:40 AM
  #51
dabooki's Avatar
steering seems tight, seems normal
dabooki is offline
Old 07-13-2006, 09:37 AM
  #52
440man's Avatar
Hey Kingrukus,
What about the step in the motorvate instructions about removing the bolt that holds the "gear indicator switch"? Is this necessary?
440man is offline
Old 12-15-2006, 08:31 AM
  #53
carguy's Avatar
Both of my CV boots in front are torn but there is no grease leaking out. I have gotten a couple of quotes from $400+ to replace the boots or the entire axles. Does this sound about right? I saw that someone had quoted a lot lower $ earlier in this post?!?
carguy is offline
matts95max
09-09-2023 01:52 AM
Bonka
09-14-2015 11:18 PM
Maxima Pride '07
09-12-2015 07:29 AM
dcam0326
09-08-2015 11:02 PM
videomano
09-08-2015 03:28 PM
Quick Reply: CV Boot just ripped...how long do I have? repairable? PICS
