What Oil Filter Brand Do You Guys Use?
#41
Originally Posted by VIP Maxima
and the OEM is like 5"
i never said its exactly 5". i estimated it by measuring how long 2.5" was
and this is a good link for you
http://forums.maxima.org/showthread....=traction+bars
#45
Not sure if you've checked the link yourself but my posts are all over that place. So yea...I do know about that link.
#46
Went to the Nissan dealer by work during my lunch break. I picked up the 15208-65F00 oil filter. It's approx. 2.75", shorter than the 9E000. Both part numbers are for our Maximas according to their computer. This will definitely work for me. They wanted $11 but I talked them down to $7.
Based on what I heard so far, the only 4th gens that have reported oil filter clearance issue are the 95/96's. Not sure why.
#49
i use the k&n oil filter..im in good with the local parts store and we cut open fram and the k&n since fram is what a lot of people use and its really poor compared to the k&n but the clearance issue i have no clue..i also use the mobil1 supersyntec 15,000 mile oil
#51
Got royally screwed by some Framm ultra-mega-cool filter once - never again.
www.nissanpartsonline.net
OEM $3.99 each - no minimum. It's a no brainer.
#52
Does oil filter make difference?
I always buy oil filters from Nissan dealer. My local dealer always has "buy 3 get 1 free" discount. It's just 20 something dollars for four filters.
Oh, forgot to mention, each filter comes with a copper washer that can be used with oil pan drain plug(bolt).
#53
I Use Fram 7317 and never had any problems. I have 119,000 miles and still have a really tight engine. It still runs like like new. I just changed the plugs after 85,000 miles and could have gone another 20,000 miles on them. I am running Bosch Platinium + 4's.
#55
Fram
I'm not too worried though, I haven't had any problems yet and if It does cause something to go wrong, 3.5 time. My oil always looks fine when I change it, so i've had no reason to switch filters
#57
Fram and bosch...good combo
#58
Originally Posted by motocross416
Fram
unless you see chunks of metal...looks mean absolutly nothing...
#59
Originally Posted by maxgtr2000
Maybe I'm wrong, I thought nissan oem is like $8, that's what I use, the regular oem.
#66
Originally Posted by fro98665
Are the Bosch premium ones any good? They can be had for around $5.
Yes, I use them.
#67
If you got a stock of 2002 or earlier their alright, after that their made in mexico...so their bad, before that they are nothing special
#70
I used to have mad wheel hops. Not anymore, these traction bars work! My only issue now is the tire rubbing on the passenger side bar. Perhaps now that I have plenty of clearance, I can remove a few more washers to bring the bar in. I'll have to try this early in the morning when its not so hot! Yo, I'm feeling like a mini-meet! My trip to the dessert got cancelled because of the extreme hot temp, don't wanna get heat stroke out there. Let me know!
Originally Posted by steven88
how does the traction bar feel dennis?
#71
#73
comon now, get a filter wrench and its just as easy with that nut, better yet if your cheap just stab a screwdriver through it and twist the screwdriver...or best yet just put it on without too much torque, and taking it off will be easy
MatthewsMaxima
09-11-2015 03:21 AM
homewrecker
08-24-2015 08:56 PM
