Ran my brake fluid dry, cant bleed!!!!
Old 05-30-2006, 02:13 PM
thefed's Avatar
A line burst at the front passenger wheel. I fixed it. The system was totally dry. I filled up master, bleed for an hour (gravity,pressure,2 man team) and nothing... not even a dribble.
Someone said I was fubar'd because i let it go bone dry, and something about 2 valves?
Can anyone shed some light plz?
thefed is offline
Old 05-30-2006, 02:29 PM
Nismo's Avatar
I did that once and couldnt get it to bleed. I accidentally had the key in the ignition on on and nothing came out. Took the key out and it bleed fine. Not shure if thats the problem or not.
Nismo is offline
Old 05-30-2006, 03:09 PM
100% chingon
clive's Avatar
Doesn't sound right. You must be doing the procedure incorrectly. Open the furthest bleed nipple - rear right? and pump the pedal. The whole system can't be bone dry. Remember it's pedal down - close bleed nipple - pedal up - open nipple - pedal down - etc.
Then proceed to the other rear wheel, work your way around. Last wheel to do is the one nearest the master cyl.
clive is offline
Old 05-30-2006, 03:40 PM
jac121479's Avatar
i just had the same crap happen to my clutch. i couldn't bleed it by pumping the pedal so after jamming the attachment of my power bleeder in there and forcing 20 psi through there i finally got it. get a hold of a power bleeder and you should be good.
jac121479 is offline
Old 05-30-2006, 03:54 PM
Maintenance Monster
dgeesaman's Avatar
I had a similar issue once bleeding a clutch. A vacuum pump at the bleeder got enough into the system to use the pedal again. Autozone rents a vacuum pump.
Dave
dgeesaman is offline
Old 05-30-2006, 04:52 PM
ThurzNite's Avatar
My autozone and Kragen have a vacuum bleeder kit, something like this:
http://www.harborfreight.com/cpi/cta...emnumber=92474
Jae
ThurzNite is offline
Old 06-07-2006, 12:24 PM
Project Ruby......
4DRSpeed's Avatar
Bump.
I changed my SS clutch line out. And when I went to fill the master cylinder with brake fluid I noticed it was already bone dry basically. Which answered two questions.
1. No wonder very little fluid came out.
2. It explains why my clutch acts funky from time to time.
I bought a vacuum bleeder kit, I hooked up to the bleeder and I pump away and very little fluid comes out. Does this mean I have so much freakin air in the system? Or is something else wrong? The fluid in the master cylinder is not dropping at all.
4DRSpeed is offline
Old 06-08-2006, 10:32 AM
toddemullins's Avatar
I'd suggest picking up a set of speed bleeders too. I replaced all my brake bleed nipples with speed bleeders and can bleed the system pretty efficiently alone. Keep in mind that it takes many, many, many pedal depressions to push the fluid through. It took me a few hours to bleed mine when I replaced my brake lines with ss lines.
toddemullins is offline
Old 06-08-2006, 10:48 AM
jac121479's Avatar
had the same issue when i replaced my clutch line. i used a power bleeder and it took about 15 minutes.
http://www.motiveproducts.com/02bleeders.html
Old 06-08-2006, 11:39 AM
Power bleeder, now that's even better...
Old 06-08-2006, 01:59 PM
Project Ruby......
4DRSpeed's Avatar
Bought a power bleeder for my clutch. Not working out. I believe the Master cylinder is shot. I ordered a new one. Hoping this solves the problem.
4DRSpeed is offline
Old 06-08-2006, 02:26 PM
Maintenance Monster
dgeesaman's Avatar
That's bizarre. With speedbleeders it takes about 10pumps per corner to fully clear the system, and that's using almost a full liter of brake fluid. Did you have the bleeder opened far enough?
But buying a new master cylinder is almost never a bad idea when fighting clutch or brake problems. It's just too damn important. I don't buy cheap protective cups, condoms, or brake components.
Dave
Old 06-08-2006, 05:37 PM
Not sure what the problem was with the bleeders, but it took forever. Maybe I was going overboard on making sure all the air was out of the lines, so it probably was fully bled after several pumps. Was my first real brake job, so I'll chock it up to being a brake noob.
pktaske
05-06-2016 07:49 AM
fastcarny
10-12-2015 07:06 AM
imported_Nismo_max
09-20-2015 08:19 AM
pktaske
09-04-2015 08:40 AM
Quick Reply: Ran my brake fluid dry, cant bleed!!!!
