Sway Bar End Link replacement How to. (pics)
Old 05-28-2006, 12:47 PM
Zack342's Avatar
For some time now my car made this periodic clunk when I would drive on serverly bumpy and uneven roads. At first I assumed it was my 138k stock SE suspension letting me know it was on its way out. So i pruchased new shocks and springs. Tein H-Techs and Tokico Illuminas. Car wonderful but the clunk would still exhibit itself periodically on bumpy roads, low speed driving in parking lots and sometimes during braking.
So I then thought my LCA bushing were worn so i ordered ES bushings to replaced them. Before installing them I decided to go to a local mechanic who usually does my inspection sticker to get a quote on installed the LCA bushings.
Long story short my LCA bushings are fine. The culprits where the swaybar endlinks.
Being ambitious and cheap I decided i would do the install myself and save the labor.
Ordered all the parts from Infiniti. Less than $30 for both sides.
Today I decided to tackle this since the noise/clunk has gotten worst.
For this you will need.
1/2 drive ratchet and metric socket set. (14mm is all you need)
Some PB blaster or your choice of penetrating lubricant.
1/2 extensions
I used air tools but what I just listed is all you need for this job.
First step is obvious jacking up the car and supporting it on jack stands, You need to remove both wheels since you will be doing both side at once.
Once wheels are removed you will see the cluprit which is held into place by 2 14mm bolts on two places, one attaches it to the sway bar and the other to the LCA.
I also suggest loosening the sway bar bushings so that you can turn the sway bar ever so slighly to get the endlink out. 2 14mm bolts.
Basically its pretty straight forward from there. remove the bolts and removed the endlink and hard ware. Comparo shot of 140k old end link and brand new one. My driverside endlink was horrible which explains why the noise was on the drivers side. it was sooo loose.
I did both sides at the same time and tightened then both after everything was in place.You install them just as they were removed. I secured the bolts as tight as I could but I am sure someone can look up the correct tq specs.
Finally reinstalled links should look like this
Zack342 is offline
Old 05-28-2006, 12:49 PM
Kevlo for President
Kevlo911's Avatar
Also, you can add the energy suspension bushings to make it stiffer.
I shall get it added to the how to's
Kevlo911 is offline
Old 05-28-2006, 12:50 PM
Zack342's Avatar
I highly recommend this to anyone who has a higher mileage maxima. Like i said the parts were less than $30 and it took about 2 hours. I take my time and it takes a while for me to jack up the car.
Driving impressisons: Car feels tighter and best of all no noises or embrassing clunk.
Zack342 is offline
Old 05-28-2006, 05:15 PM
darklegend06's Avatar
I just replaced my lower control arm and the things and what a pain it was. Luckly I had air tools. Good luck to those that are replacing them.
darklegend06 is offline
Old 05-28-2006, 05:29 PM
I'm nutty for Nissans
JSutter's Avatar
Hey Zack you need to straighten out the endlinks. They must be in line with the braket on the control arm. $30 must have been with your bro's discount, since I bought NAPA ones at IIRC $20 each.
JSutter is offline
Old 05-28-2006, 05:34 PM
Zack342's Avatar
I did that after. I tightened them. They are straight now.
Yeah i was suprised to i think it was like $28.XX for everything all new nuts, washers, bushings and links.
Zack342 is offline
Old 05-28-2006, 05:48 PM
Black Maxima
Cool post, how can you tell if your sway bar end links are going bad, besides the clunk noise? I have no many noises I just turn up my radio. This seems like something I might want to try...
Old 05-28-2006, 06:53 PM
Custom User Title
Nismo3112's Avatar
Nice writeup.. I should do this before I sell the car.
Nismo3112 is offline
Old 05-28-2006, 07:42 PM
Custom User Title
Nismo3112's Avatar
I priced the parts at nissanparts.cc, came out to about $55 shipped for all pieces.
I'll try DAVEB, and local dealers.
Old 05-28-2006, 10:18 PM
Zack342's Avatar
Damn. I guess he gets a good dicount.
Zack342 is offline
Old 05-29-2006, 05:34 AM
Black Maxima
Please post up some part numbers.
Old 05-29-2006, 05:44 AM
speed racer's Avatar
+1 for the part numbers.
speed racer is offline
Old 05-29-2006, 06:50 AM
Maintenance Monster
dgeesaman's Avatar
Actually, there is a hex shape in the end link so that you can hold it still with a wrench while you tighten nut on top.
Dave
dgeesaman is offline
Old 05-29-2006, 07:07 AM
knight71's Avatar
you will need moog part # k9824...you can order these through www.rockauto.com.
knight71 is offline
Old 05-29-2006, 07:33 AM
B!tch We Got a Problem
Gismo-T's Avatar
Just got TRW sway bar endlinks from Advanced Auto for $28.
Part #18166
Gismo-T is offline
Old 05-29-2006, 09:31 AM
Maintenance Monster
dgeesaman's Avatar
End Link: 54618-0E000 ($14.49)
Washer (2 per side): 56113-60U05 ($1.28)
Bushing (2 per side): 56112-V0100 ($2.40)
Upper Nut: 01223-00291 ($0.54)
Lower nut: 01225-00261 ($0.66)
Unless you know of damage, I would only buy the bushings and link and re-use the hardware. These part numbers were pulled for a 97 SE, but I'm almost positive they work for all 4th gens.
Dave
Old 05-29-2006, 09:57 AM
Zack342's Avatar
Dave
Thanks Dave I couldn't find my invoice.
Zack342 is offline
Old 05-29-2006, 10:43 AM
Custom User Title
Nismo3112's Avatar
I am doing mine right now. After 183k miles, mine are beyond repair!
Old 05-29-2006, 10:51 AM
Zack342's Avatar
Alot of play compared to the new ones right
Zack342 is offline
Old 05-29-2006, 10:55 AM
aznsap's Avatar
Dave
where do we order for these prices?
aznsap is offline
Old 05-29-2006, 12:29 PM
Custom User Title
Nismo3112's Avatar
There was so much play in the old ones, I could probably pull the joint right out.. Here's a pic:
I bought a set of Moog's from Oreilly's. Each kit comes with the hardware, $21.99 per side. The car actually feels alot better driving now. Much more direct feel when turning corners.
On a side note, my car has had an annoying suspension squeak for quite some time now, and lately it has been getting worse. Well, after I replaced these and went for a drive... THE SQUEAK IS NOW GONE!!
Old 05-29-2006, 12:43 PM
Nissan maniaco conpulsif
hightuner's Avatar
bough mine
hightuner is offline
Old 05-29-2006, 12:49 PM
MDeezy's Avatar
good to hear people are noticing a signigant feel from this. Mine are going in next weekend with a new spindle control arms and inner and outter tie rods.
MDeezy is offline
Old 05-29-2006, 05:43 PM
Zack342's Avatar
Damn those are beefy. Glad to hear it got rid of your moises also. Such an easy fix i can't believe i hadn't done this sooner. Also for the price you can't justify not doing it.
Zack342 is offline
Old 05-29-2006, 05:57 PM
Black Maxima
Dave
Are those part numbers from the Nissan dealer?
Old 05-29-2006, 05:58 PM
Black Maxima
Dave
Old 05-29-2006, 07:12 PM
Custom User Title
Nismo3112's Avatar
Yes.... They ARE Nissan parts.
Old 05-29-2006, 07:24 PM
Black Maxima
COOOOOOOOOOOOOOOOOOOOOOOOOOOOOL.
kthxbye
Old 05-29-2006, 07:55 PM
aznsap's Avatar
are those rubber? can we use urethane for those?
aznsap is offline
Old 05-29-2006, 09:03 PM
MorpheusZero's Avatar
Nice, are the bushings stiffer as well or is it just a beefier endlink? I'm thinking about doing this in the near future but I'd like some energy bushings (or equivelent).
MorpheusZero is offline
Old 05-29-2006, 09:29 PM
3.5 in the works
DandyMax's Avatar
Just did all new ES bushings up front after 110k miles. What a difference! I did the CA bushings, sway bar bushings, end link bushings, and sub frame bushings. That plus the motor mounts I already had, KSports and new ball joints and it's a totally different car.
DandyMax is offline
Old 05-29-2006, 09:31 PM
Wow. How much total, and how long did it take you to put 'em all in?
Old 05-29-2006, 09:47 PM
DR-Max's Avatar
zack342,
Thanks for the write-up. You've described the clunk that I've been trying to figure out for quite a while now. I must do this next!
So what's the cheapest price on them? Should I stick with the oem replacement?
DR-Max is offline
Old 05-30-2006, 09:58 AM
aznsap's Avatar
do you have all those part #'s on hand by any chance? and where'd you get everything and how much?
aznsap is offline
Old 05-30-2006, 10:04 AM
DR-Max's Avatar
Part #'s are in post #16.
DR-Max is offline
Old 05-30-2006, 10:32 AM
Custom User Title
Nismo3112's Avatar
I think so, yeah you can replace those with urethane ones.
I am not sure, as I don't know how well stock good condition ones feel. But definitely 100x better than my old ones.
I had to cut my driver side one off because it was too rusted and the bolt wouldn't come off..
Old 05-30-2006, 10:50 AM
Zack342's Avatar
Originally Posted by DR-Max
zack342,
I am a big fan of oem replacement parts but that maybe because I get them for cost due to a family member working for a Infiniti.
With the prices quoted above your looking at about $46.10 + shipping for all the parts.
With the aftermarket MOOG parts Nismo used you looking at $43.98+ tax for everything.
either way your going to spend about $50 its your choice weather you would like OEM or not. I think the MOOG setup looks excellent but for $3 more I would prefer the OEM setup.
NISMO can you post the part #'s for anyone interest in using the MOOG stuff?
Zack342 is offline
Old 05-30-2006, 12:32 PM
knight71's Avatar
check my post on page 1 for moog parts #'s.
knight71 is offline
Old 05-30-2006, 01:44 PM
Hahaha I noticed that and almost commented on it... but decided against it.
Old 05-30-2006, 02:18 PM
DR-Max's Avatar
Got a quote for the parts below from Pinnacle Nissan, $43 with tax. Shipping shouldn't be that much more.
DR-Max is offline
Quick Reply: Sway Bar End Link replacement How to. (pics)
