Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 05-23-2006, 03:15 PM   #1
Your friend list is empty
Kevlo911's Avatar
For those who want to change their steering rack
I bet over 75% of 4th gen owners have a leaking steering rack and/or worn tie rods...
I bought this rack
Click
I bought the 99se rack because it is stiffer. It comes with new inner tie rods and new o-rings.
You should replace the outer tie rods and sway bar bushings at the same time.
As for the how to.
Loosen lugs
Jack up and put the car on jack stands.
Remove wheels
Remove outer tie rods(I did not and paid for it ) - You need to rent the outer tie rod removal tool from AutoZone to do this.
Remove the bolt on top of the sway bar end link and the 2 bolts on the bracket that holds the "inner" bushing in.
Move the sway bar up and wiggle it out from the passenger side.
Remove the ypipe(rent the o2 removal tool)
As you can see, I forgot to rent the tool
Now the fun part. Crossmember. Remove the engine mount bolts, in the rear I used a long 10in extension to get to the bolt from the engine bay(intake removed). Front engine mount you need an open end wrench on one side and a socket on the other(or two sockets...) I supported the engine with a jack and a 2x4. If you have a tranny jack it would be better. Remove the 2 bolts in the front and rear(4total bolts) on the cross member and it will drop down. You can replace the mounts right now if you want too.
See a plate covering this mount on the rack. It is behind the rear header and is held on by three 10mm screws. Remove it.
Now remove the fluid lines, have something to catch the fluid(I had a trash can lid). Remove these from the engine bay, it is much easier that way.
Use a 14mm open end wrech to get the bottom one. On the top one, remove the hose and swap the nipple on the new rack once it is out of the car.
Remove those nuts. Now you will see the spindle, there is a 12mm nut holding it on the spindle of the rack. Make sure the steering wheel is strait before you remove it.
Remove the bolts holding on the rack now. One mount is pictured above, other you will see when you are down there.
USE THIS ALONG WITH MY TIPS TO CHANGE THE RACK
FSM is basicly the same write up too.
As you can tell I didn't do everything they did.
You will remove the rack from the middle, it will NOT slide out from the sides(I found out the hard way). You will move it towards the pass side and then drop it down in the middle. You will install it the same way. I also installed new bushing on the rack, I got MOOG bushings from rockauto.com
You will soon find out the spindle does not want to go into the joint. You will have to bang on top of the joint to get it on the spindle. I used my tq wrech and breaker bar to bang it in. I didnt have a rubber mallet(I did this with the rack mounts partially in, only the lower nuts were in). Rest is the reversal.
Next you get it aligned... I still have to do this, my wheel is cocked to the right.
This will take all day and would be much easier with air tools. But I saved about 800-1200bucks labor by doing myself and I now have a stiffer and better feeling steering system.
__________________
97 Pearl White Max GLE
191WHP and 201WTQ
Bi-Xenon retro for sale!!!
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 05-23-2006, 03:47 PM   #2
I assume that you also have to bleed the PS system once you are done, correct?
JeremysBlkMax97 is offline   Reply With Quote
Old 05-23-2006, 03:52 PM   #3
Kevlo911's Avatar
It's a self bleeding system. Just turn the wheel left to right about 100x times(less ) and keep filling to the COLD FULL level.
BTW I used Mobil1 ATF full synthetic. 1qt will be enough.
Old 05-23-2006, 04:08 PM   #4
Maintenance Monster
Dude, you ROCK. I have a low mileage 97 rack in my loft that needs to be installed, and I've been whimpering about it for weeks and putting it off. Maybe I should trade it for a '99. Knowing exactly what you did is very helpful.
Sadly, the thing I'm most concerned about is my y-pipe, which was removed once about 20k ago and it's now at 150k. I have new studs and nuts but I fear that my rack replacement will become an exhaust rust and stud extraction nightmare.
BTW, I fiddled with my front struts recently to change out axles, and my alignment was off as a result. I got it pretty darn close by lifting the front end and adjusting it manually. Start by setting the steering wheel to dead center and lifting the front end. Look down the face of each front wheel - mine pointed just near the center of the rear wheel since the suspension toes outward when it's not compressed by the weight of the car. I tweaked until they were pointing on nearly the same line, and lo and behold they came out to nearly zero toe angle when I put the front end back down. My steering wheel is very close to centered. It's not an alignment, but in 10min it's not too bad.
Oh, and nice tires. I have them on my RX-7 and man are they good for being street tires.
Dave
dgeesaman is offline   Reply With Quote
Old 05-23-2006, 04:16 PM   #5
SomePsychoGuy
SPiG's Avatar
Send a message via AIM to SPiG
Thanks Kevlo I am planning on doing this after Maxus.
SPiG is offline   Reply With Quote
Old 05-23-2006, 04:25 PM   #6
Kevlo911's Avatar
Quote:
I still need to replace the control arm bushings and the ball joints. If I go to Maxus I will let you drive it and feel the new steering. Dunno if I will have the bushings and balljoints done but I might have a secret power adder
__________________
191WHP and 201WTQ
Old 05-23-2006, 04:27 PM   #7
Droppin logs
D-Bo's Avatar
Send a message via Yahoo to D-Bo
Top notch write up as usual Kevlo!
D-Bo is offline   Reply With Quote
Old 05-23-2006, 05:41 PM   #8
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
Nice, is it worth it? Can you feel the difference? I am thinking of doing this mod also.
Zack342 is offline   Reply With Quote
Old 05-23-2006, 05:51 PM   #9
Send a message via AIM to BigLou93SE
Definately a good read and write up. Subscribing like whoa
__________________
1996 A32 SE 5MT \\ I/Y/E/AGX/CMS - 2.208/14.667@94.09
1990 S13 5MT \\ soon-to-be GT32 fed SOHC KA-T
BigLou93SE is offline   Reply With Quote
Old 05-23-2006, 05:51 PM   #10
SomePsychoGuy
SPiG's Avatar
That would be great Kevlo. Did you put a controller for the pressure like i30Krab? I assume it the electronically controlled one.
http://f.maxima.org/showthread.php?t=364766
I have all of the bushings already in ES or custom polyurethane, but I am going to do the ball joints and tie rods when I do the rack.
I wanted all of this done before Maxus, but I am waiting for parts and I don't want to go to Maxus broke or without my car if I couldn't get it back together. So my mystery mods will have to come later.
Old 05-23-2006, 06:30 PM   #11
aznsap's Avatar
Send a message via AIM to aznsap
sweet write up kevlo. i'm subscribing. for someone who only wants to do this when they have to, how do you know when you need a new steering rack?
__________________
FOR SALE (pics): 4g upper and lower IM, 4g IACV, white (qno) hood, '95 TCM, oem crank pulley and belts, auto gear select indicator and shift mechanism
aznsap is offline   Reply With Quote
Old 05-23-2006, 07:03 PM   #12
I like Maximas
Send a message via AIM to vipervadim
zack you already have a 99 steering rack
Kevlo great job as always, so you like the 99 steering rack too?
vipervadim is offline   Reply With Quote
Old 05-23-2006, 07:08 PM   #13
Zach95SE's Avatar
Send a message via AIM to Zach95SE
Could I do this in flip flops?
Zach95SE is offline   Reply With Quote
Old 05-23-2006, 07:26 PM   #14
matty's Avatar
Send a message via AIM to matty
So any feedback on the Feeling ???? You have to tell us how it feels !!!
-matt
matty is offline   Reply With Quote
Old 05-23-2006, 07:30 PM   #15
Zack342's Avatar
I know i was messing with them but no one noticed > nice work on your car by the way. Must be hot, i am going to suggest for your next mod 5speed conversion
Old 05-23-2006, 07:55 PM   #16
I like Maximas
next mod is already in progress - HID projectors, wait till you hear my hybrid projector setup..
Old 05-23-2006, 08:22 PM   #17
Kevlo911's Avatar
Feels 100x better. It is MUCH stiffer. Steering response is better too.
How do you know if you need a new one? Look to see if yours is leaking(Im positive most are) and is the wheel very loose? Mine was. This is much better. I just need to get alignment so I am all set.
Old 05-23-2006, 08:26 PM   #18
No longer a maxima owner.
kingrukus's Avatar
I am in for this. I know for a fact I have a leak somewhere in the PS assembly. So how much of a difference did you experience before/after this change?
__________________
Current:
G35 M6 Coupe
Previous:
5th gen Maxima SE 4AT
4th gen Maxima GXE 5MT
5th gen Civic CX 5MT
kingrukus is offline   Reply With Quote
Old 05-23-2006, 08:51 PM   #19
Kevlo911's Avatar
Mine used to be very loose and had about an inch play in the steering wheels left and right. In that "play" it would do nothing. That should not be there at all.
I used to be able to steer the car with my pinky haha.
Now it is stiff with no play. Has a more sporty feel to it, like most newer cars. It is not as stiff as our Madza6s but it is very close to our G35.
Old 05-23-2006, 09:08 PM   #20
Thinks he owns a sports car
Good writeup & pics.
Just to clarify the "stiffer" only applies to '95/96 (all) and '97-99 GLE/GXE's right? The '97 and later SE's all got the same smaller pinion's as the '99. That same part# you posted cross ref's against the 97/98 SE's too. I'm assuming the pinion comes with the rack just like the inner rods.
BEJAY1 is offline   Reply With Quote
Old 05-23-2006, 09:11 PM   #21
kingrukus's Avatar
How much did this run you in total? I know of a '97 SE parts car with about 60k miles on it that may be a doner for me.
Old 05-23-2006, 09:25 PM   #22
Kevlo911's Avatar
265+10bucks for new bushings.
20 for outer tie rods?
5 bucks for one qt of ATF.
Old 05-23-2006, 09:40 PM   #23
4th Gen Parts King
Maxima_Joe's Avatar
This is on my list when i put my 96 back together. It shouldn't be a problem though since it has no motor.
Maxima_Joe is offline   Reply With Quote
Old 05-24-2006, 06:03 AM   #24
Nissan maniaco conpulsif
hightuner's Avatar
Maybe you see my post too ,
i am planning on doing that for a little while .
Now every place i call and ask , they said 96 ans 99SE and not the same
i notice you have a 97 .
I really dont know if it the same ??
Also mine is not leaking just loose as hell , make the car impredictible
anyhow thnaks for witing this , i plan doing mine while a 3.5 swap
hightuner is offline   Reply With Quote
Old 05-24-2006, 06:24 AM   #25
Kevlo is just me or is it a typo when you say 800-1200 in labor???
Also my steering rack blew and whereever I parked I left a good deal of fluid on the ground. I got another rack off a the same car, a 99. The labor cost me $240 to replace the steering rack. The used rack itself was $100 from the junkyard. After they replaced it my steering felt heavy for like a week. After a week it went back to the same feeling as the old rack. Also after the rack was put in and my brake pads replaced, discs resurfaced my steering wheel doesn't vibrate when I have to do some hard braking at high speeds.
Brushedpewter is offline   Reply With Quote
Old 05-24-2006, 06:59 AM   #26
hightuner's Avatar
I was quote 1100 can
Also he used a rebuild ..
nice post , is 95-96 compatible whit 99SE ??
thats my question
Old 05-24-2006, 07:36 AM   #27
Kevlo911's Avatar
Naa i've read about these high quotes and I got some like that too.
$240 labor for all this work is amazing.
Old 05-24-2006, 07:48 AM   #28
Send a message via AIM to mforrest100
Quote:
To go thru this process, it might be better just to get a brand new remanufactured unit. Just to ensure longevity.
Ordered mine today. Figure I should get this out the way since I'm swapping engines out. I heard its easier than changing a tire when the engine is out.
mforrest100 is offline   Reply With Quote
Old 05-24-2006, 09:58 AM   #29
The dealer wanted $560. $240 is amazing but not when they bend some parts. They just bent something I wasn't using anyway so I got some weight reduction after this. They also didn't clean off the engine bay. I had to go to a gas station and spray some compressed air.
They put the old one(steering rack) in the trunk of my car. Any parts I should take off before I throw it away?
