New bulbs, fogs still don't work. What Gives?
Old 05-05-2006, 07:56 PM
bmxsteve's Avatar
My fog lights won't come on...does anyone have any ideas what I can check? The fog light fuse under the hood (in the fuse box by the battery) looks fine. Is there any other places where there are fuses for the fogs or any other ideas that may be causing them not to work?? Thanks, Steve
bmxsteve is offline
Old 05-05-2006, 08:33 PM
99grnmaxgxe's Avatar
Loose wires?
99grnmaxgxe is offline
Old 05-06-2006, 12:33 AM
drvefastho's Avatar
check ur fuses....if not then well yeah of course theres a fault in the circuit....some wire is gone
drvefastho is offline
Old 05-06-2006, 04:34 AM
4thgenx42's Avatar
Im having the same problem and I spent all afternoon yesterday trying to fix it. They were working about two weeks ago. I thought maybe the fuse just blew or something. Ive checked every fuse in the car and every relay, everything is good. Has anyone ever run into this problem? Advise please.
4thgenx42 is offline
Old 05-06-2006, 10:06 AM
FEELS GOOD TO BE GANGSTA
semaj3708's Avatar
Same problem when I bought the car. The owner/mechanic said he fixed them, only to go dead about 3 weeks later. He said he had to replace the bulbs. I spent on saturday checking fuses and relays, swapping, etc... no luck. Removed one foglight and tried tracing wires but did not find anything bare. Also I have done the foglight rewire, rechecked that work, OK. Any other ideas????
semaj3708 is offline
Old 05-06-2006, 10:23 AM
bmxsteve's Avatar
Well mine used to work, and for some reason one day they decided to go out, then come back on. And then after a few days, they would go out, and come back on again. Now, they never come on. Surely somebody has the answer???
bmxsteve is offline
Old 05-06-2006, 10:25 AM
MaximaDriver
WielkiWaac's Avatar
switch, relay did you gauys check all that stuff??
WielkiWaac is offline
Old 05-06-2006, 02:40 PM
konak85's Avatar
same problem hear. both fogs dont work for me.
konak85 is offline
Old 05-06-2006, 03:04 PM
Biggs_02's Avatar
sorry if i'm making a stupid comment but...did you check to see if the switch for the fog is on the "on" position?
Biggs_02 is offline
Old 05-06-2006, 03:16 PM
Digitized's Avatar
I had that problem it and was due to the light stark... inside the steering wheel colum where the fog light switch creates a contact to advise the car to turn the fogs on... must probably the contact has worn out.. well in my case it was... don't know if it helps...
Digitized is offline
Old 05-06-2006, 03:28 PM
Biggs_02's Avatar
well you should hear the switch go off in the fuse box when you turn the selector right? if you don't then it should be a switch/selector problem?
Biggs_02 is offline
The Frye
09-02-2021 11:03 AM
mvm062
11-30-2020 09:00 AM
captchaos
03-15-2016 12:18 PM
crazyespn
09-03-2015 01:30 PM
iflexsteel
09-02-2015 08:04 AM
Quick Reply: New bulbs, fogs still don't work. What Gives?
