Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 04-27-2006, 09:41 AM   #1
Send a message via AIM to 4genstock
Question about harmonic balancer
i Took my car in to get some belts replaced and the guy calls back and says the harmonic balancer needs to be replaced......i didnt tell him to check anything besides the belt thats why im skeptical. He says the cam shaft is wobbling a little.
For a little background on my car, some spoiled brat had it before and took terrible care of it and did no maintenance on it, i got it with 149,000 miles on it and it now has 170,000.
Let me know if the harmonic balancer going out is a common problem on 4th gens or if its even possible mine is going, and also how i could tell that its going.
thanks
__________________
Since 1995, Maxima has been known for its V6 engine superiority. The 2003 Maxima employs a 255-horsepower V6 engine, part of the VQ engine series that has been named one of the "10 Best Engines" by Ward's Auto World for eight consecutive years. Ward's editors have written that it is "simply the best V6 engine available in America."
GO VIRGINIA TECH HOKIES!!!!
4genstock is offline   Reply With Quote
Old 04-27-2006, 10:32 AM   #2
Wild for Width
Fr33way™'s Avatar
Points: 14,804, Level: 78
Points: 14,804, Level: 78 Points: 14,804, Level: 78 Points: 14,804, Level: 78
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
Send a message via AIM to Fr33way™
I think you are experiencing crankshaft runout.
There is no harmonic balancer, the crank pulley is one piece.
__________________
-----------'97 Q45 '96 SC300 - I owe my ability to wrench and internet to Maxima.org - AMD lifetime member.--------
Fr33way™ is offline   Reply With Quote
Old 04-27-2006, 11:02 AM   #3
Points: 8,570, Level: 62
Points: 8,570, Level: 62 Points: 8,570, Level: 62 Points: 8,570, Level: 62
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
I think what he means by the harmonic balancer is since the Maxima's pulley is in fact a 2-piece ( 2 rings held together with rubber)...
I had to replace my pulley since the 2 rings actually came apart while I was driving... lol
You can get an unorthodox Racing pulley which is a solid 1 piece instead..
ps. My "harmonic balancer"/Pulley went and the car only had 90 000KM on it..
Digitized is offline   Reply With Quote
Old 04-27-2006, 11:08 AM   #4
Wild for Width
Fr33way™'s Avatar
Activity: 1.1%
We DO NOT have a harmonic balancer.
Old 04-27-2006, 11:10 AM   #5
Wild for Width
Fr33way™'s Avatar
Activity: 1.1%
Quote:
That is true, I suppose what I meant was that is was just a pulley and not a HB.
__________________
Old 04-27-2006, 11:45 AM   #6
aight thanks guys, that should help me get to the bottom of this.
__________________
Old 01-16-2009, 08:55 PM   #7
Points: 4,740, Level: 43
Points: 4,740, Level: 43 Points: 4,740, Level: 43 Points: 4,740, Level: 43
Activity: 0%
I truely hate to revive an old thread however, I had a serious whine with a odd tapping sound coming from under the hood on the passenger side. I didn't notice a performance or fuel difficiency as a matter of fact the car drove fine with the exception of the annoyance. (Sounds similar to a bad belt and water pump combo)
So I pull into the stealership and had them check it out. Initially the mechanic said my belt wasn't the right size. Having known the previous and current owners OCD with upkeep and maintanance I knew that wasn't true so I asked if it was possible the belt had sheered from improper seating on the pully?
The mechanic takes it around back, roughly thirty minutes later the Service Manager comes around and informs me that my Harmonic Balancer was the source of the noise.
Looking at the previous post, I wonder why I am able to find a Harmonic Balancer if they are not equipted on the 95 models??
http://www.am-autoparts.com/AM/Harmo...-/AM-30145667/
For documentation purposes this occured around 209,000 miles on the original engine.
ShogunTX is offline   Reply With Quote
Old 01-16-2009, 09:32 PM   #8
The Dirty Pearl
pmohr's Avatar
Points: 22,440, Level: 93
Points: 22,440, Level: 93 Points: 22,440, Level: 93 Points: 22,440, Level: 93
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Where above did you read that only the '95s didn't have one? The crank pulley isn't a true 'harmonic balancer', really. Though that's up for much debate, much like the (proven untrue) '95 OBD-I myth.
Basically, all you need is a crank pulley. Nothing more, nothing less (assuming the issue was properly diagnosed). You'll want to do this sooner rather than later, as there have been many cases of these flying apart while driving.
If that happens you'll lose the alternator, and will have a limited driving distance until the battery dies.
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 01-17-2009, 08:20 AM   #9
Activity: 0%
Quote:
I suppose I should have said 4th Generation Maximas rather than 95 maximas.
So basically I could have just picked up a UDP and been done with it verses going with another stocker.
Old 01-17-2009, 11:24 AM   #10
The Dirty Pearl
pmohr's Avatar
Activity: 1.2%
[QUOTE=ShogunTX;6817461]
Where above did you read that only the '95s didn't have one? quote]
No point in getting a UDP, you won't notice big gains, if any at all. There have also been quality problems with UDPs either shattering, leaking, etc. I would just grab an OEM style crank pulley and be done with it.
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
