Introducing EGR back 00VI Swap.
Old 05-06-2010, 05:13 AM
OC_Nooby's Avatar
Hey
So when I did the 00VI like many others I blocked of the EGR on the upper intake manifold. I also blocked of the rear headers EGR tube. Do all I need to do to reintroduce the EGR is just connect the exhaust tube of the rear headers and have it go back in the intake?
Just trying to get them NOx's levels down for emission...Ohh I don't have the EGR guide tube so it will just be routed into my intake. Which is the same thing...Unless vacuum opens up inside the intake manifold to reroute exhaust at certain engine load/rpm?
OC_Nooby is offline
Old 05-06-2010, 06:12 AM
first to none's Avatar
when you do that swap do you still use the old y pipe or you use the the y pipe that came of that motor
first to none is offline
Old 05-06-2010, 12:48 PM
OC_Nooby's Avatar
err, well all you change is the top part (UIM) has nothing to do with your exhaust...
OC_Nooby is offline
Old 05-06-2010, 03:56 PM
OC_Nooby's Avatar
Anyone?
OC_Nooby is offline
Old 05-07-2010, 04:48 AM
OC_Nooby's Avatar
No one has ever had there EGR blocked off and then had to reinstall for an Emissions Test? I'm sure my method would work just wanted to be 110% sure as it would just be from the EGR guide tube on the headers to the intake after the throttle body...
OC_Nooby is offline
Old 05-07-2010, 02:20 PM
OC_Nooby's Avatar
boo...
OC_Nooby is offline
JRod28
12-29-2023 09:56 PM
Finkle
09-27-2015 09:53 PM
Justin Kroll
09-02-2015 11:06 AM
Maximeltman
08-31-2015 01:01 PM
skinnypimp
08-28-2015 11:45 AM
Quick Reply: Introducing EGR back 00VI Swap.
