Front Brakes
Front Brakes
Just noticed today that the front brake pads are wearing very slowly compared to rear brake pads. I've replaced the front brake pads about 3 years ago and was thinking I'm about due for replacement (have 50,000 miles on them). When i checked the rear brake pads which I replaced about 15,000 miles ago, they were already half worn down. Nissan brake pad front/rear. These are not abs brakes.
I'm thinking a proportional valve problem. Is this valve built in to the master cylinder?
I really don't think the calipers or parking brake cable is sticking. Last July, I replaced the calipers, new pins, hardware, pads, etc on both sides. Also ended up replacing the parking park cables. I have the parking brake cable adjusted very loosely. Cable moves freely. The rear wheels move freely no binding at all when jacking up the car. After a long drive, the calipers are not extremely hot. I've been through frozen calipers and binding parking brake cables before and the rear wheels are not displaying those symptoms. Just that the rear pads have lost over 50% wear since July. Thats why I ask about the master cylinder, seems to me the the car is using the rear brakes more than the fronts.
I hear almost all aftermarket pads are noisey. Most people I have talked to recommend nissan pads. Could the back pads be closer to the rotors then the front pads? Causing you to push the brakes harder to engage the front brakes? This is why I don't do my own brakes. I figure if I mess up on something in the engine the car won't go, if I mess up on the brakes it won't stop, which is a much scarier thing to me.
This is why I don't do my own brakes. I figure if I mess up on something in the engine the car won't go, if I mess up on the brakes it won't stop, which is a much scarier thing to me.[/QUOTE]
Hey, why pay someone to screw up your brakes, when you can do it yourself
The Dual Proportioning Valvle is seperate from the Master Cylinder. I was reading NFSM (Nissan Factory Shop Manual) and it recommends you bleed the brakes. The bleed pattern is Right Rear, Lef Front, Left Rear, Right Front. Just trying to give you other ideas than just the E-brake cable.
MAXSE5SPD
08-23-2015 12:06 PM
