Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 02-10-2006, 12:33 PM   #1
sook's Avatar
aftermarket fog: has install bolt in center, max has no hole. help?
Okay, I'm getting aftermarket fogs (don't want oem, want useful). The ones that I'm getting (Bosch Compact 100) have the install bolt in the center. There is no hole in the Max in which to place this bolt. What do I do about it? I don't think the light'll fit in the stock fog hole if the bolt hole isn't in the center. Am I going to have to dismantle the front of my car and drill a hole? If so, how would I do this, and how much time and effort am I looking at?
Thanks!
__________________
http://www.frappr.com/maximaorg4thgen
http://www.frappr.com/aznissans
sook is offline   Reply With Quote
Old 02-11-2006, 12:56 AM   #2
To take off the front bumper, it takes time and patients, due to some rusted bold and other things.
First open hood and take off center grill and headlights
Second there are three bolts near the center where your grill use to sit, and there are three bolts beneigth each headlight assembly, take those out to make easier for later.
Third remove the two front wheels(make easier) and remove the wheel-well cover,( you don't ahve to remove the whole thing, just the front part of it.
Forth there are three nuts on each side where the fender and the bumper connect, (one on top, one in mid, and one near bottom) BOTH SIDES
Last don't forget to remove the screws from below your car where the bumper is attached to the plastic guard.
Then just pull forward, might get caught here and there but nothing big.
I think I hit every point but its like 2am and I'm tired.
__________________
5SPEED swap finally done (3/30/07)
|Popcharger|5spd swap|AE headlights including corners|Kevlo911 STS|RAZO340|Cleared out tails|Ebay Fogs|Clear corners|H-tech on GR2s|Progress RSB|Warpspeed Y-pipe|FSTB|Custom Audi style LED headlights|Custom Catback exhaust|More to come|
Shift_Having fun
My cardomain site
darklegend06 is offline   Reply With Quote
Old 02-11-2006, 01:01 AM   #3
will fly for food
Maxima99SE's Avatar
Send a message via AIM to Maxima99SE Send a message via MSN to Maxima99SE Send a message via Yahoo to Maxima99SE
aftermarket fogs FTL.
but to each his own...
__________________
Maxima99SE is offline   Reply With Quote
Old 02-11-2006, 01:54 AM   #4
sook's Avatar
holy sht thats a lot more work than i was expecting.
there has GOT to be a better way to do that
Old 02-11-2006, 01:59 AM   #5
i dunno where you're trying ot install them, but what i did was cut out the plastic piece in the stock foglight hole cutout locations. stick your hand in there and feel up top. there should be if i remember correctly 2 or 3 mounting holes int he metal frame thingy. i think i went to home depot and got a 1/4" hex bolt [double check me on this] to hold it in place [length depends on your application]. worked well, but my fogs burned up on me, and too cold since to redo it. IMHO, go oem stock fogs. they look bada55 on our 99 bumpers.
__________________
I miss the maxima
kbmaxima is offline   Reply With Quote
Old 02-11-2006, 12:14 PM   #6
sook's Avatar
im trying to install them in the default location. i just have those little plastic bars across the holes. i looked up in there, and there is no hole in the center in which to mount the fogs. the ones im getting have a 4" diameter, and that is just about exactly the same size as the hole, so, centered it must be!
Old 02-11-2006, 03:40 PM   #7
§è~® f®ÈÄk
nismos14's Avatar
Send a message via AIM to nismos14
It shouldn't be hard if you remove the under gaurds and raise the car up on a lift or something then get under there with a drill.
nismos14 is offline   Reply With Quote
Old 02-12-2006, 07:39 PM   #8
sook's Avatar
how do i remove the under guards? would it be possible to mount the fogs to the "bottom" of the hole where the stock fogs go? install the fogs upsidedown, as it were?
Old 02-12-2006, 09:08 PM   #9
i don't understand why you wouldnt have stock mounting holes. we both have 99 gle's. you have to cut that small bar in teh foglight holes (i used a hacksaw and then a file to get it smooth) there should be mounting holes right up top, just like how i did my fogs.
__________________
I miss the maxima
Old 02-12-2006, 09:27 PM   #10
Spec V Sell Out
MaximaSE96's Avatar
Send a message via AIM to MaximaSE96
make some custom brakets usingf L shaped brakcets form a hardware store
__________________
I sold out and bought a Spec V...I miss my 4th Gen Maxima...
MaximaSE96 is offline   Reply With Quote
Old 02-13-2006, 01:23 AM   #11
sook's Avatar
yes, yes, i have the stock holes. i have the ones in the bumper, i have the ones in the metal that the fog mounts to. that aftermarket ones dont use two/four screws to mount on either side of a rectangle bracket. they use a single bolt that needs a hole in the middle.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
