Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 02-06-2006, 11:02 AM   #1
Axle seal leak
Hi - In November, I brought my 96 Maxima to a highly recommended local mechanic because my front suspension was making noises and it had a small oil leak. The oil was from the passenger side axle seal. The CV joints were cracked open.
The mechanic suggested we replace both axle seals and both CV axles, so I did.
The suspension noise went away, but there was still an oil leak. This time from the driver's side axle seal which did not leak before the repair.
In the past three months, we have replaced the driver's side seal six times and tried three more CV axles (all at no charge). There is still a small leak. We've tried parts from several suppliers including Nissan. The mechanic is out of ideas -- he has even "talked to his buddy at Nissan." He has offered me my money back for all driver's side repairs.
It is only a tiny leak now which I could live with, but I think this should be easy to fix. Any ideas?
dave
dave1812 is offline   Reply With Quote
Old 02-06-2006, 11:11 AM   #2
RaWr!!! ('''_(o_O)_''')
Vlasic's Avatar
Send a message via ICQ to Vlasic Send a message via AIM to Vlasic
Are you talking about the cv boots on the axle, or the axle seals on the transmission?
__________________
Quote:
Originally Posted by carnal_c30
thats because your car is a living barely driving parts car with more check engine lights than a nuclear power plant... if there were individual lights you'de have a christmas tree staring back at you!!!
Vlasic is offline   Reply With Quote
Old 02-06-2006, 11:19 AM   #3
Send a message via AIM to rome06
its probably the rubber seal that goes into the tranny on the drivers side axle.....mine was leaking too and it was a easy fix
rome06 is offline   Reply With Quote
Old 02-06-2006, 11:51 AM   #4
differential carrier bearings in the transmission assuming its a 5spd..
s0ber is offline   Reply With Quote
Old 02-06-2006, 12:19 PM   #5
Quote:
It is the axle seals on the transmission.
Old 02-06-2006, 01:22 PM   #6
Vlasic's Avatar
If it was leaking from the transmission then I dont know why you replaced the cv joints. If you replaced the axle seals and its still leaking, then you probably have a bad diff bearing like what s0ber said. Do you have a 5 speed? Get under the car and grab the axle right where it enters the transmission and try and move it up and down. If it moves then your diff bearing is bad. There should be no play in the axle where it meets the tranny.
Old 02-06-2006, 01:52 PM   #7
Thanks.
It is a 5 speed. The axle is rock solid - it doesn't move at all where it meets the transmission. The leak is clearly coming from the axle seal despite numereous attempts at replacing it. I can clean it all off and watch it leak.
Maybe I will have another mechanic look at it.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
