Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Sponsored by: FCP Import
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 01-28-2006, 09:53 PM   #1
tastey wheat
mendon99's Avatar
Points: 11,475, Level: 70
Points: 11,475, Level: 70 Points: 11,475, Level: 70 Points: 11,475, Level: 70
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to mendon99
squeaky struts
my struts squeak, any way to fix this? i tried spraying some lithium grease in there, it helped for about a week.. now the squeaking seems to be back .. i know this is because i didn't install strut boots when i put the struts in, but ill get some soon if theres a way to permanantly make the noise stop..
suggestions?
__________________
'03 G35 Sedan
I install alarms and remote starters, PM for more info.
mendon99 is offline   Reply With Quote
Old 01-29-2006, 01:27 AM   #2
Points: 8,012, Level: 60
Points: 8,012, Level: 60 Points: 8,012, Level: 60 Points: 8,012, Level: 60
Activity: 0%
Send a message via ICQ to ShRapNeR Send a message via AIM to ShRapNeR Send a message via MSN to ShRapNeR Send a message via Yahoo to ShRapNeR
did you change out the mounts too?
im getting squeeking.. but its b/c the strut shaft moves up and down a tad on my passenger side.. b/c i didn't change mounts
ShRapNeR is offline   Reply With Quote
Old 01-29-2006, 05:23 AM   #3
tastey wheat
mendon99's Avatar
Activity: 0%
hrmmm... im not sure, when i was jacking the car up, it squeaks every time push the jack, so i assumed it was the strut. sounded like it was coming from there too.
Old 01-29-2006, 07:29 AM   #4
Maintenance Monster
Points: 12,837, Level: 73
Points: 12,837, Level: 73 Points: 12,837, Level: 73 Points: 12,837, Level: 73
Activity: 0%
It's probably those rubber tubes that wrap around the coils at the top and bottom. I used that spiral plastic wiring wrap as a replacement, and it holding up pretty well after 3 years. I was able to lift the front end of the car, use a spring compressor to compress the middle of the spring tightly to give access to the ends, and install the wrap. That way I didn't have to take apart the strut and get an alignment.
Make sure the spring is properly seated and clocked when you're done, and avoid having your fingers in between the coils when it's got the compressor on. (If the compressor were to suddenly let go, you'd lose those fingers).
Dave
dgeesaman is offline   Reply With Quote
Old 01-30-2006, 04:23 PM   #5
look at your struts through your strut towers. If they are not centered you need new mounts. Mine were shot when I put in my new suspension. It took me 2 weeks of listening to that squeeking before I figured it out.looking at them to see if they are centered is the easiest way to find out.
texasluva is offline   Reply With Quote
Old 01-30-2006, 05:48 PM   #6
Maximoneypit
NCSU_MAX's Avatar
Points: 12,818, Level: 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Activity: 36.1%
Activity: 36.1% Activity: 36.1% Activity: 36.1%
Send a message via AIM to NCSU_MAX
I used silicone which got rid of the sound for a long time when i had my factory struts on. Not sure if it would work better than lithium grease or not tho.
__________________
SOLD: 98 VQ35 6spd
DD: 2004 White Diamond Pearl 6spd Acura TL
JDM Package: All weather floor mats, air freshener, aftermarket cup holders
Quote:
Originally Posted by cjandura View Post
All that leakage he got going on Crusher needs to wear depends and rubber pants or change his lifestyle
Quote:
Originally Posted by Conrad283 View Post
Damn O, you just got seriously pwnt
Quote:
Originally Posted by Kevlo911 View Post
word, i modded this thread with *****
Quote:
Originally Posted by MinervaMaxxxima View Post
If I had a dollar for every time I've thought Crusher has hit rock bottom....
NCSU_MAX is offline   Reply With Quote
Old 01-30-2006, 06:52 PM   #7
I Broke OT
86maxima96's Avatar
Points: 10,839, Level: 68
Points: 10,839, Level: 68 Points: 10,839, Level: 68 Points: 10,839, Level: 68
Activity: 0%
my rear right shock squeaks when i push down on the trunk. i think it's the mounts for me. did you change those when you installed them? what kind of struts are they?
86maxima96 is offline   Reply With Quote
Old 01-30-2006, 09:28 PM   #8
tastey wheat
mendon99's Avatar
Activity: 0%
Quote:
ok so look at the strut through the spring? or from the top in the engine bay?
they are GR2s. no, i did not replace the mounts, i hope thats all that it is, unless strut mounts are expensive...
the sound is bad sometimes when i take turns also, if that helps any.
thanks for the input fellas keep it coming
__________________
'03 G35 Sedan
Old 01-30-2006, 09:29 PM   #9
tastey wheat
mendon99's Avatar
Activity: 0%
NCSU, if it lasted a long time, its def better than lithium grease. the grease only lasted like a week or so..
Old 01-31-2006, 06:19 AM   #10
Maximoneypit
NCSU_MAX's Avatar
Activity: 36.1%
yea, my thoughts were maybe that he had applied his differently and if these two did have to same effect that maybe the difference in application was the solution
__________________
SOLD: 98 VQ35 6spd
Old 02-06-2006, 09:45 PM   #11
tastey wheat
mendon99's Avatar
Activity: 0%
bumping this, requesting more suspension info.
where can i get some OEM strut mounts? autozone good enough? or somewhere else?
the squeaking/rubbing sound happens more and loudest when im taking a turn, slowly.. anyone else agree its my strut mounts?, i didnt replace them when i put the GR2s on...
also, just in the rear, if i have any more than just me in the car, i bottom out big time.. would long-travel mounts (bens susp.) solve this problem?
thanks in advance.
Old 02-07-2006, 08:16 AM   #12
tastey wheat
mendon99's Avatar
Activity: 0%
bump, common guys i need some info here... taking the maxi on a road trip with some friends to Montreal soon, and this stuff needs to happen before then.
Old 02-07-2006, 09:03 AM   #13
If you brake and you get the squeek when the car leans forward you should buy new strut mounts. If not maybe you need bumpstops.
Not likely your car is going to fall apart because these are not new.
Armelius is offline   Reply With Quote
Old 02-07-2006, 09:31 AM   #14
tastey wheat
mendon99's Avatar
Activity: 0%
yeah, i think it does make the noise when i stop.. time to invest in some new strut mounts i guess. ill update later
Old 02-20-2010, 10:42 AM   #15
Points: 1,035, Level: 17
Points: 1,035, Level: 17 Points: 1,035, Level: 17 Points: 1,035, Level: 17
Activity: 0%
Strut Mounts
Hi there,
I just replaced the rear struts this week. Today I am installing new front struts. Replacing strut mounts and bellows as well.
I got all my gear from "The Parts Geek" http://www.partsgeek.com/
New Mounts are a must, especially if the old ones are 5 years older or more.
Unfortunately I still have the Squeek problem in the right rear strut, so it's not the strut or the mount and all the bolts are tightened to factory spec. Will let you know when I figure out the cause.
Good luck,
Maatrasa is offline   Reply With Quote
Old 02-20-2010, 03:16 PM   #16
Points: 14,066, Level: 77
Points: 14,066, Level: 77 Points: 14,066, Level: 77 Points: 14,066, Level: 77
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
^ I'm sure they figured it out over the 4 year period. They had to !!
__________________
Snypa is offline   Reply With Quote
Old 02-20-2010, 03:52 PM   #17
i just had struts and mounts installed on 2000 camry and now i get a sqweek from both when i turn the wheels !! What could be wrong ?
pbptjr is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
