JUST got alternator replaced, tested, battery tested, STILL SAME VOLTAGE!!! $*#(@)$*)
#47
Originally Posted by whitegold
Am I the only one who wishes he had thsi problem? I usually read about 12volts while charging.. I need a new battery.. and possibly a new alt
#48
Well when I first start it up bone cold.
SAFC II read 14.9-15.0
Radar reads 14.9-15.0
Just driving around normally no highway...
SAFC II reads 14.3-14.5
Driving on Highway...
SAFC II reads 14.7-14.8 sometimes 14.9
#51
How accurate is the multimeter that you are using? I'm an electronics guy and I know first hand that multimeters vary. And I wouldn't rely on your radar detector and safc to be dead on ***** accurate either as there main purposes is not to be a volt meter . Just my 0.02
#52
#53
This is garbage. I'm so mad. I just got the alternator replaced with a brand new OEM Nissan alty. The voltage from the original in my opinion was to high 14.8-15.0 when driving. I knew it had to have been the alternator since it was a reman'd. So I purchased an OEM one, put it in, and guess what? Voltage is STILL the same. So I got the battery tested, guess what? IT'S GOOD! So why can't I charge at 14.0-14.5 V???
#61
Did anyone consider consulting the FSM four years ago? There is a good flow chart on troubleshooting alternator/charging problems. It shows that unless the voltage exceeds 15.5VDC the voltage regulator located in the alternator and the alternator are fine.
I can't believe the OP was so worried about a 0.5V difference.
#62
ALT.S fuse
I had the exact same problem for a few months. I took the "monitor it and see approach". I first noticed that the voltage was too high when I checked it after changing the crankshaft pulley and the two serpentine belts. The voltage would usually stay between 14.8 and 15.2V, even at idle with very little load. I just came across this thread and the only person who got it right, at least in my case, was luedemann in his post on November 13th of 2010. I read how he changed the 7.5 amp ATL.S fuse in the fuse box by the battery under the hood and that fixed the problem for him. I went out and checked my 1996 Maxima and, yup, that fuse was blown. I didn't change anything but the fuse and it fixed it. Now it runs around 14.3V @1500 RPM. I think that the higher voltage DID do some damage to my battery though because even after a long drive, the battery voltage is only at 11 volts with the car shut off and it almost doesn't start if it is too cold out. Anyways... Thanks luedemann!!
JMag90
08-25-2015 09:17 AM
