Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-28-2005, 05:51 PM   #1
I30 Autodimming Mirror Installation Writeup
Hey folks, here's my writeup for installing an I30 autodimming mirror, complete with pictures. (In fact, I had to split this writeup into multiple posts because we're limited to 5 pics per post!) Feel free to leave comments or questions. I hope people find it helpful!
4th Gen Autodimming Mirror Installation Writeup
by FunLovinMaxima
Prologue:
I wrote these instructions because there isn't a heck of a lot of info out there about installing an autodimming mirror; there is a webpage with pictures of a mirror install on a 5th-gen which isn't particularly helpful to us 4th-geners, but there is a thread out there with some pinout information which is helpful, although it didn't help me.
The first step is to procure an autodimming mirror. I opted for a mirror from a '95 to '99 infiniti I30 because I knew it would look stock and fit the same mounting holes on the ceiling. Unfortunately, finding one of these mirrors is not as easy as you think: this mirror was an option on the I30s, so there aren't a heck of a lot of them out there. Of the mirrors out there, the majority seem to be beige but my interior is black. Also a critical note: before you buy a mirror, be sure it includes the plastic trim piece that covers the mounting holes! I don't know why, but most of the mirrors for sale don't include this piece. The local Infiniti dealer told me that they don't sell that piece individually, only as part of an expensive kit including the mirror.
Step 1: Test the Mirror
When your mirror arrives, before you even begin installing it, take a few minutes to test it out. The mirror has a four-pin harness. Looking at it head-on, it looks like this:
| 1 2 3 4 |
tab on the bottom
Here's what we're gonna do: Take two pieces of wire and strip their ends. Using the wires, connect pin 1 to the negative terminal of a 9v household battery. The 9v battery simulates the 12v electric system of our maximas. Connect pin 4 to the positive terminal. The light on the AUTO button should illuminate. Next, connect pin 2 to the negative and pin 3 to the positive. The lights behind the text AUTO and DAY should illuminate.
Let's discuss the four wires on the mirror.
The factory shop manuals for the i30 (i checked the manual for each year) say the following:
Black - This is ground.
Red/Yellow tracer - This taps into the Red/Yellow wire of the illumination control switch.
Green/Blue - This taps connects to Fuse #13, an ignition switched 12v.
Red/Blue tracer - This taps into the line between the Blue/Yellow wire of the illumination control switch and Fuse #18.
However, my mirror had different different colored wires! I don't know why. I deduced the following:
Black - This is ground. We're going to tie it into the Cigarette Lighter Ground.
Red/Silver tracer - This is the positive lead. We're going to tie it to the other Cigarette Lighter wire.
Blue/Silver tracer - This taps into the line between the Blue/Yellow wire of the illumination control switch and Fuse #18.
Green - This taps into the Red/Yellow wire of the illumination control switch.
In the following steps, we'll discuss how best to connect and run the wires around the cabin.
Step 2: Repair the Mirror (if necessary)
When I received my mirror, the swivel joint was extremely loose. I attempted to tighten it via the screw in the back, but when I removed the small rubber screw cover, the screw fell out! If this happens to you, here's how to fix it: First, with a screw driver, gently pry off the bezel around the mirror's glass, pushing in on the bottom to get away from the tabs.
Gently fold the glass down and check out the innards. You'll notice the ball joint that allows the mirror to swivel. Make sure there is a white plastic socket cover on top of it.
A small metal triangle-shaped piece is supposed to go over the white plastic socket cover and is held in place by the screw that fell out on me. Reseat the triangle piece and thread the screw back into it. See the arrow in the pic below for the screw location. It is this triangle-shaped plate that puts pressure on the white plastic cover to tighten the ball joint by means of that screw.
And with that, I fixed the mirror.
Step 3: Remove the Old Mirror
This part is easy. Using a screwdriver or the claw part of a small hammer, remove the cover of the mirror from the ceiling. Just insert the screwdriver or claw between the plastic cover and the ceiling and it should pop right off. Obviously, be careful not to scratch or crack anything. Once the cover is off, there are three philips-head screws to remove. Your mirror will get loose as you do this, so be careful not to let it fall!
FunLovinMaxima is offline   Reply With Quote
Old 12-28-2005, 05:54 PM   #2
Step 4: Exchange the Mirror Mounting Bracket and Clip
You'll notice that your old mirror has a white plastic mounting bracket attached to it and your autodimming mirror doesn't.
This white plastic mounting bracket is the part that mounts the mirror on the ceiling. It is attached to the mirror by way of a weird-shaped metal clip wedged around a big screw. First, detach it from the old mirror: take a big old screwdriver and pry out the metal clip. It will take a fair amount of force to do this, but it's not hard. Be careful not to damage the plastic mounting bracket while doing this and be sure to pry the thing away from your face because it will pop out with a LOT of force. When my clip came off, it went flying across the room. Now attach the mounting bracket to the new mirror. The easiest way to do this, I found, is to loosen the large screw on the mirror with a big old vice grip. It is just screwed in too tight to use a screwdriver. So after you loosen it up a bit, drop the plastic white mounting bracket on top and slide the metal clip over it. then you can use a screwdriver to tighten the screw. Make sure that the bracket is in the proper position, which you'll be able to tell by feel.
Step 5: Disconnect the Car Battery
This is probably a good time to disconnect your battery so you don't zap yourself. Loosen the negative terminal clamp and slide it off. Your electrical system is now dead, save for any transient juice left in any random capicators.
Step 6: Remove Interior Panels
Here's where the fun begins! I'm sure you'll want to a nice and clean install, so here's what you need to do: First, remove the driver's side plastic A-pillar cover. This is easy. Open the driver's door and pull out the weatherstripping from around the top of the windshield down to the side mirror area. Let that hang for a moment. Then, with a screwdriver, pry out the plastic pillar cover. There are a couple of interior clips that hold the thing to the metal pillar, but you don't have to worry about them. Just use a big screwdriver or two to pull the plastic down. You'll notice that there is a shrink-wrapped bunch of wires already running up the pillar. I assume that's for the HomeLink transmitter in my sunvisor. Be careful not to accidentally puncture it. Put your parking brake on. Pry up the plastic trim around the shifter and remove it. You'll need to disconnect the cigarette lighter harness and if you have an automatic like me, its easiest if you drop the shifter to N or D. Move it back to Park when you've gotten that trim piece off. Check the Haynes manual or Factory Shop Manual for extra help. Next, remove the lowest trim piece under the steering wheel area. There are two philips-head screws to remove to do this. Again, check the Haynes manual or FSM for extra help. On your dash, pop out the interior illumination control switch. Pry it out with a screwdriver along the side. To make the next step easier, pop out switch cover next to it, too.
Old 12-28-2005, 05:57 PM   #3
Step 7: Run the Wires
Alright, so you've gotten through the annoying stuff. Now on the fun part! To do this right, you'll need four runs of wire. I only had red and black 18 gauge on hand, so that's what i used. While you are running these wires, make sure you remember which is which. You might want to put labels on them in the A-pillar area so that when it is time to connect them to the mirror, you know what is what. Start by snaking a wire under the headliner through the hole where the mirror would be, down towards the window and then drag it across towards your A-pillar. You can easily keep it tucked under the headliner by the top of the windshield. Run it down the A-pillar and pass it through the space near the door.
You can snake it down through the dash and it can grab it in front of the fusebox. It might help to get down by the fusebox and look up through the dashboard to find your wire.
Keep the wire above the fusebox and run it under the dash, keeping it above all the various wiring harnesses and stuff under there. When you can, stuff the wire up towards the interior illumination control switch. You should be able to see your wire behind the switch, and with a claw-type extraction tool (or possibly a pair of long tweezers or something), grab the wire and pull it through towards you. Repeat this step, because two wires will connect to the interior illumination switch.
Be sure to leave a decent amount of slack in the wires you run.
Connect one wire to blue/yellow wire and the other to the red/yellow wire. You can use t-taps or whatever is easiest for you. I just inserted my wires into the back of the harness by gently prying open the tiny metal connectors inside it and then used a little bit of electrical tape to make sure nothing pulls loose.
The next two wires go to the cigarette lighter. Like before, run them from the mirror area, under the headliner, down the A-pillar, under the dash, above the fusebox, and towards the shifter. Again, keep them above all the wiring harnesses you find. Sneak the wires down alongside the bottom of the center console area and up through the shifter trim area you removed earlier. Connect one wire the +12 switched wire of the cig lighter (orange wire). Connect the other wire to the ground (black wire).
Again, you can tap into these wires however you like, but I just expanded the metal connectors inside the harness and inserted mine into those connectors, sealing the deal with electrical tape.
Old 12-28-2005, 06:00 PM   #4
Step 8: Mount and Connect the Mirror
Almost done. First off, cut off the wiring plug unless you have the mate to it, and be sure to leave as much of the original wires as possible. Carefully strip the four wires. Screw the mirror back into the ceiling (I bet it looks good already) and run your four wires around the notch on the top left side.
Trim and strip your four wires. Using four tiny twist-on wire connectors, attach your four wires to the mirror's four wires using the scheme described above. Make sure you have a good connection here, and carefully tuck your wires and connectors in.
Now go ahead and reconnect your battery, then take a deep breath.
Step 9: Test the Installation!
Now that everything is installed, here's how the mirror should behave. Start with the key out of the ignition, all lights off. Nothing on the mirror should be illuminated. Stick your key in and turn it to ON. The AUTO button should be illuminated (like your clock). If you push the DAY button, that should be illuminated instead. Now turn your headlights on. The text AUTO and DAY should both be illuminated. If you roll the Interior Illumination dial back and forth, the text should dim and brighten along with all your other interior lights. Finally, if you're doing this during the day, cover up the photosensor on the back of the mirror with your hand and after a few seconds the mirror should start dimming. If you're doing this at night, go out for a spin and enjoy! Clip the mirror trim piece on to cover your wiring, reattach all your other interior trim pieces, and congratulate yourself. Job well done!
__________________
1998 Pebble Beige Metallic Maxima SE / Bose / ABS / 140k miles (still in diapers )
Black Leather Trim Package / Security and Convenience Package / Deluxe Seating Package
K&N Panel Filter / ContiExtremeContact Rubbers / Alfa Otto FSTB / Alfa Otto DC Clears
'99 Ambient Temperature Mod / '02 Pathfinder Bose 6-Disc Changer
I30 Autodimming Mirror ( my write up )
Quote:
Old 12-28-2005, 11:37 PM   #5
Droppin logs
D-Bo's Avatar
Send a message via Yahoo to D-Bo
Nice write up! I am gonna keep an eye out for that mirror next time I hit the yard.
This would make a fine addition to the How To sticky...
__________________
D-Bo is offline   Reply With Quote
Old 12-29-2005, 07:58 PM   #6
Send a message via AIM to speed racer
So, when you drive at night does the auto dimmer detect glare and starts to dim? I read up on some information but there is not too much out there to explain what its functions are.
speed racer is offline   Reply With Quote
Old 12-29-2005, 08:45 PM   #7
Quote:
Yup, you've got it! It's got one sensor looking out the windshield and the other looking out the rear and if it detects a difference in light between them for a few seconds, it will dim.
Thanks for the props!
Old 12-29-2005, 10:35 PM   #8
maximariceboi's Avatar
Send a message via AIM to maximariceboi Send a message via Yahoo to maximariceboi
nice write up
__________________
cammed 4.5 gen | 04.5 350z track | www.teamalloutnissan.com
maximariceboi is offline   Reply With Quote
Old 12-29-2005, 11:16 PM   #9
Send a message via AIM to l3ftonm3
another one for the long list of things to do.
l3ftonm3 is offline   Reply With Quote
Old 12-30-2005, 02:34 PM   #10
Quote:
Originally Posted by maximariceboi
nice write up
thanks!
Quote:
yeah its totally worth it if you drive at night.
Old 01-01-2006, 11:11 AM   #11
wariow's Avatar
Send a message via AIM to wariow
great write-up, i really want to do this but would having 5% tint defeat the purpose of having an auto dimming mirror?
wariow is offline   Reply With Quote
Old 01-01-2006, 02:17 PM   #12
NLK
Id say it would defeat the purpose of driving at night.
NLK is offline   Reply With Quote
Old 07-21-2006, 12:49 PM   #13
is there any way I could have the pictrures that was in the write up? all red x now...
devast8 is offline   Reply With Quote
Old 07-21-2006, 05:37 PM   #14
Quote:
Yeah, this thread is kinda old. I have installed many aftermarket rear-view mirrors, including ones with temperature and compass. PM me, and I can help you.
MIXXMAX is offline   Reply With Quote
Old 07-22-2006, 06:56 AM   #15
Decal Specialist
erty67's Avatar
Send a message via AIM to erty67
where was this 2 years ago??? LOL! Nice write up.
erty67 is offline   Reply With Quote
Old 07-22-2006, 07:35 AM   #16
I just updated the location of the images to reference my new host. Hope you find this writeup helpful.
Quote:
Ha! Thanks man!
Old 07-22-2006, 11:51 AM   #17
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
I have one for sale if anyone is looking Awesome write up.
http://forums.maxima.org/showthread.php?t=477845
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Zack342 is offline   Reply With Quote
Old 10-26-2006, 09:25 AM   #18
Bad Mother Fornicator
DJ420's Avatar
Send a message via AIM to DJ420
Very good write-up, indeed! Thanks FunLovin Maxima.. very helpful! Thanks to Zack342 for the i30 mirror, too! Gonna go throw it in today!
DJ
__________________
Built. Powered. Dropped. Braced. Tinted. Luxury Performance. Entertainment Powerhouse.
SO MuCH MoRE!! Maxus09: 2nd Place Heavily Modified 4th Gen Maxima & Judge's Choice!!
You Can Check Me Out Right HERE! Check Out New England Modified HERE!
DJ420 is offline   Reply With Quote
Old 01-08-2007, 06:26 PM   #19
great write up
__________________
Quote:
Originally Posted by MacSima
at least its not a black on black maxima hataz
Quote:
Originally Posted by chazmcgee
**** my Grammar you english major tards
Quote:
Originally Posted by hiren_patel_83
The whole point of carbon fiber is not to paint it.
If he paints his carbon fiber, then it really wouldn't be carbon fiber.
shavedmax is offline   Reply With Quote
Old 01-08-2007, 08:28 PM   #20
and it works. I been using this for about 8 months. really helps out with these damn ricers we have in nyc with there HIDS.
Old 01-19-2007, 05:40 AM   #21
Quote:
Originally Posted by shavedmax
great write up
thanks man. i get PMs asking questions about this stuff all the time; i guess i'm the resident mirror guru.
i hear ya... HID-induced blindness is one of the real reasons i installed mine.
Old 01-19-2007, 05:35 PM   #22
:cough: should be a sticky :cough:
__________________
Old 03-13-2007, 07:24 PM   #23
Great Info.
__________________
2008 Corvette C6
2002 SE - Z rims, Clears FSTB - SOLD
2002 Q45 Sport -Totalled
2002 I35 Sport - Tokico Illumina's
1996 GLE Too many mods to list.
Kevin is offline   Reply With Quote
Old 03-17-2007, 05:17 PM   #24
Send a message via AIM to FormorAccordMan
I used this writeup and it was Perfect.
FormorAccordMan is offline   Reply With Quote
Old 03-18-2007, 07:17 AM   #25
Quote:
Originally Posted by Kevin
Great Info.
Quote:
Perfect? Wow, such a compliment. Thanks you guys!
Old 09-03-2007, 03:07 PM   #26
Send a message via AIM to SE Maxima Send a message via Yahoo to SE Maxima
done!!
thanks for the great write-up on this one!! i picked up an I30 mirror from Ebay for bout $50 and the install was exactly as you described. love the new mirror.
if i may add a couple tips for everyone else....
--i bought 40 feet of wire and it was the perfect amount. in the end there was only about a foot left over.
--18 or 20 gauge wire is a good size
--there's not a lot of room for large connectors overhead. i ended up cutting off the harness connector and using small end-to-end crimp still connectors which worked great.
happy driving all!!
__________________
350Z wheels & Bridgestone Potenzas, Porterfield R4-S pads, K&N Filter, FSTB, tint, diamond cut corners, low window washer fluid mod, gloss black brake calipers, Homelink visor, I30 auto-dimming mirror
SE Maxima is offline   Reply With Quote
Old 09-03-2007, 05:33 PM   #27
Licensed to Spell
ptatohed's Avatar
:o)
Good job funlovin. Thanks!
__________________
Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
1996 GLE, Pearl/Black - Superchargerless
1993 SHO, Pearl White/Gray - Stock
Super Charger install instructions
ptatohed is offline   Reply With Quote
Old 09-07-2007, 12:25 AM   #28
Good write up, will come in handy. just picked i30 mirror from junkyard. For some reason I thought maximas were prewired for the auto dim mirrors, I guess I was wrong.
nutty dredd is offline   Reply With Quote
Old 09-07-2007, 09:11 AM   #29
Quote:
i can tell you my '95 SE (no leather or auto climate) WAS pre-wired for Homelink but it definetly WAS NOT pre-wired for auto-dimming mirror. the installation wasn't too bad and it looks great.
__________________
Old 11-05-2007, 06:06 AM   #30
The map lights are 12V right? That is what the light bulbs say. Can I just tap into that? The I30 I pulled mine from looked to be wired that way.
__________________
Things I have replaced on my Maxima, Steering wheel, door panels, carpeting, roof panel/sun visors, 15" steel rims to 16" SE rims, I30 chrome door handles, I30 woodtrim, I30 auto mirror. Mods, AC electric outlet under passenger seat, USB cable to the ECU for laptop monitoring.
FS:door handles, switchs , lights, armrest
FS:I30 Tan leather seats
clh288 is offline   Reply With Quote
Old 11-05-2007, 03:10 PM   #31
[quote=clh288;6050316]The map lights are 12V right? That is what the light bulbs say. Can I just tap into that?QUOTE]
No. The only time you would have power to the mirror is when you map light was on.
__________________
"Your signature can not be longer than 500 characters."
1996 Maxima GLE...dark green/tan
2010 Maxima SV Premium...winter frost/cafe' latte
DO IT RIGHT....DO IT ONCE.
67whitegoat is offline   Reply With Quote
Old 11-05-2007, 08:39 PM   #32
[quote=67whitegoat;6051179]
oh thats true and if I wired it before the switch then it would always be powered even when the car was off. Well I already ran a wire down the A pillar and under the dash, Connecting it to the 12 volt cig lighter will have to wait till tomorrow. When you hit the day button does that just shut it off?
__________________
Old 11-06-2007, 09:22 PM   #33
^^^ Yea. The day button will keep it from dimming if you don't want it to. I powered mine through the parking lights, so it's only on with my lights anyway. But, if it's raining and I have my lights on I can disable the dimming with the day button.
__________________
Old 11-07-2007, 12:56 PM   #34
nice......def to go in stickies.
__________________
FOR SALE
97-99 Headlights $100 shipped obo
Snypa is offline   Reply With Quote
Old 03-04-2009, 11:14 PM   #35
I just did this! Its awesome, i love my new mirror, and i bought it for $10 gotta love that!
Here is the difference.
And here is the wiring, oh yeah
Thanks so much for the write-up, its wonderful!
SrgScott is offline   Reply With Quote
Old 03-05-2009, 03:18 PM   #36
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
I have 3 for sale in case someone wants one.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 13.88@101mph 60' 2.1 AUTO 210whp, 213wtq 3220 w/driver
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is online now   Reply With Quote
Old 03-05-2009, 08:20 PM   #37
khantalha+'s Avatar
Send a message via MSN to khantalha+ Send a message via Yahoo to khantalha+
i have a few for sale black and tan
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Driver/Grocery Getter) = sold
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha+ is offline   Reply With Quote
Old 06-23-2009, 01:45 AM   #38
Send a message via AIM to Mistertones
I remember reading in a threat that this wire is in some maximas. Can someone confirm it's in a 96 Maxims SE?
Mistertones is offline   Reply With Quote
Old 06-23-2009, 01:45 AM   #39
I remember reading in a thread that this wire is in some maximas. Can someone confirm it's in a 96 Maxims SE?
Old 06-23-2009, 07:53 AM   #40
The Golden One
IlyaK's Avatar
Quote:
It depends on the package in your car.
My 99 SE didn't have it, while some others did.
No one can answer this question except for you. Even if you don't have it, the wiring involved with this 'mod' is minimal.
Just do it.
IlyaK is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
