crankshaft position sensor leak(pics)
Old 12-03-2005, 06:01 PM
chillin014's Avatar
I have a leak in my timing chain cover (i think thats what it is) where the crankshaft position sensor is. people have told me to replace the washer in there but i dont really know where the washer is/how to replace it/where to get a new one.
wheres the washer? that thin ring within the sensor? how would i get that out?!
chillin014 is offline
Old 12-03-2005, 06:10 PM
JwaxMax99's Avatar
There's an O-ring, replace it. Dealer part. (Cam sensor) BTW
JwaxMax99 is offline
Old 12-03-2005, 06:13 PM
chillin014's Avatar
alright thanks but....where is it? so i know what im replacing.
does the dealership sell just the o-ring?
Old 12-03-2005, 07:56 PM
twiggy144's Avatar
If not sold separately by the dealer, you might find individual o-rings at any good hardware store, or at a plumbing supplies shop.
twiggy144 is offline
Old 12-03-2005, 11:06 PM
chillin014's Avatar
alright thanks. but how do i get that o-ring out? cut it? is that o-ring supposed to be sticking out a little past the surface of the sensor?
Old 12-04-2005, 01:11 AM
maxspeed96's Avatar
The O-ring is just rubber. So just pry it off with a flathead screwdriver. If the dealer doesnt have it, get one from any hardware store. An yes, it should stick out just a little, its a seal.
maxspeed96 is offline
Old 12-06-2005, 09:52 AM
chillin014's Avatar
thank you so much. now i've got to figure the correct size to get.
Old 12-06-2005, 10:38 AM
matty's Avatar
Bring the Part to the auto parts store and match up an O-Ring. (it does come off of that harness you know)
-matt
matty is offline
Old 12-06-2005, 02:51 PM
My other car is a Hybrid
Chunger's Avatar
Is it just me? I believe that there shouldn't be any oil in that area of the engine... That is equivalent to the plastic covers on honda that cover their timing belt. There shouldn't be any oil in there for a leak to even occur. (The sensor shouldn't have any oil on the inside IIRC)
Chunger is offline
Old 12-06-2005, 04:21 PM
chillin014's Avatar
Dude I hope your wrong, I just replaced the o-ring, I kinda had to push it in to the hole because the o ring stuck out a little more than the old one, which completely broke in half when I pryed on it with my screwdriver.
Also, my screwdriver stuck to that magnet on the end of the sensor, I hope nothing got messed up.
Old 12-06-2005, 05:01 PM
I'm actually quite pleasant until I'm awake
killcrap's Avatar
The vq30de is chain driven. and that chain needs lubracation. and also that a maxima is no honda. nor are they built the same. the camshaft position sensor is cylinder head. if there was no oil at the camshaft, wouldnt that be a problem?
killcrap is offline
Old 12-06-2005, 05:12 PM
killcrap's Avatar
the nissan part number for a new camshaft position sensor is 23731-38U12 about $60
killcrap is offline
Old 12-06-2005, 05:38 PM
chillin014's Avatar
thanks killcrap, i was thinking the same thing....wouldnt any moving part need lubrication...? i might replace the sensor, although it doesnt appear to be the same as the picture you gave me. for now i just replaced the o-ring i hope the leak does not continue.
sake1bs
09-19-2015 09:32 PM
iflexsteel
09-15-2015 03:37 AM
Maxboy23
08-21-2015 11:02 AM
Balkins
08-12-2015 06:39 AM
Quick Reply: crankshaft position sensor leak(pics)
