my 96 max has no spark
Old 11-23-2005, 09:10 AM
  #41
nismology's Avatar
Originally Posted by russt766
i got a new pump walbro pump....was running in the car before i blew the motor
Are you getting any intake backfires while cranking? I think the next steps should be getting a new fuel filter and verifying that the timing is on point with a timing light.
nismology is offline
Old 11-23-2005, 09:21 AM
  #42
kcryan's Avatar
Wow guys.seriously whats next? try banging on your windsheild? seriously some of the advice from a certain person has been beyond useless (no i dont mean killcrap)
anyway my only thoughts here are first, did u check all ur fuses, the under the hood ones too?
seccond check mass airflow sensor, alone it wont make the car not start but with all that other stuff it might
kcryan is offline
Old 11-23-2005, 09:56 AM
  #43
Do I get a tax break?
njmodi's Avatar
You talking about me
njmodi is offline
Old 11-23-2005, 09:57 AM
  #44
kcryan's Avatar
no sir.....keep guessing
kcryan is offline
Old 11-23-2005, 09:58 AM
  #45
njmodi's Avatar
Phew.
njmodi is offline
Old 11-23-2005, 10:01 AM
  #46
kcryan's Avatar
ok ill give a hint....it starts with a K ends with a X and has a ORMA in the middle, and its all followed by "97"
kcryan is offline
Old 11-25-2005, 12:42 PM
  #47
russt766's Avatar
k i changed my fuel filter and check all fuses...but it still dont start up....how can i check my fuel pump????
russt766 is offline
Old 11-25-2005, 01:23 PM
  #48
njmodi's Avatar
Put a fuel pressure gauge in line (with a T fitting) with the rubber hose on the outlet side of the fuel filter. Check for correct fuel pressure or any fuel pressure build up when cranking. I don't have the spec fuel pressure numbers handy...
njmodi is offline
Old 11-25-2005, 02:05 PM
  #49
nismology's Avatar
Fuel pressure should be at 43 PSI with the key in the on position with the motor off.
Old 11-25-2005, 02:29 PM
  #50
russt766's Avatar
what if i dont have a guage?? how can i check if my fuel pump is working??
russt766 is offline
Old 11-25-2005, 02:32 PM
  #51
njmodi's Avatar
You could try to pull the back seat out and listen for it
A fuel gauge will only cost you 20 bucks... given you car won't start and you've already spent so much time on it, why not at least arm yourself with the right equipment...
njmodi is offline
Old 11-25-2005, 06:22 PM
  #52
I'm actually quite pleasant until I'm awake
killcrap's Avatar
do a key cycle. and listen for the fuel pump to kick in. If the engine is freshly rebuilt, and it has had an oil change, i would pull the dipstick and smell the oil, You may have flooded the engine. If you smell a lot of fuel, do the following. if you dont smell a lot of fuel goto step 7 and 8
1)pull the fuel pump fuse, and disconnect the CAM sensor
2)crank the engine over a couple of times to clear the cylinder(open the throttle when your doing it)
3)change the oil
4)change the sparkplugs. get the copper ones. they retain the heat better than the platnums.
5)plug the fuse back in and plug the cam sensor back in
6)when you fire the car up next time, do a clear flood mode.
7)put your foot all the way down on the accelerator and crank the engine over.
8)if the engine fires get off the throttle
killcrap is offline
Old 11-26-2005, 10:35 AM
  #53
russt766's Avatar
i check the fuel pump...it has 2 clips....one clip has 4 wires and the other one has 2 wires....i was told to check the one with 2 wires and thats my power wires.....i have no power while the ignition is on....but the fuse is still good.....is there a relay that i should check if there is one?? what should i do next???
russt766 is offline
Old 11-26-2005, 11:22 AM
  #54
PAREDLINE's Avatar
Invest in a haynes manual. If you don't know basic mechanics its best to read up on it instead of asking a bunch of amateur enthusiasts incessant questions.
I will tell you one thing. Without the proper equipment you will go nowhere. A fuel pump could pump fuel at 5psi and it can pump at 25psi. You won't know without a gauge. So get your nikes on, ride the short bus to autozone, and get one. While you're there you can buy a manual and all your cam and crank sensors. You can bring them back if you don't use them.
You guys are the "bridge builders" of the future and you cant even figure out the easiest crap much less get along with each other.
We are doomed.
PAREDLINE is offline
04-16-2020 05:15 AM
Need help
23
10-02-2015 08:56 AM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: my 96 max has no spark
