Failed Smog (NOx), EGR Solenoid Prob
Old 11-12-2005, 07:56 PM
dmg
dmg's Avatar
My EGR Control solenoid is not getting enough juice to activate the solenoid (to open the EGR valve). Solenoid works fine when I apply direct power from battery, but the harness doesn't carry enough juice to activate it (it does read 12 volts, but doesn't have enough power to even run a test light). Looks like one lead goes to a power source, and the other one goes to the ECM.
Any ideas? Does the ECM just complete the ground in the circuit to activate? Sound like a bad connection or an ECM problem (or a sensor that the ECM uses to activate the solenoid circuit)? Any help is appreciated...this is a tricky one...
Thanks in advance !
Dave
dmg is offline
Old 11-15-2005, 03:54 PM
I'm nutty for Nissans
JSutter's Avatar
you should do a continuity test on the wires.
JSutter is offline
Old 11-15-2005, 05:22 PM
Mishmosh's Avatar
It's been a while, but I believe 12V is the default voltage feed. When the ECM drops that to 0V, the EGR system is activated.
Mishmosh is offline
Old 11-15-2005, 11:44 PM
greenmax95se's Avatar
i had same problem, make sure all your vacum hoses are connected right, mine were wrong and it fixed my problem and i pased emmissions the 2nd time
greenmax95se is offline
shilov
02-19-2024 09:40 PM
homeofbacon
09-23-2015 07:17 PM
JoshG
51
09-21-2015 10:41 PM
bumpypickle
09-19-2015 01:07 AM
Jay556
09-12-2015 05:50 PM
Quick Reply: Failed Smog (NOx), EGR Solenoid Prob
