Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 10-11-2005, 02:39 PM   #1
Points: 8,109, Level: 60
Points: 8,109, Level: 60 Points: 8,109, Level: 60 Points: 8,109, Level: 60
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
HELP: Car shuts off when I come to a stop
My car has been randomly shutting off. When I come to a full stop and then begin to accelerate the rpms drop and the car turns off. The only code I get is 05 05 which means no problem is recorded. I just replaced the ks but that didnt seem to help. I have also tried cleaning my TB, cleaning IACV, and changing pcv. None of this seemed to help. Please help.
cefiro a32 is offline   Reply With Quote
Old 10-11-2005, 03:53 PM   #2
NLK
Points: 5,772, Level: 49
Points: 5,772, Level: 49 Points: 5,772, Level: 49 Points: 5,772, Level: 49
Activity: 0%
Most likely a sensor problem, had a problem like this before. Ended up being the coolant temp. sensor
__________________
Member of Team Zenkai Hawaii
NLK is offline   Reply With Quote
Old 10-11-2005, 05:20 PM   #3
Points: 9,845, Level: 66
Points: 9,845, Level: 66 Points: 9,845, Level: 66 Points: 9,845, Level: 66
Activity: 0%
could try cleaning the egr valve, my buddy ran into a similar problem last week. all we did was clean his egr and his truck ran like a champ again.
__________________
06 Altima SE-R 6-spd | 97 Maxima SE 5-spd (Sold) | 97 Maxima SE Auto (Sold)
gto400no1 is offline   Reply With Quote
Old 10-11-2005, 05:32 PM   #4
Mass Air Flow could also be the problem. My Max was having your exact same problem several weeks ago. I changed the KS and MAF. Works much better, but I am currently experience lower than normal idling due to EGR valve.
95MaxTampa is offline   Reply With Quote
Old 10-11-2005, 07:01 PM   #5
I still miss the max
PTownMax's Avatar
Points: 7,427, Level: 57
Points: 7,427, Level: 57 Points: 7,427, Level: 57 Points: 7,427, Level: 57
Activity: 0%
Send a message via AIM to PTownMax Send a message via Yahoo to PTownMax
coolant temp sensor (there are two) the one that goes to ecu (believe it's the front one)
i've been there and had the exact same problem
__________________
the maxima is gone
PTownMax is offline   Reply With Quote
Old 10-11-2005, 07:38 PM   #6
Points: 11,772, Level: 71
Points: 11,772, Level: 71 Points: 11,772, Level: 71 Points: 11,772, Level: 71
Activity: 0%
Send a message via AIM to ImmaSquashYou
if you need to rev the car in order for it to keep on running, don't think its stupid, but do you have enough engine oil in yoru car? i believe the car has a safety switch that if its running on too lil oil, it would want to shut off. The coolant temp sensor controls how much coolant your engine is getting. if it is bad, you will be able to tell by the temp guage. If it is hot, that means its stuck closed, if its cold, that means its stuck open. This temp sensor i'm talking about is the one that is connected to the radiator not the one to the ecu.
ImmaSquashYou is offline   Reply With Quote
Old 10-11-2005, 08:44 PM   #7
Points: 7,915, Level: 59
Points: 7,915, Level: 59 Points: 7,915, Level: 59 Points: 7,915, Level: 59
Activity: 0%
YUP! I had the same problem also, and this is what it ended up fixing it...about $25 for the part and oh 5 minutes to change out...have the new one ready to go to minimize coolant loss. (You shouldn't lose more than a few ounces, if that).
NCSUpilot is offline   Reply With Quote
Old 10-11-2005, 09:19 PM   #8
Activity: 0%
Thanks alot everyone. Ill try changing the coolant temp sensor, and see if that does it.
Does anyone have a pic of the sensor?
Old 10-11-2005, 09:48 PM   #9
dot dot dot ...
NmexMAX's Avatar
Points: 47,506, Level: 100
Points: 47,506, Level: 100 Points: 47,506, Level: 100 Points: 47,506, Level: 100
Activity: 76.7%
Activity: 76.7% Activity: 76.7% Activity: 76.7%
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Wait for a code ...
__________________
03 SE 4AT 257whp/245wtq
95 SE 4AT 245k Miles
08 Pathy LE 5.6
Stuff for sale: 4" intake tubing/FastCat, HID bulbs, HID Fog Kit,front bearingshttp://forums.maxima.org/5th-generat...t-springs.html
NmexMAX is offline   Reply With Quote
Old 10-11-2005, 09:56 PM   #10
i had a similiar problem, but it was only once in a while stalling at stops and occaisional bogging down like it wanted to stall while driving constant speed.. i had ks sensor and coolant temp sensor codes, replaced and all is well. i only had a few trickles of coolant come out when i replaced mine. just make sure its cold
dabooki is offline   Reply With Quote
Old 10-12-2005, 10:32 PM   #11
Activity: 0%
Just changed the coolant temp this morning. I drove the car for about 10 miles without any problems.
__________________
97 I30
Place racing/JWT hybrid Intake (for sale) Make offer
Warpspeed ss y-pipe
Custom Mandrel cattback w/ Focuz exhaust
UDP
VB Mod
B&M Tranny cooler
upgraded torque converter
Rear sway bar
Front strut bar
KYB GR2
Old 10-12-2005, 10:44 PM   #12
NLK
Activity: 0%
Congrats! Hope thats the fix for it.
__________________
Old 10-12-2005, 10:49 PM   #13
Activity: 0%
Thanks NLK
__________________
97 I30
Warpspeed ss y-pipe
UDP
VB Mod
B&M Tranny cooler
Rear sway bar
Front strut bar
KYB GR2
Old 10-13-2005, 12:58 PM   #14
Activity: 0%
Car is shut off on me once again.
Old 10-13-2005, 01:36 PM   #15
do all the cheap, easy stuff first... f.i. cleaner, pcv, check for vac. leaks, sticking or poorly seating egr, maf plug connection, dirty maf screen (do not touch or spray wire inside !!!) dirty tb,
__________________
HATE IS WHAT DRIVES ME
THEJEFFERATOR is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
