Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 10-02-2005, 02:20 PM   #1
turbo
VSS code! Replaced VSS and still got the code...options?
Anyone know what could throw the VSS code in addition to it being messed up itself? I replaced mine and am still getting the code. Anything to do with cruise control maybe?
Old 10-02-2005, 06:31 PM   #2
Points: 6,179, Level: 51
Points: 6,179, Level: 51 Points: 6,179, Level: 51 Points: 6,179, Level: 51
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
I'm right there with ya. I posted a thread about this the other day and the consensus was that it was a bad speedometer.
http://forums.maxima.org/showthread.php?t=429615
NetFurie is offline   Reply With Quote
Old 10-05-2005, 10:32 PM   #3
Points: 4,617, Level: 43
Points: 4,617, Level: 43 Points: 4,617, Level: 43 Points: 4,617, Level: 43
Activity: 0%
Maybe this info may save some in unnecessarily replacing the speedo head. The speedo head contains circuitry which converts the ac signal of the VSS to a 0-10 Volt square wave and then routes it to the ECU. If your speedometor works, but your getting 0104, the ECU is not getting the square wave signal.
1995 Maxima 0104 VSS, DTC0504 A/T Control
Subject: 1995 Maxima DTC0504 A/T Control
Over the past year, I have had an intermittent CEL 0104 (vehicle speed
sensor), along with 0504 (a/t control) and 0304 (knock sensor). The
speed sensor checked out, plus my speedometer was functional. My guess
was that the signal path from the speedo head to the ECM was
intermittent. I was able to borrow a portable o-scope and monitor pin
29 (vehicle speed sensor) of the ECM. The signal during normal
operation was a 0-10V square wave where the freq would vary with
vehicle speed. A few times the signal would be stuck at 10V or 0V.
When this would happen, the CEL would trigger. I banged on the dash
near the speedometer and the square wave returned. I later took the
dash apart and cleaned the connections to the speedo head with contact
cleaner. I continued to monitor pin 29 and for about a month now the
signal has behaved normally and no CEL.
A few days ago I checked for non-CEL DTC's. I had both 0504 and 0304.
The FSM continutity test of the 5 wires to/from the ECM and A/T control
unit passed. The short to ground test also passed. The FSM is vague
on any more detail on the specific function of these 5 signal lines, so
although I could monitor them, I'm not sure what to look for.
I've also been monitoring pin 64 (knock sensor), it's voltage varies
from 2V to 3.3V. Is this normal operation for this sensor? I was
expecting the voltage to increase if I accelerated hard, but have not
yet noticed a consistent pattern.
Part of my impetus for checking for DTC's was that I noticed a slight
hard shift from 1st to 2nd.
Appreciate any helpful thoughts anyone might have.
I use premium gas, usually Shell 93. 159K miles. Maxima SE.
95MaxSE_White is offline   Reply With Quote
Old 10-06-2005, 04:35 AM   #4
I got the same problem. I accidently cleared it tho. It popped up along with my KS malfunction code.
PoKKi is offline   Reply With Quote
Old 10-06-2005, 03:15 PM   #5
turbo
Only way to know if the knock sensor is bad is to log your timing. It may be related to KS voltage output but logging the timing is much more understandable and easy.
I am going to try and tighten the screws on the speedo head unti as suggested in an alternate thread.
Frickin Nissans! haha
Old 10-06-2005, 07:11 PM   #6
Activity: 0%
Turbo,
On the back of the combination meter, there are 3 connectors. They plug into the meter assembly connecting to a flex pcb. It's the connection between the pcb copper and plug that is most likely causing your problem. Unplug them, clean both sides with contact cleaner and connect.
Thanks for the timing tip.
Old 10-07-2005, 04:48 AM   #7
turbo
No problem buddy, thank you too.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
