Transmission problems again, but different than before
Old 09-02-2005, 07:01 PM
motocross416's Avatar
I already had to replace my old 5spd tranny, now I have in a VLSD tranny, I have no idea of the milege on it. It has worked fine for the last 20K miles, goes into gear and drives good except all of a sudden its like 1st and 2nd gear are not there. Its sort of like how you can't go left beyond 1st and 2nd normally, but all of a sudden the barrier will be at 3rd and 4th. I can go through 3, 4, 5, R, but I can't get into 1 or 2. I have to start out in 3rd full throttle slipping the clutch and then when I slow down again, it will go into 1, 2 fine. This happens intermittantly and there doesn't seem to be any pattern to it doing this. I hope that made some sense, Any ideas as to what might be wrong?
One other thing that I've noticed recently is that when the car is in neutral and I let the clutch out, there is a grinding noise, but when I push in the clutch it goes away. Could this be related to my transmission problems?
motocross416 is offline
Old 09-03-2005, 12:26 PM
anyone know what might be wrong?
Old 09-03-2005, 12:49 PM
Old enuf to pick his own gears
d00df00d's Avatar
My instinct is that the problems are unrelated, although I can't tell you for sure.
Usually a noise that happens with the clutch in but not out is from worn input shaft bearings.
d00df00d is offline
sctludwig
09-01-2022 01:32 PM
03-12-2020 12:06 AM
boomerbrian
10-31-2018 10:25 AM
The Wizard
24
10-01-2015 08:47 PM
Quick Reply: Transmission problems again, but different than before
