how to replace front sway bar bushings
does anybody know how to do it?
how many bolts and where to take it apart?
and where can you get the ES endlinks? which ones?
Are the ES endlinks any good or should I get Nissan?
He's talking about the sway bar bushings, not the endlinks. There are 2 of them, one for each side of the sway bar. They're REALLY easy to replace. Each mount has 2 bolts. Undo the bolts to the mounts, take them off along with the bushings. Grease the inside of each bushing and put them on the sway bar (after removing rust and whatever crap may be on there) then put the mounts back over them and tighten. DONE! Don't get me started on the control arm bushings though....THOSE are a pain in the a$$
OEM's don't give you rough and harsh ride, but the handling is just as good as the ES bushings.
those are easy and cheap to replace , so i don't mind throwing new bushings on there every 20K
Nick.
Nick.
Cheaper than Courtesy: http://www.suspension.com/nissancars.htm (half way down)
Thanks. I just ordered the sway bar bushing set (2 bushing + 4 grommets) total $11 plus $2 shipping from www.suspension.com.
kingw323
20
10-21-2015 08:36 AM
