Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-22-2005, 11:28 AM   #1
Need help for fixing starting engine hard
Hi, guys,
I have a trouble with my maxima now.
It need to crank for a long time to get started every time and sometimes I need to try several times.
I have it checked today and got some error codes, they are P1335, P0340 and P0325. Thay are about camshift position, crankshift position and knock sensors.
The mechanic said he need more time to figure out what's causing this problem and he already charged me $80. That makes me very annoyed and I decided to drive back home first.
Does anyone here can help me out?
Thanks a lot!
sampdoria is offline   Reply With Quote
Old 08-22-2005, 11:55 AM   #2
Send a message via AIM to MDeezy
Repair the codes and you'll be back to normal, those sensors are responsible for a smooth start up. Change them reset the ecu and you should be fine.
__________________
Quote:
Originally Posted by CMax03 View Post
Where are the moderators???? This guy should have been banned after his first reply when he first joined this forum! I'm totally in awe with his behavior and ruthless antics on someone else's thread!!!!! I believe he's broken every rule at least twice...????????
Beware the Deezy
MDeezy is offline   Reply With Quote
Old 08-22-2005, 11:57 AM   #3
Do I get a tax break?
to what MDeezy said... replace the camshaft position and crankshaft sensors, reset the ECU and drive
Check for codes again in a few days to see if the knock sensor (0325) reposts.. if it does, then you need a new KS.
__________________
96 Max GLE.
Mods: Carseat in the back, stroller in the trunk
njmodi is offline   Reply With Quote
Old 08-22-2005, 12:01 PM   #4
that is the same thing i'm going threw now. i changed the crankshaft sensor and it starts alittle better but it might be another sensor. still checking
__________________
aa one and a two and a 7200
two pull's then pass to the left
you know your a ricer when you go to the speed shop to get gauges that monitor tire pressure.
laylow1988 is offline   Reply With Quote
Old 08-22-2005, 02:39 PM   #5
thanx, guys.
do i need have those sensors replaced or it's just a problem of connections/wires? How much should it cost? I want to know more before I go to any garage.
BTW, who can recommend a good garage in columbus, oh?
Old 08-22-2005, 03:31 PM   #6
dont know how much they cost, but buy new sensors and your problem should be fixed.
__________________
Beware the Deezy
Old 08-24-2005, 07:57 AM   #7
thanx, guys.
just got it fixed at the dealer's after replacing the cam and crank sensors.
yet i still donno why those sensors were bad. seems like it happened after my drive belts were broken and replaced.
Old 08-24-2005, 08:11 AM   #8
Quote:
Originally Posted by sampdoria
thanx, guys.
so you changed the cam and crank sensors at the dealer and your car is fine now? i changed my crank but now i gues its time to check or change the cam sensor too.
Old 08-24-2005, 08:20 AM   #9
I'm actually quite pleasant until I'm awake
killcrap's Avatar
get an ohm meter and ohm out the sensors. and compare to oem specs. i think its at 68 degrees. do not just replace the parts. check them first. if they are in spec, check MAF sensor and TPS sensor as well. dont overlook ECT either.
killcrap is offline   Reply With Quote
Old 08-24-2005, 11:21 AM   #10
Quote:
yes, the dealer said if the sensors were replaced, everything will be fine, so i let them do it and the problem is gone. i am still not sure if those sensors are really bad or just the connections or other thing related were bad.
in your case, did you get the error code for cam sensor too? if yes, maybe you can try to replace the cam sensor.
Old 08-24-2005, 11:52 AM   #11
Send a message via AIM to Turk
If you replaced, the starter, most of the sensors, and still have hard time starting up, its you timing chain that advanced, mine had the same problem.
Turk is offline   Reply With Quote
Old 08-24-2005, 12:04 PM   #12
how much did it cost to get it fixed at the stealership?
SoLid97SE is offline   Reply With Quote
Old 08-24-2005, 12:18 PM   #13
Quote:
around $350, including diagnosis
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
