Sap Sucks...
Old 08-18-2005, 01:14 PM
InsneDrmr's Avatar
Sap Sucks...
My ex-girlfriend parked her car (ugly a$$ Jetta) under a tree that apparently dripped sap on her hood. She let it sit on there for a few weeks and now shes trying to get it off. I tried using Goo Gone, and Bug and Tar remover, and it is helping slightly...but does anyone have any ideas? If nothing works, oh well its not my car...but if it does....well lets just say brownie points!
InsneDrmr is offline
Old 08-18-2005, 01:18 PM
emmas97's Avatar
can you try wetsanding very lightly (like 2000 grit) and then if you know someone or know how, have them buff over the spot.... thats what i had to do to get the pollen off my entire car....
emmas97 is offline
Old 08-18-2005, 01:31 PM
AxisKill's Avatar
wash the car and then try claybar... but if she's your "ex-girlfriend" i don't see why you'd go through all the trouble
AxisKill is offline
Old 08-18-2005, 01:35 PM
InsneDrmr's Avatar
no trouble at all...i tried 2 things...actually i recommended 2 things...she did the work. But if it comes off...that means ill be having a good night, if you catch my drift.
Old 08-18-2005, 01:39 PM
packetscan's Avatar
The sap has dried an hardened..
I had this before.. although didn't let it sit that long.
I brought it to one of those self serv car washes and it turns out the Wax setting was HOT water.. it started to melt off after a few minutes..
Maybe a total of 10 minutes..
packetscan is offline
Old 08-18-2005, 01:54 PM
nismology's Avatar
Haha...
nismology is offline
Old 08-18-2005, 02:25 PM
Chief Brody's Avatar
I soaked some goo gone on a paper towl and let it fester in for a few hours. I was then able to scape it off in one big chunk.
Chief Brody is offline
Old 08-18-2005, 03:05 PM
Project Ruby......
4DRSpeed's Avatar
I believe windshield washer fluid works, or so I have a read.
4DRSpeed is offline
Old 08-18-2005, 03:28 PM
BossMoney's Avatar
clay bar...then mothers carnauba cleaner wax...it will come right off and leave ur finish looking and feelinglike glass...
BossMoney is offline
Old 08-19-2005, 11:55 AM
Norm_Nav's Avatar
I don't know from claybar, But you might try peanut butter...not chunky and the brand doesn't matter. use it like a buffing compound,,y'know just on a damp cloth (not bread). It works in the house according to heloise,,so why not on a Jetta.
Norm_Nav is offline
Old 08-19-2005, 12:35 PM
NismoGTR's Avatar
they sell sap remover.....where i dont know my dad owns a detail shop and he gets it from a guy who come in a truck which has supplies on.....if its really bad this is a good ideal since its been sitting a while....only issue with the one we have its so strong it leaves a bit of a fade look as if it went through the clear...depends how much u use sometime it doest leave a mark.....the mark it leaves is better than the Sap
NismoGTR is offline
Old 08-19-2005, 01:36 PM
ImmaSquashYou's Avatar
since you should have clear coat on there, get comse scratche remover, use a exacto blade n start to chip it off, making sure that you're going sideways. make sure that its hardened. n then you shuold be able to "crack it" justl ike freezing gum n then peeling it off sorta deal
ImmaSquashYou is offline
Old 08-19-2005, 01:42 PM
rsly33's Avatar
Try bug and tar remover, claybar and then polish. Its probably etched into the paint by now so stuff like goo gone isnt going to work. And wax is not going to do anything to it, even if it is cleaner wax. Wax doesnt do anything to remove stuff from your paint.
rsly33 is offline
Old 08-19-2005, 02:22 PM
Dan
No Longer Owns a Maxima
Dan's Avatar
why isn't this in the detailing section? Try hot water, with whatever suggestions mentioned above.
Dan is offline
Old 08-19-2005, 02:54 PM
njmaxseltd's Avatar
We use brake cleaner at the shop. Takes it right off and does not hurt the paint. Just polish and wax the area when your done.
njmaxseltd is offline
Old 08-19-2005, 03:32 PM
YoKramer's Avatar
Your joking right???
Hot Hot water soak will help first. Then try the goo gone again.
YoKramer is offline
Old 08-19-2005, 03:43 PM
PAREDLINE's Avatar
Use brake fluid. no dont. Dont use brake cleaner either. Or sandpaper.
I'll give you the best stuff to use. Rubbing Alcohol. Make sure its not 50% isopropyl alcohol but 100% isopropyl alcohol.
You can park in a nice hot spot. Get the stuff soft. Then move it into the shade and let a rag with alcohol sit on it for a few seconds. You'll be able to start to rub it off. With a few spritzes of alcohol on a rag it will come off cleanly.
PAREDLINE is offline
Old 08-19-2005, 04:06 PM
njmaxseltd's Avatar
No I'm not joking, you'd be very suprised at what 3M brake cleaner takes off your cars paint, without harming the finish at all. Try it yourself and you'll see what I'm talking about.
Old 08-19-2005, 04:10 PM
PAREDLINE's Avatar
Wait a few months. I bet those spots you sprayed begin to fade as the clear coat beneath starts to discolor and flake.
Old 08-19-2005, 05:10 PM
YoKramer's Avatar
Ive seen some brake cleaners take off clear right away
YoKramer is offline
Old 08-19-2005, 06:16 PM
unkadave11's Avatar
I have uses a general purpose cleaner called purple power at full power, similar to simple green, to clean sap and tar off small areas and haven't had any problems with the clear coat or fading.
unkadave11 is offline
Old 08-19-2005, 08:35 PM
rsly33's Avatar
You must mean youve seen brake FLUID eat away the paint, brake CLEANER wont and is fine on your paint.
rsly33 is offline
Old 08-20-2005, 06:21 AM
4thgenx42's Avatar
A couple of my friends had the same problem. One used a claybar and the other buffed it out. They both worked....
4thgenx42 is offline
Old 08-20-2005, 11:55 AM
njmaxseltd's Avatar
Thank you...
Old 08-20-2005, 12:29 PM
brotherhood of tq
liqidvenom's Avatar
i had the same thing happen to me and i used goo-gone and a plastic card to gently scrape it off. but then agai tom is a detailer so i say u do what he says
liqidvenom is offline
topdog1207
Detailing
04-27-2005 09:06 PM
mjg
07-27-2003 11:31 AM
Momaxima
05-13-2003 02:59 PM
Chance
05-15-2002 03:13 PM
Wreck-Diver
06-01-2001 09:58 PM
Quick Reply: Sap Sucks...
