Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-18-2005, 09:46 AM   #1
Power Steering Belt Nearly Impossible To Remove
I loosened everything to include that large 15mm nut on the back of the power steering pump. Didn't take it off. Nor did I take off the other two that you are suppose to loosen.
Am I missing something? That belt just doesn't want to come off or do I have to remove those nuts?
In the meantime I just said screw it and place a new main drive belt on. If the power steering belt breaks I always have the replacement but that belt looks good compared to the main drive belt which was missing a small area out of it (about three teeth if that is what they are called after they crack).
Any advice on replacing that power steering pump belt?
http://www.greghome.com/images/Maxim...DriveBelts.jpg
The main drive belt took about 10 minutes to remove and replace, while that ps belt I worked on for over two hours and it has got me beat.
Armelius is offline   Reply With Quote
Old 08-18-2005, 10:11 AM   #2
Do I get a tax break?
Did you undo that bolt on the power-steering belt pulley - as shown in the second picture, top row, in the link you provided?
You have to loosen that locking bolt first then then tighten the other bolt shown - that will relieve the tension in the PS belt.
__________________
96 Max GLE.
Mods: Carseat in the back, stroller in the trunk
njmodi is offline   Reply With Quote
Old 08-18-2005, 10:22 AM   #3
I loosened all three. Didn't tighten any.
The top and bottom on the second pic I only unloosened and didn't take any off.
__________________
signature deleted. not appropriate.
Old 08-18-2005, 10:23 AM   #4
Points: 10,648, Level: 68
Points: 10,648, Level: 68 Points: 10,648, Level: 68 Points: 10,648, Level: 68
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
Your supposed to tighten the tensionor, it works backwards, tighten to loosen the belt.
__________________
SouthFloridaMaximas.Com
s0ber is offline   Reply With Quote
Old 08-18-2005, 10:26 AM   #5
Quote:
Exactly - you have to tighten the bolt, that will loosen the belt. (The lowest bolt, in the 2nd pic). You have to loosen the upper bolt in the second pic first.
Old 08-18-2005, 10:41 AM   #6
Alright. Very difficult to mess with that back bolt. The top nut I had to use a breaker bar.
Luckily the belt doesn't look like it needs to be replaced and I just ran out of time to be messing with it.
Thanks for your help though. When it does start to go I am sure I could replace it within about an hours time.
I had heard that the dealership charges 130 plus or 300 dollars to replace these belts. Don't know how true that is but I would much rather have some air tools to get that back bolt.
__________________
Old 08-18-2005, 11:24 AM   #7
just cut the belt off and that usually helps loosening the tencioner
f550maranello2 is offline   Reply With Quote
Old 08-18-2005, 11:51 AM   #8
Points: 5,645, Level: 48
Points: 5,645, Level: 48 Points: 5,645, Level: 48 Points: 5,645, Level: 48
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to Chief Brody
Armelius, where did you get your replacement drive belt? Is this one those parts that you recommend getting from the dealer or can you just go to autozone and get a replacement that fits? What do you guys think?
__________________
Chief Brody is offline   Reply With Quote
Old 08-18-2005, 11:52 AM   #9
You can get them anywhere, BUT, the OEM ones are so cheap, (25 bucks for both), I just used the OEM parts.
__________________
96 Max GLE.
Old 08-18-2005, 12:04 PM   #10
Quote:
If you end up not being able to get the tensioner loose, you are screwed if you've already cut the belt... ... I wouldn't recommend this method to anyone who isn't "sure" of being able to do it successfully.... i.e. anyone doing it for the first time.
Old 08-18-2005, 12:56 PM   #11
Dealer. One is made in Japan and the other is made in the US. I would recommend getting the drive belt from the dealer the power steering could be bought at discount auto or something. But with the dealer you know you are getting an exact fit.
I paid just under 60 dollars for both. I am going to call the dealer up to see how much they charge to change both to see what my savings should be.
Ten minute job for that drive belt though.
__________________
Old 08-18-2005, 01:04 PM   #12
Just got off the phone. They charge 129 plus tax to change two belts that's including labor so I assume it takes them an hour to change them.
__________________
Old 08-18-2005, 03:59 PM   #13
Activity: 0%
Nice man. Good to see that is a quick job.
__________________
Old 08-18-2005, 05:46 PM   #14
That drive belt lasted over 100,000 miles
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
