Changing Rear Brake Pads?
haynes manual has it in there, you goto autozone and buy the caliper tool that plugs into your ratchet. ou remove the two bolts on top, i think theyre 16 or 17mm, remove the part from the rotor and rest it on osmething.
you turn the tool so that the caliper is in then you place the pads in there and adjust the caliper accordingly.
www.motorvate.ca its on there it hink
DO NOT attempt to turn the caliper with a pair of pliers, you will just wind up busting your knuckles and getting extremely frustrated as I did. You need the tool. Other than that, its pretty easy.
Originally Posted by passEMonTHErite
I love how people say "just turn the caliper" like its easy or something. The rear caliper does not just simply push in like the fronts. It needs to be twisted CLOCKWISE. In order to do this you need a special tool. Just go to Autozone and ask for the rear disc brake caliper tool which they will loan out to you. It will still be relatively difficult but will eventually turn with enough elbow grease.
Huttig2009
09-25-2015 03:31 PM
RealityCheck
08-05-2015 06:18 AM
