HIGHEST output (wattage) BULBS
Old 05-23-2001, 02:18 PM
Naughty
Question- What is the Highest Output (wattage) bulb out there for the Maxima's(Headlights). Anything better then the Piaa's ?
-Thanks
Old 05-23-2001, 03:25 PM
Master Will
metallic97gxe's Avatar
I have seen some 130/100W anything higher than the stock 45-65 and you WILL need the APC upgraded wire harness unless you have it already...how bright do you want???............ get a spotlight.....
metallic97gxe is offline
Old 05-23-2001, 10:30 PM
Naughty
Well i thought the higher the wattage---> higher the temp---> making it closer to the H.I.D look. Maybe?
Old 05-23-2001, 10:43 PM
emax02's Avatar
All 4 of my lights are only 35 watts each and blind the hell out everyone But I can see everything! It's much easier to avoid all the damn frogs in my neck of the woods.='s Splat!
emax02 is offline
Old 05-24-2001, 05:08 AM
DFWmax's Avatar
higher wattage doesnt mean higher color temp (i believe that is what you are referring to). the 85w, or even the 100w bulb will still be the same yellow as the stock 55w bulb. the increase in wattage will give you more light, and more heat, but will not significantly change the "color" of the light (it might look whiter, but that is only because it is brighter, not whiter).
i put in catz zeta, and what it does it change the input voltage going to the lights, from 12v (i measured and got 12.7 before) to 14.4v. sending 14v thru the same bulb that normally runs at 12v will make the light brighter and a little whiter. but it was not a cheap upgrade ($200). i wouldnt compare it to a true HID, but i would say it was brighter and whiter than stock. oh, and im running them with piaa superwhites (55w).
dfwmax
DFWmax is offline
Old 05-24-2001, 09:17 AM
Naughty
dfwmax
So then what kind of a bulb would you guys rec. to go with the Piaa's H3 (Xtreme whites)? cuz right now i have the piaa 9004 and they dont match at all!
doctorpullit
03-29-2016 11:08 AM
mpbclutch33
12-26-2015 11:11 AM
knight_yyz
11-01-2015 01:34 PM
Noela
09-26-2015 08:22 AM
Quick Reply: HIGHEST output (wattage) BULBS
