Need Help!!! Car Wont Start!
I have full power lights, horn,radio,...etc. Car cranks...but wont turn over. I tried pumping the gas a couple times. Still nothing. Any ideas could it be electrical?...I have no clue what it could be.
Well i just changed the starter about 4 months ago, so I dont think thats the problem. As far as cranking...When I turn the key it sounds like it wants to start right up..but it doesnt. I can hold it in the cranking position and the car just wont start. When my starter was going bad, I didnt get anything at all. No sound what so ever. A couple of clicks and then nothing.
So it sounds like the car is turning over, but not catching. This can now be an air, fuel or spark issue.
1. Check all the fuses - perhaps your fuel pump is dead or fuse is blown.
2. you can buy some starting fluid and spray it into the intake to see if that works - that would help you identify if there is fuel being delivered or not.
3. Is the CEL lit - Check for codes (see stickies for details).
jus stried cranking it...and it seems like im losing power.With every crank I feel like the car is getting closer to dying completely. All the lights in the car dim more and more with every crank.
get a spark tester and see if your even getting spark. if you arenot, check the cranksensors./coils/sparkplug/ if you are, go to fuel.
next time when you try to start the car, turn it to run, and listen for the fuel pump to come on for a sec to prime the injectors. if you dont hear anything, check the fuel pump relay. and then check the fuel pump. if it all checks out, go get a noid light, and connect it to the injector harness, and crank the engine. the light should flash every time the ecm grounds the signal.
Killcrap...u the man..Thanks for the advice...I had an inkling that it might be my fuel pump because I didnt hear it come on...nor was I smelling any gas after pumping the accelerator while cranking it.
BTW
Wheres the fuel pump relay..
BTW
Same thing happened to me. After so many cranks, my battery died. When nissan looked at it, they thought it was the starter and replaced it without charging the battery (bastards). It ended up being a faulty fuel pump. The relay checked out OK. Needless to say, I had to pay for the starter, too.
There's two types of fuel pumps for our car distinguished by the electrical connectors. Make sure you get the right one.
I kinda have the same problem...except the starter turns(clicks to start the car), but the tach doesnt shoot up like it normally does, itll go up to like.5 on th rpm, and try to go up, but cant..it has started to stall out after I turn the ignition, and I end up having to turn the key 4-5 times, and press the gas each time, to get it started..once it finally starts up..I hear a belt whine pretty bad, but thats it..once I start driving, no whiny noise, no smell, the car runs fine..my car only has 89k miles..its been hot as hell here in ny recently..and I dont know what it could be..the car sat for a year and a half because the lady I bought it from moved to ireland..
Originally Posted by nycspudz03
I cant seem to locate it...can someone be specific and pinpoint it out.
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MaximaDrvr
08-19-2015 08:20 PM
Maxboy23
08-11-2015 11:59 AM
