Changing settings on AGX's and Illuminas
I'm trying to decide between the KYB AGX's and the Tokico Illuminas for my 97 Max SE 5spd. Right now I'm in the process of finding the best price. Went in to the local NOPI dealer today and asked him for a price and got it. However, he mentioned that some guys like the AGX's better because they are able to adjust the settings easier than on the Tokicos. AGX's have a dial that is fairly easy to access and set. He said that the Tokicos are adjusted w/ a screwdriver from the top of the shock. Can anyone help me out here? How do you adjust both shocks and which is easiest? I have been leaning toward the Tokicos just because they have come out more recently but I am flexible. BTW, looking at HR coils. Thanks.
The AGX's require a flate head screw driver to adjust the fronts, underneath the hood.
The rears have a twist dial, I have to get on the ground to access mine.
Im not sure about the Illumina's.
The AGX's are a bit stiffer then the Illuminas and they get real stiff in the cold. They dont take long to warm uo but just an FYI.
Most peaople are leaning more towards the Illumina's nowdays. They cost a bit more but seem to have a better ride.
I think this has been covered many times but Illuminas are super easy to adjust. A small flathead screwdriver will do all four... the rear you get to from inside the trunk, just need to pop off one corner of the carpeting.
yeah, Illuminas are really easy. just a screwdriver on all four, as people have said. on the AGX, isn't there a dial on the actual strut body? therefore, wouldn't the tire have to be removed in order to get your hand in there to adjust it?
(sorry, just a little question on the side, but I couldn't get an answer anywhere: I put KYB dustboot/bumpstops on my Illuminas last night. for the front, is the boot supposed to be pushed down onto the actual polished piston part? I just pushed it onto there until the top of the boot was flush with the bottom of the threads. but people kept saying that they fit like stock and I couldn't imagine how.) so to jack the thread, but I tried to contribute above
The Illumina's by concensus seem to have the better range in ride quality and that's what the strut is all about, both are easy to adjust but you don't do that everyday! You certainly ride on them everyday, basically don't get hung up on the adjustablity, spend the extra bucks and get the best..... ILLUMINA'S, you can have stock plush ride even lowered or autocross stiff!
I am looking for strut recommendations for my wife's 99 Max SE. She wants struts that are close to OEM ride, but are good quality. From reading several forum threads, I gather that the Illumina's are more adjustable than the AGX and closer to OEM ride?
Thanks,
Steve
Thanks,
Steve
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
sdotcarter
09-02-2015 09:53 PM
