Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 06-25-2005, 09:46 AM   #1
Points: 12,875, Level: 74
Points: 12,875, Level: 74 Points: 12,875, Level: 74 Points: 12,875, Level: 74
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via Yahoo to dr-rjp
Disconnected battery = reset ECU memory
I read somewhere that disconnecting the battery resets the ECU's memory of how you drive.
My question is, "Does that happen immediately, or only after a certain period of time?"
I'm installing a new battery and I would prefer NOT to give my ECU amnesia.
dr-rjp is offline   Reply With Quote
Old 06-25-2005, 09:58 AM   #2
Kevlo for President
Kevlo911's Avatar
Points: 41,763, Level: 100
Points: 41,763, Level: 100 Points: 41,763, Level: 100 Points: 41,763, Level: 100
Activity: 59.5%
Activity: 59.5% Activity: 59.5% Activity: 59.5%
No, only way to reset ECU is to use the screw method or Consult. OBDII readers can clear the code.
Batt does nothing.
__________________
97 Pearl White Max GLE
Kevlo911 is offline   Reply With Quote
Old 06-25-2005, 09:59 AM   #3
Do I get a tax break?
I don't know exactly how long you have, but I think its on the order of 30 mins. So you should have plenty of time to swap in your new battery. You will lose radio station presets, clock etc., those are independent of the ECU memory.
__________________
96 Max GLE.
Mods: Carseat in the back, stroller in the trunk
njmodi is offline   Reply With Quote
Old 06-25-2005, 02:57 PM   #4
Points: 7,960, Level: 60
Points: 7,960, Level: 60 Points: 7,960, Level: 60 Points: 7,960, Level: 60
Activity: 0%
how would the car know how you drive?...i mean ive heard of wear in certain spots on the clutch due to the driver, but never anything on the ecu.
__________________
Shift_Insane
98 Maxima SE
Mods:
Red/White Tails; Clear Corners; Fog light Rewire mod;
HAI; Optima Red Top; Pacesetter Catback; Pioneer System
Coming Soon:
Illuminas; H&Rs; Budget Y-pipe; and Possibly Stillen kit
2005 Harley Davidson Dyna Glide
Stock
87 Mustang GT
Work in progress
InsneDrmr is offline   Reply With Quote
Old 06-25-2005, 03:58 PM   #5
Activity: 0%
Quote:
It's alive! It's alive!
Seriously, the ECU is a computer with a self-learning function that adapts various engine functions to how you drive.
Drive like a granny? The ECU will produce one set of variables to match. Drive like Mario Andretti? The ECU will produce a different set of variables to match.
Now, if we could only get the drivers to be so smart!
Old 06-25-2005, 04:05 PM   #6
Kevlo for President
Kevlo911's Avatar
Activity: 59.5%
Actually the ECU is always learning, every second. There are no presets that it adjusts to. The maps are changing all the time.
__________________
Old 06-25-2005, 04:38 PM   #7
Points: 13,588, Level: 75
Points: 13,588, Level: 75 Points: 13,588, Level: 75 Points: 13,588, Level: 75
Activity: 0%
Disconnecting the battery long enough will clear all codes if stored in the memory of the ECU. But, this actually does nothing but make the car have to go thru several drive cycles to re-learn everything. If there were codes stored before the disconnection, you can guarantee that it will come back soon if the faulty sensor hasn't been changed. That is why if you change a faulty sensor, and have to disconnect the battery or not, just as long the battery isn't disconnected too long (several hours or so), you should use a scan tool or consult to clear the code so that the car can recognize the new sensor and adjust to it right away. The car will relearn much faster with the new sensor.
MIXXMAX is offline   Reply With Quote
Old 06-25-2005, 04:46 PM   #8
Points: 35,333, Level: 100
Points: 35,333, Level: 100 Points: 35,333, Level: 100 Points: 35,333, Level: 100
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
Send a message via AIM to njmaxseltd
how would the car know how you drive?....
BMW's learn how you drive.
Their transmission controller actually adapts to your driving style when you drive in the "S" sport mode. If I drive my 330 hard the controller holds the gears longer and doesn't upshift as quickly if you let off the gas for a second. You can very clearly feel it change shift patterns to adapt to the way it's driven.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 06-25-2005, 05:06 PM   #9
Kevlo for President
Kevlo911's Avatar
Activity: 59.5%
Maxima TCM is not that smart.
Like I said, dissconnecting batt does not clear ECU codes.
__________________
Old 06-25-2005, 07:54 PM   #10
I Broke OT
86maxima96's Avatar
Points: 10,839, Level: 68
Points: 10,839, Level: 68 Points: 10,839, Level: 68 Points: 10,839, Level: 68
Activity: 0%
Quote:
wow!! i had no idea! that's really cool to know. another great reason why i my maxima!
86maxima96 is offline   Reply With Quote
Old 06-25-2005, 09:42 PM   #11
Points: 11,591, Level: 70
Points: 11,591, Level: 70 Points: 11,591, Level: 70 Points: 11,591, Level: 70
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
John Lawrence Cudal @jlcudal Palakaboy
Send a message via AIM to cefiro8701
no u cant do this....do the ECU screw method...anyways...good luck...i tried the battery thing so many times...it doesnt work...do the screw method...
__________________
Need a photographer? (not my car or my shop)
the opposite of a mod list:
motor mounts, vacuum leaks, exhaust leaks, suspension leaks, headlights,Air Conditioning, corner lights, fog lights, interior leather, sunroof leaks, radiator support rubber, rusty rear swaybar, 200k struts, etc...
Repairs done:
Front Bumper, Passenger Fender, Most vacuum leaks, sunroofleaks, indiglo gauges, HID mounts
cefiro8701 is offline   Reply With Quote
Old 06-25-2005, 09:58 PM   #12
blah
Points: 8,950, Level: 63
Points: 8,950, Level: 63 Points: 8,950, Level: 63 Points: 8,950, Level: 63
Activity: 0%
It does for me. When I did the big 3 upgrade and when I installed my stereo it cleared the codes. I would estimate that you have to disconnect the battery for about 2 hours for it to clear the codes. Also when I went on a trip for two weeks I disconnected the battery and cleared the codes again.
Batxel is offline   Reply With Quote
Old 06-26-2005, 08:02 AM   #13
Kevlo for President
Kevlo911's Avatar
Activity: 59.5%
I bet if you check the codes, the codes are still there
Sometimes the ECU turns the light off but the codes are still in the computer and the light will come back on in a few days.
__________________
Old 06-26-2005, 08:06 AM   #14
You can reset your maximas memory by unhooking your battery cables and hold them together, thus drainging all energy from your car, leading to a reset in your cars memory. Since you do not wish to do this, just simply make sure your + and - are not touching. You have plenty of time.
dtm13002 is offline   Reply With Quote
Old 06-26-2005, 10:55 AM   #15
Old 06-26-2005, 03:45 PM   #16
blah
Activity: 0%
I checked the codes and they weren't there. In my case they were evap codes so whenever I disconnected the battery or reset ecu (screw method) the codes came back about 2-4 days later
Old 06-26-2005, 05:45 PM   #17
blah
Activity: 0%
njmodi didn't say anything wrong read it again
Old 06-26-2005, 05:50 PM   #18
Send a message via AIM to Crockpot Send a message via MSN to Crockpot
Quote:
you're right, my bad, post removed
__________________
Crockpot is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
