Tranny problem !!!!
Old 06-10-2005, 11:13 AM
Abimax95's Avatar
Tranny problem !!!!
Hi guys here is my dilema ...I had to replace my clutch and also the input shaft bearing and seal ...well after I put evething together in the pouring rain until 11:30pm for some reason the tranny stays on reverse there is no neutral although the sihfter is on the neutral position the car goes on reverse ,if I shift it to 5th it goes on reverse ,if I shift to reverse it goes on reverse , if I shift to 1st it dies , if I shift to second gear the shifter gets stock !!! someone help
Abimax95 is offline
Old 06-11-2005, 07:21 AM
4thgenx42's Avatar
Ooooooh, man that sounds serious. Did u you do the clutch yourself? If you didnt take right back to he mechanic who did. It sounds like a clutch problem.
4thgenx42 is offline
Old 06-11-2005, 07:23 AM
Chickan's Avatar
check your linkage? I've never heard of anything like that. I'll check my haynes manual later on.
Chickan is offline
Old 06-11-2005, 07:24 AM
Bobo's Avatar
Did you not read what he said? Sorry, I can't help but be patient, some knowledgeable .orgers will weigh in once they shake off the cobwebs, lol!
Bobo is offline
Old 06-11-2005, 08:56 AM
MDeezy's Avatar
all sensors were hooked back up? I'd check sensors etc and linkage also.
MDeezy is offline
Old 06-11-2005, 10:37 AM
slag's Avatar
sounds like your linkage anchor wasnt put in and the linkage is not engaging properly.
slag is offline
Old 06-11-2005, 02:55 PM
maxgazm's Avatar
Linkage has to be the peoblem. mostlikely not even hooked up at all. need to double check.
maxgazm is offline
Old 06-12-2005, 07:37 AM
Abimax95's Avatar
Hi guys thanks for all the feedback I will open it again and check but as far as I know everything was put back the same way I took them out ...If I didn't put the links right how would I know if they are in the right spot ????well I will find a schematic of the tranny and check !!!
Thanks to all
Abimax95 is offline
pktaske
05-06-2016 07:49 AM
Socalstillen
09-20-2015 11:46 PM
iamute
09-20-2015 05:22 PM
pktaske
09-04-2015 08:40 AM
Lowered_a33
09-01-2015 07:49 PM
Quick Reply: Tranny problem !!!!
