How to fix Ecu Code 1001 ?
Old 06-09-2005, 04:45 AM
maximavqpower97's Avatar
I found out thise ecu code in the mourning 1001 decoder says its Front Left Htd 02 sensor heater, but how do i fix it?
maximavqpower97 is offline
Old 06-09-2005, 05:43 AM
BUMP.help plz.
Old 06-09-2005, 06:45 AM
Do I get a tax break?
njmodi's Avatar
Read the stickies.
njmodi is offline
Old 06-09-2005, 06:47 AM
Originally Posted by njmodi
Read the stickies.
i did and it doesnt say nothing about it.
Old 06-09-2005, 06:49 AM
njmodi's Avatar
I took me 10 seconds to search the ECU sticky for this - at the bottom of the text, it refers to code 1001.
0901
Diagnostic Trouble Code 0901 points to a problem with the Front Heated Oxygen Sensor, Right Bank. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5.
The Front Heated Oxygen Sensors are installed in the Y-pipe, the part of the exhaust system which conveys exhaust gases from the exhaust manifolds to the Catalytic Converter. There is an Oxygen Sensor in each branch of the Y-pipe. These sensors produce a signal which varies with the concentration of oxygen in the exhaust gas, as compared to the outside air. This signal is sent to the Engine Control Module which uses it to control the fuel injection system.
DTC 0901 is detected when the current drawn by the heating element in the Oxygen Sensor is out of the normal range.
Possible causes include ...
- harness or connectors (the sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor (right bank).
The heated Oxygen Sensors have two components: a heating element and a sensing element. The heating element may be tested with an ordinary ohmmeter. This test is done with the engine off.
Follow the wires away from the Oxygen Sensor until you find the nearest electrical connector. Disconnect the connector. Viewed with the connector latch at the 12 o'clock position, there are three terminals. They are numbered 1-3, right to left. Be sure to measure the terminals in the connector half which is attached to the Oxygen Sensor, not the one which leads to the Engine Control Unit.
Measure the resistance between terminals 1 and 3.
The factory spec is 2.3-4.3 ohms at 77 degrees Fahrenheit.
Measure the resistance between terminals 1 and 2.
The reading should be infinity (no connection).
Measure the resistance between terminals 2 and 3.
If the resistance measurements are significantly different from the factory specifications the sensor is faulty and must be replaced.
If the resistance measurements meet the factory specifications the sensor may be good and the wiring is defective. You could exchange the two Front Heated Oxygen Sensors and reset the Engine Control Module. Then drive normally and expect the Malfunction Indicator Lamp to turn on again. If you still get DTC 0901 the wiring is faulty. If you get DTC 1001 the sensor is bad.
njmodi is offline
Old 06-09-2005, 07:01 AM
Can this be the noise i been hearing?
Old 06-09-2005, 03:03 PM
97MaximaSE's Avatar
to fix replace front left heated o2 sensor
97MaximaSE is offline
Old 06-09-2005, 03:15 PM
Bobo's Avatar
I think the noise you have been hearing is totally unrelated. You have another problem.
Bobo is offline
Old 08-09-2005, 10:32 AM
pedroboe's Avatar
I have the same code, 1001.... my sensor is new and the ECU has been reset. Did the person that installed it fucced it up? is it possible to install it wrong or fucc something else in the process? I guess the answer is yeah, but was wondering if anyone has had the same issue.
pedroboe is offline
Old 09-19-2010, 10:36 PM
illmortal's Avatar
huge bump
Is there a diagram/blue print to show the locations of our sensors... specifically this one? I have this code as well.
illmortal is offline
Old 09-21-2010, 02:08 PM
ajcool2's Avatar
http://www.courtesyparts.com/maxima-...1814_1818.html
ajcool2 is offline
Old 09-21-2010, 03:22 PM
illmortal's Avatar
Thanks a lot bro!
03-12-2020 12:06 AM
gustavison
10-04-2015 06:50 PM
QueensMAX
09-15-2015 04:14 AM
lux97Max
09-11-2015 01:12 PM
Quick Reply: How to fix Ecu Code 1001 ?
