Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-08-2005, 04:07 PM   #1
Send a message via AIM to Sizzam
Car shakes when at a stop
hey everyone, im having a problem with my car and i dont know what it is. whenever i come to a complete stop (at a red light or in traffic) my car starts to shake and it is concurrent with my RPM's. when my car shakes, my RPM needle shakes as well. Now when i put my car in nuetral, the skaing completely goes away. does anyone have any idea what this could be? i thought maybe my battery was going bad so i went and bought an optima yellow top battery and it is still doing this. someone please help me because this is really annoying. by the way, if i am in reverse and stopped it also does it, but not in park.
Sizzam is offline   Reply With Quote
Old 06-08-2005, 05:06 PM   #2
Torque converter maybe?
smokeyone is offline   Reply With Quote
Old 06-08-2005, 05:08 PM   #3
have you diagnosed your TPS?
__________________
atpham89 is offline   Reply With Quote
Old 06-08-2005, 06:01 PM   #4
Send a message via AIM to NY 95 VQ30DE
my car was doing something similar earlier today. at a stop it was idling low and rough, and when i shifted it would stall. two days ago, i cleaned my k&n filter, and when i put it back in the rubber gasket between the airbox and the maf wasnt in right. as i was driving down the highway, the bumps caused the gasket to slip out from under the hose clamp , leaving a gap between the airbox and the maf. took me 5 mins to loosen the hose clamp and re-assemble it. check your intake before doing anything.
damn those little things
NY 95 VQ30DE is offline   Reply With Quote
Old 06-08-2005, 07:46 PM   #5
Send a message via AIM to vizslak7
You may need new ignition coils. In fact, I will bet $5 on it.
JS
vizslak7 is offline   Reply With Quote
Old 06-08-2005, 11:11 PM   #6
I have had the same problem for the last six months, still can't get to the bottom of it. I have changed all 6 coils(1 was bad anyway),new fuel filter,plugs, cleaned iacv,adjusted idle up, always run premium, no codes from ecu. THIS IS DRIVING ME INSANE!! Car was fine then one day while stopped at a light rpms dropped, car vibrates and has been this way since. If you figure it out, PLEASE follow up with this post. I'm pretty sick of shiftin into neutral at every light.
tweeter007 is offline   Reply With Quote
Old 06-08-2005, 11:29 PM   #7
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
What are your peoples idle at when at a light, I'm guessing you're all automaitc..
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-09-2005, 12:21 AM   #8
750 when in neutral or running "normal". Put it into drive it slowly drops to 450-500 car begins to vibrate, put back into neutral smoothes out goes back up to 750.
Old 06-09-2005, 12:34 AM   #9
Certified Hooptie
NmexMAX's Avatar
Some fine tuning of the ECU screw and mine sits at 900 in nuetral, and 750-800 in gear. Automatic of course ... but not for long
__________________
Old 06-09-2005, 02:14 AM   #10
That has been happening to me also so I took it to my dad's shop and his mechanic checked for codes and something about an evap solenoid came up. So, tomorrow I am going to finally try and fix that problem. If it works then I will post what I did.
lman07 is offline   Reply With Quote
Old 06-09-2005, 09:26 AM   #11
The same thing happened to me. It started a couple weeks ago. I have done all the maint. on it and have cleaned the iac 2 times in the last 1.5 years now. (I only put on 6000 miles a year) I don't get any codes or pending codes. I have a dyno-scan program for my palm so i can monitor all the sensors. My idle is shaky in gear (like its missing) and kind of goes away after warmed up, but then in gear at a stop it shakes and the idle varies from 625-700 and constantly changes. I know what your thinking but i already changed my tps sensor 6 months ago. Man this is the most touchy problematic car i have ever owned. So far i have had the transmission overhauled (due to the crappy nissan solenoids, replaced the knock sensor, tps sensor changed all non cheap factory spark plugs, fuel filter, Good thing i love to do this kind of thing or i would be pissed. But the good thing about the trans overhaul i got a good shift kit out of the deal. Then needed to install the trans cooler up front. Man that thing make a difference in temps. Well enough about my rambling, Anyone have an idea of whats going on here?? If the coils are going bad won't they have a code or pending code??
Subzero is offline   Reply With Quote
Old 06-09-2005, 09:27 AM   #12
Oh yeah I only have 50,500 miles on it!!
Old 06-09-2005, 10:17 AM   #13
Certified Hooptie
NmexMAX's Avatar
Your car sort of sucks ... mine has 229k still on original tranny, & TPS.
__________________
Old 06-09-2005, 10:37 AM   #14
Geez you had your car since it was brand new hugh?? If not how do you know it has the original?? Yeah knowing of all the problems are cars have and especially the a/t, I find it really hard to believe. I suppose you have the original k/s and coils to??
Old 06-09-2005, 10:40 AM   #15
Certified Hooptie
NmexMAX's Avatar
Nope, if i had the original KS I would have stated as well as the coils. On my 2nd KS and changed one coil.
My tranny is slipping more than a crack fein on a new job .. but that's given.
__________________
Old 06-09-2005, 01:03 PM   #16
thanks for all of the inputs...i think i am goign to just go to max tuning sometime next week and have jeff run like every single diagnostic possible.
Old 06-09-2005, 04:18 PM   #17
Im also having the same problem. Whenever I come to a stop.. my whole car starts to shake like crazy.. this has been happening for the past year and I still cannot find what is wrong with it. If anyone ever finds a solution, please post it because im getting sick of the vibrations.
prestoguy is offline   Reply With Quote
Old 06-11-2005, 10:08 PM   #18
anyone find a solution? =/
Old 06-12-2005, 12:56 AM   #19
nick's Avatar
Send a message via AIM to nick
do the shakes go away when more load is applied to the engine? ie: AC turned on?
if they go away - your base idle speed is to low and needs to be adjusted by disconnecting MAF sensor and turning Idle adjustment screw which is located on TB
don't forget to re-connect the MAF after you are done !!!
Nick.
__________________
Lower control arm & sway bar bushings replacement WRITE UP
http://www.cardomain.com/ride/348507/15
Inner tie rod WRITE UP
http://www.cardomain.com/ride/348507/13
nick is offline   Reply With Quote
Old 06-12-2005, 02:31 AM   #20
Send a message via AIM to oofzpumba
MY CAR ALSO!.my mechanic told me it was a problem with my spark plugs didnt get the job done yet. i also have the solenoid thingy problem that is why my check engine light is on. my knock sensor is bad also. and i recently got into an accident just body damage but maybe mechanical.. anyone ever solve tis problem?
oofzpumba is offline   Reply With Quote
Old 06-12-2005, 12:05 PM   #21
Changing the plugs never helped out my cause, please guys keep this one going until someone figures this thing out, the Nissan dealership here did'nt even have a good answer, they checked all codes, came up blank, they claim the "exhaust system is mounted too tight", pretty lame answer seeing as how the problem started 2 months after exhaust was installed. Nothing seems to help the vibes, when a/c is turned on idle does go up, but not as much as it used to, car feels like it is struggling to keep idle up, put in N however it all goes away.
Old 06-12-2005, 04:31 PM   #22
nick for me the the car shakes less when the car is cool. as soon as it heats up i feel it kicking shaking and all sorts of things?.. help PLEASE!
Old 06-12-2005, 04:59 PM   #23
I agree, when the car is first started there is really no vibration in D, as soon as it reaches normal temp, vibration begins
Old 06-12-2005, 09:32 PM   #24
Quote:
yea, the first 5-10 mins after start up.. there isnt much vibrations..
then after a while, every time i come to a red or a stop sign, it starts shaking violently and sporatically. it gets so dam ANNOYING.
Old 06-12-2005, 11:32 PM   #25
Hey guys, just thought i'd throw my experience in here. I have the same problem, ive checked the coils, spark plugs as well as changed the fuel filter and cleaned the k & n air filter and the throttle body. I had a bad knock sensor replaced that but it turns out that wasnt cause of this problem. Still got no idea what it is, so im gunna be takin it in to the STEALership the day after tomorrow and see if they can deal with it. I'll let you know what they find and if they fix it,mabey it will help u out too.
StrikerHA is offline   Reply With Quote
Old 06-12-2005, 11:55 PM   #26
Offset Is Everything.
Send a message via AIM to MrDicks95SE
my car shakes like a salt shaker. in neutral at every light and stop sign. wahoo.
MrDicks95SE is offline   Reply With Quote
Old 06-13-2005, 12:18 AM   #27
this vibration is very disturbing and stressfull -=T my poor max
Old 06-13-2005, 01:00 AM   #28
Quote:
good luck with everything, hopefully you can get it sorted out and tell us whats wrong..
Old 06-13-2005, 01:16 AM   #29
Quote:
Battery? I couldn't imagine what why the battery would cause it. Same with the torque converter, if it shakes when the car is in gear, I think it's because putting it in gear causes the engine to run at a lower rpm. That's all I have, this hasn't happened to me yet.
ryant35 is offline   Reply With Quote
Old 06-13-2005, 04:40 AM   #30
Jime's Avatar
I had that problem with my wife's Max (my old 95 GXE) it turned out to be one of the injectors.
You can check by leaving it in D and pulling the e-brake on and pulling the connector off of each injector one at a time and see if it changes the idle. If it makes it worse of course the injector is ok but if it makes no difference you could have a plugged injector. I just happened to have a few spare so I just changed it and all was ok.
It was one of the front 3, but if its on the back 3 not sure if you can unplug the connector while the intake is on.
PS Make sure the a/c is off because it sometimes makes the idle rougher.
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 06-13-2005, 08:56 AM   #31
Send a message via AIM to maxdick
I think it's probably that lardass who lives across the street slowing your car down and making the engine work too hard.
__________________
http://www.richardtrautmann.com
Want to Buy:
clear corners (bumper/blinker lights)
white plastic cover for passenger side mirror
For Sale:
97-99 Foglights
maxdick is offline   Reply With Quote
Old 06-13-2005, 02:51 PM   #32
I had the exact same problem on my Max ('99 GLE). It shook at idle after the engine warms up, but only did it like half the time. I replaced 5 coil packs (left the old one in the cylinder that seemed hard to get to) and the car still shook. Then I said "darnit I gotta get that 6th one out, I already paid 300+ bucks for the new coil packs" and then figured out that I only had to take off 2 bolts to get to the 6th cylinder. I replaced the last coil pack and everything's been fine now for a couple hundred miles. I didn't test my old coilpacks, but I didn't replace or change anything else so I figure the coilpacks must have been the problem.
Moral of the story: change your coilpacks. I've read on here before that testing them isn't good enough, as sometimes they test out OK but they are still bad.
nethack4ever is offline   Reply With Quote
Old 06-13-2005, 06:03 PM   #33
HOLY FRICKIN CRAP Finally people who know what I'm talking about!!!!!!!
I can't believe everyone has this SAME thing. I have been posting on this site for like a month now about the SAME D#$# THING.
Mine does exactly the same thing, and it stops in neutral, and I have the same error codes as everyone too, KS (replaced), O2 Sensors (replaced), EVAP purge valve/selenoid valve (not replaced yet), and
Well I did all the same things everyone else has done:
all new NGK plugs
all new HANSHIN coils
new fuel filter
cleaned Trottle Body (gave me more acceleration but didn't fix the stutter)
bla bla bla
Well then yesterday the MAX started running really bad and threw some new codes.
This time I got a cylinder 5 misfire,(among other things) I checked the coil for spark today and it was fine then I tried the self diagnosis described on VB8maxima.com or whatever that site is. You can test the rear bank of injectors using the connector on the passenger side of the engine, the big U-shape harness, there is a connector there that allows you to test injector 1, 3, 5.
Well in turns out #5 injector is bad, so I will be spending the next couple of days taking apart the engine to replace that one and clean the others(while im in there)
SO if this fixes the dreaded " stop light shake" I will share it with everyone (and if it doesn't I will share anyway only no one will care because it still doen't solve a d*&n thing).
Anyway I'll let you know how it goes.
95GLEPEARL is offline   Reply With Quote
Old 06-13-2005, 06:14 PM   #34
someone siad they changed their coilpacks and it didnt fix it? UGH!!! this is confusing..
Old 06-14-2005, 09:34 AM   #35
hmm so the problem is either your , spark plug , ignition coil , or injector?
Old 06-14-2005, 10:08 AM   #36
Try running injector cleaner first! I had a car that did the same thing described and injector cleaner fixed it.
Anii23 is offline   Reply With Quote
Old 06-14-2005, 10:27 AM   #37
Disco Biscuit
Whitemax's Avatar
Send a message via ICQ to Whitemax Send a message via AIM to Whitemax Send a message via Yahoo to Whitemax
On my auto max its the torque converter. acts almost like my 5speed stopping without the cluch being engaged. Put it in neutral and it goes away since theres no longer a load. Personally I'd say it's your torque converter.
__________________
"You don't appreciate a lot of stuff in school until you get older. Little things like being spanked every day by a middle aged woman: Stuff you pay good money for in later life."
"Who was the first person to say, 'See that chicken there -- I'm gonna eat the next thing that drops out its butt."
Whitemax is offline   Reply With Quote
Old 06-14-2005, 10:45 AM   #38
Send a message via Yahoo to dr-rjp
Believe it or not, bad gasoline will do that!
Assuming that you use something good like Chevron or BP, then I would put my money on a vacuum leak!
You've got vacuum lines running to a lot of critical parts throughout the engine, such as the IACV, the EGR, the PCV, etc..
PLUS, a vacuum leak will typically rear its ugly head ONLY when idling...so that is why I suspect that is your problem.
dr-rjp is offline   Reply With Quote
Old 06-14-2005, 10:58 AM   #39
ughhh i got the same freakin problem. 1997 GXE 125k. For a while car would shut off only when i i shift it to R (or D sometimes). Now it just stoll's on me when ever, sometime even while driving which is dangerous. Went to my mechanic ..like on purpose it worked great there, shift to reverse no prob, drives perfectly, computer diagnostics says no poblems detected. As soon as i pull by my house it shuts off all over again, as i try to start it it starts but rpm jump up and down then drops to .3 and shut offimmideately. What could be there problem??
Also i decided to see whats going on with my spark plugs, i replaced them maybe only 4 months ago and put 6k on them NGK Vpower coopers, as i took them out the end that gives spark is all smoky with black 'sulfur'. I dont know if that part of my car shutting off problem but it didnt look too good.
I really dont know what to do ECU shows no code, while at Mechanic car ran perefectly so he said he cant help. Im really confused and have no idea what to do and what to look at. (gas filter, air filter, starter, rear o2 sensor all recently replaced)
went to a different mechanic yesterday after cheking it out for a while he said he is 99% sure that it has something to do with transmission and that i should take it to Nissan Dealer as its my only choice....Could it be the tranny???
MaximumAlex is offline   Reply With Quote
Old 06-14-2005, 11:26 AM   #40
Same thing happened to me, now its gone. It didn't happen right away, after i cleaned my TB and IACV i noticed it went away slowly. Also check your air filter if its dirty and MAF and intake connections.
konak85 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
