Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-16-2005, 10:09 PM   #1
eng92's Avatar
03 gauge cluster in a 98
This is part of a full 3.5 swap that I will be doing in about a month.
I got a great deal on an 03 gauge cluster ($25 CDN) because one of the three mounting brackets was broken off. For the swap that is ok because all three brackets are in different locations compared to a 4th gen.
Here is the 03 cluster with the 2 remaining mounting brackets cut off.
I fabricated the two lower brackets out of polyurethane using a plaster of Paris mould I made of my stock 98 cluster. For the top bracket, I just reused the one I cut off by gluing it in at the correct position and angle.
Here is the gauge cluster with the new brackets.
Here it is installed without the finishers on.
And with the finisher installed.
Check out the mileage on the odometer 3619 km (~2250 miles)
As far as wiring is concerned, you pretty well need to have a section of the the 03 dash harness as the three gauge cluster connectors are completely different from the 4th gen. I had the 03 harness already as I am using a portion of it for the engine swap. It was simply a matter of going through the 98 and 03 wiring diagrams and splicing the appropriate wires.
IMO this mod is not worth it unless you are doing a full 3.5 swap.
The only nice feature that the 03 cluster adds is the board computer which displays: ambient temp, trip timer, ave. trip speed, fuel consumption and estimated driving range based on remaining fuel.
eng92 is offline   Reply With Quote
Old 05-16-2005, 10:19 PM   #2
Looks great. Are you planning to use the 3.5 ecu + e-gas?
GoalieKeg is offline   Reply With Quote
Old 05-16-2005, 10:22 PM   #3
Send a message via AIM to G4nismo
what!!!?? i would love to have that feature b/c i'm usually low of gas cause of the
astronomical prices
__________________
03 Z33 Brickyard touring coupe 6spd
97 Maxima - Sold
Quote:
Originally Posted by 35oZephyR View Post
My350z = General Car Enthusiast Forum (sprinkled in with a little Z douchebaggery)
G4nismo is offline   Reply With Quote
Old 05-17-2005, 04:43 AM   #4
Team Ramrod
lilaclucymaxima's Avatar
Send a message via AIM to lilaclucymaxima
Looks sweet, weird that its in km/h though...
lilaclucymaxima is offline   Reply With Quote
Old 05-17-2005, 04:48 AM   #5
Do I get a tax break?
Quote:
He's in Canada...
njmodi is offline   Reply With Quote
Old 05-17-2005, 04:50 AM   #6
Quote:
Where does the ambient temp. reading come from? i.e. where is the sensor? I would have assumed it was independent of the cluster.
Btw, creative mod! I don't think I've seen that around here yet...
Old 05-17-2005, 04:54 AM   #7
i wonder....... could you take the ambient/trip lcd out of there and retro it to another place in the 4th gens like for example the empty spot next to the dimmer switch on the gauge cluster
__________________
Every vision is a joke until the first man accomplishes it once realized it becomes commonplace.
15.492 @ 88.50
DTM Tails-AE headlights and corners-PIAA fogs-Place Racing Intake-Drop Resistor Mod-7"nesavision screen indash-clarion 835mp-PS2-LED Window Switches-Remote Start-Cigar humidor in center console-Polished Strut Bar-Custom auto shifter knob
98maximaSS is offline   Reply With Quote
Old 05-17-2005, 06:25 AM   #8
Send a message via AIM to YozhiksMax
it looks really nice......i think i might want to do that
__________________
YozhiksMax is offline   Reply With Quote
Old 05-17-2005, 06:31 AM   #9
Wow, nice job dude.
konak85 is offline   Reply With Quote
Old 05-17-2005, 06:33 AM   #10
Jedi Knight
nupe500's Avatar
Send a message via AIM to nupe500
That is a very nice mod...did you use the 4th gen finisher? How was the fitment on that? Glad to see that all of your dials work...the question is...are they still accurate? (fuel tank, and the lights...also...no CEL? What about the traction control light?)
Sorry for all the Questions...
__________________
Boondocks Wrote: Could you repeat that again? I couldn't hear you over sh*ttin myself
www.greekfamilyaffairs.com
nupe500 is offline   Reply With Quote
Old 05-17-2005, 06:57 AM   #11
eng92's Avatar
Quote:
Yes & Yes.
Quote:
It is independent of the cluster. The stock auto air conditioning uses an amb. temp sensor located up in the front of the car by the rad. You just need to splice into the two stock wires and run them to the cluster.
Quote:
Originally Posted by 98maximaSS
I wonder....... could you take the ambient/trip lcd out of there and retro it to another place in the 4th gens like for example the empty spot next to the dimmer switch on the gauge cluster
There is some signal processing done in the cluster itself to calculate the values. You would of course have to move all the associated circuitry with the LCD display. I have not opened up the cluster to see if the display and all the electrics are an integrated unit.
You do need a separate momentary contact switch connected to ground to switch the displayed parameter. On the 02/03, the switch is on the wheel. I am taking a TCS off switch from a 99 and using that.
Old 05-17-2005, 07:16 AM   #12
eng92's Avatar
Fitment of the finishers is perfect as the curvature (up/down) on the front of the cluster for the 4th & 5th gens is the same. There is a slight difference in the left-right profile of the clusters. The 5th gen is a little narrower. Most people would not notice.
The wires for the TCS light are not hooked up so it does not come on.
Fuel is accurate as the needle is in exactly the same spot as it was on the original cluster when I removed it.
RPM and tach are accurate. Idle is at 650. 120 km/hr is ~3000 rpm in 5th which is right where it should be.
The only problem really is the coolant temp gauge. On the 02/03, the ecu supplies a voltage signal to the cluster for water temp. On the 4th gen, there is a separate water temp sensor that is used by the gauge cluster and the auto air conditioning. The ecu uses its own sensor. Therefore the circuitry is not built in to the 02/03 cluster to convert the sensor resistance into a voltage that the gauge can display.
In my case, this does not matter as I will be using an 02 ecu when I swap engines.
Old 05-17-2005, 07:24 AM   #13
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
Nice job dave.....look forward to seeing the full swap
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Zack342 is offline   Reply With Quote
Old 05-17-2005, 07:41 AM   #14
eng92's Avatar
Quote:
Thanks Zack. Right now I am just trying to take care of all the little things ahead of time just to minimize the downtime when I do pull the engine. I am in no rush as it will be atleast another month or more before Cattman has another batch of headers ready for shipping.
My next little weekend project will be installing an 03 fuel pump assembly in my tank.
Old 05-17-2005, 08:31 AM   #15
VK56 Inside
Dubbya's Avatar
Send a message via Yahoo to Dubbya
Looks great man! Any chance you could fabricate these for people?
Dubbya is offline   Reply With Quote
Old 05-17-2005, 08:50 AM   #16
Wow! Nice job! You're quite the smart one for figuring that all out! Are you going to do a writeup? Definitely very creative!
Northern Maxima is offline   Reply With Quote
Old 05-17-2005, 08:52 AM   #17
No longer a maxima owner.
kingrukus's Avatar
Interesting I must say. Are you on TMEC?
__________________
Current:
G35 M6 Coupe (Summer)
6th gen Accord SE 5MT (Winter)
Previous:
5th gen Maxima SE 4AT
4th gen Maxima GXE 5MT
5th gen Civic CX 5MT
kingrukus is offline   Reply With Quote
Old 05-17-2005, 10:25 AM   #18
eng92's Avatar
Quote:
I have popped in a couple of times when the .org was down. Username is the same (eng92).
Quote:
To do multiple units the way I did it would be horrendously inefficient. You really need a 2 piece mould in order to do this in one step and still get the part out. Because this was a one of, I used some of my kids plastercine for the top portion of the mould and then just peeled it away once the polyeurethane and epoxy had dried. There was also some time involved with the dremel to shape the brackets exactly like the 4th gen stock ones.
Also, gluing plastics can be kind of tricky and I would hate to make a bunch of them for people and have the brackets snap off.
The short answer is: sorry but no. Some things in life you only want to do once for the learning value and/or the experience.
Old 05-17-2005, 10:47 AM   #19
Send a message via AIM to MDeezy
Fantastic job, very creative and differnt. Wish the 4th gen had the readings the 03 has. Will save this thread incase I happen to see an 03 clutste dirt cheap or need to reaplce mine for some odd reason.
How did you adjust the milage or did you?
__________________
Quote:
Originally Posted by CMax03 View Post
Where are the moderators???? This guy should have been banned after his first reply when he first joined this forum! I'm totally in awe with his behavior and ruthless antics on someone else's thread!!!!! I believe he's broken every rule at least twice...????????
Beware the Deezy
MDeezy is offline   Reply With Quote
Old 05-17-2005, 12:22 PM   #20
eng92's Avatar
Quote:
Once I get the 3.5 in with the ecu and data link connector, I will take it to the local dealership.
Old 05-17-2005, 01:30 PM   #21
Always sunny in philly
Nismotic's Avatar
Very nice job. It's something different over the regular SE gauges.
__________________
It's only after you've lost everything that you're free to do anything.
Nismotic is offline   Reply With Quote
Old 05-17-2005, 03:03 PM   #22
vsamoylov
you did the exactly same thing as me when i installed my cluster. props to you. cant wait until you have the complete swap. how far are you and waht did you do already?
Old 05-17-2005, 03:32 PM   #23
He's Gonna Blow!!!
Ninos_Maxima's Avatar
Send a message via AIM to Ninos_Maxima
wow that looks sexi, hehe now you can tell people you have a 02 maxima.
__________________
Shift_ Then Floor It
Fast cars are dangerous. Save lives, Drive a Honda!
Yeah I was in china, so I got one of these
A Chinese Name 疯熊水上漂 feng xiong shui shang piao
Crazy Bear floating on the River
Ninos_Maxima is offline   Reply With Quote
Old 05-17-2005, 06:57 PM   #24
Custom User Title
Looks interesting. Can't wait to see the finished product!
Nismo3112 is offline   Reply With Quote
Old 05-17-2005, 07:05 PM   #25
Send a message via AIM to SonicDust187
I have been thinking of installing a 2k cluster into my maxima. Hope I wont have any problems with the Fuel, Tach, Speedo, and Temp gauges.
SonicDust187 is offline   Reply With Quote
Old 05-17-2005, 07:05 PM   #26
Nice. Always wanted a 260 km/h gauge. Would it be worth putting in our cars as far as time and effort is concerned?
JClaw is offline   Reply With Quote
Old 05-17-2005, 07:38 PM   #27
eng92's Avatar
Quote:
You should not have any problems as the 2K cluster uses the same type of signal inputs for those 4 parameters as all the 4th gens.
Old 05-17-2005, 07:40 PM   #28
eng92's Avatar
Quote:
If all you want is a 260 km/h speedo, then use a cluster from a 2K/2K1. The wiring would be much more straightforward.
Old 06-02-2005, 08:24 PM   #29
1 of few unmodded 4G Maxs
Wills98MaxSE's Avatar
excellent job!!
Wills98MaxSE is offline   Reply With Quote
Old 06-02-2005, 10:02 PM   #30
Awesome job. Give you props for following the wiring and get it right...most people get discouraged when they have to do electronic work.
Wish u the best on the swap man.
Luigi38 is offline   Reply With Quote
Old 06-02-2005, 10:07 PM   #31
bklynzsleepy's Avatar
That is a freakin' awesome job that you did. Can you post more pictures?
bklynzsleepy is offline   Reply With Quote
Old 06-03-2005, 12:02 AM   #32
ohhh man that is so sick....I cant imagine getting into my car everyday and getting to look at that...man they are SICK ... nice gunmetal color
__________________
350z owner, but will always love the Maxima.. Love dem Nissans...
ThisMaxIsTight is offline   Reply With Quote
Old 06-03-2005, 12:37 AM   #33
Yeah they look nice but if ur province is anything like my state... Because uve changed clusters, and thus mileage information, ur title will need to be changed to "True Milelage Unknown" which will wack atleast a G off ur resale value, if not more....
__________________
No Points for Second Place...
The Deal is offline   Reply With Quote
Old 06-03-2005, 02:37 PM   #34
vsamoylov
the only problem with them is that they arent bright enough.
Old 06-03-2005, 06:20 PM   #35
eng92's Avatar
Quote:
That is a matter of personal preference. I use the dimmer control to turn the brightness down.
Quote:
IMO mileage becomes irrelevant once you swap in a non-stock engine from a different vehicle. Also I consider myself an "end user" so resale value is a non-issue.
Old 06-03-2005, 06:38 PM   #36
vsamoylov
did you also hook up the switch that operates the mpg/temperature and etc?
Old 06-03-2005, 07:22 PM   #37
eng92's Avatar
Yes. Last sentence of post#11.
Old 06-03-2005, 07:40 PM   #38
Send a message via AIM to joeeey
How many & what size bulbs are in the 03 max illumination. I just upgraded to 5 way Blue LED and would like to do the swap also, I just wanna know if I gotta order new LED's
joeeey is offline   Reply With Quote
Old 06-03-2005, 08:02 PM   #39
eng92's Avatar
Quote:
03 cluster uses four 3W bulbs for illumination.
Old 10-03-2005, 11:50 AM   #40
well done. Could you show me how to do the wiring please? thanks!
jackwu is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
