Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-03-2005, 12:38 PM   #41
Licensed to Spell
ptatohed's Avatar
Impressive! Nice job.
__________________
Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
1996 GLE, Pearl/Black - Superchargerless
1993 SHO, Pearl White/Gray - Stock
Super Charger install instructions
ptatohed is offline   Reply With Quote
Old 10-03-2005, 02:32 PM   #42
A write-up would be great on this. Id be interested in doing a different gauge cluster setup whether it was a 00 or 02-03. I like the newer ones better then my 95 gxe one. Im gonna be doin some junkyard hunting soon and if theres a good writeup on it ill try and snag one thanks it looks great man!
lanky2882 is offline   Reply With Quote
Old 10-03-2005, 03:34 PM   #43
eng92's Avatar
This is a mod that IMHO is not worth it unless you are doing a 3.5 swap w/ 02/03 ecu.
If you are not doing the swap,the following things will not work in your gauge cluster:
1. No engine coolant temperature display . The type of input used and the operating voltage range are different between 4th gen and 02/03.
2. No fuel consumption display - to calculate MPG, the cluster requires the real time fuel consumption from the ecu. This output does not exist on the 4th gen ecu, so you will only see a blank display.
3. "Soft" speed limiter at about 80 mph. This one was unexpected.
By "soft", I mean you can get past it if you are accelerating at a decent rate. It has something to do with the vehicle speed output from the cluster to the ecu. After swapping gauge clusters, I noticed that if I log vehicle speed through the OBD-II port, the recorded speed is 4X what the indicated speed is on the speedometer.
I never tried clipping the vehicle speed input to the ecu to see if that will eliminate this issue.
Currently, the cluster (and engine) are out of the car. The next time I start it up, all of the above issues will be gone.
eng92 is offline   Reply With Quote
Old 10-03-2005, 10:20 PM   #44
Others were saying that this would work with a 00 cluster though is the installation pretty similar?
Old 10-03-2005, 10:27 PM   #45
Send a message via AIM to JOMAN
looks good i like it!
JOMAN is offline   Reply With Quote
Old 10-04-2005, 06:23 AM   #46
eng92's Avatar
Quote:
00/01 use the same type of thermal transmitter for coolant temp as the 4th gen so you would not have the problem that I experienced with the 02/03.
There is no fuel consumption display in the 00/01 so you would not have that problem either.
The three electrical connectors are the same for 00 thru 03 so you still need to get those.
Also, I would think that because the 00 thru 03 all share the A33 chassis, the gauge clusters would have the same mounting points. Having never seen a loose 00/01 cluster, I cannot say this for a fact.
Old 10-04-2005, 06:42 AM   #47
tastey wheat
mendon99's Avatar
Send a message via AIM to mendon99
looks great! makes the interior look less old
__________________
'05 Altima 3.5 5spd
Eclipse, Rainbow, Viper 791xv
I install alarms and remote starters, PM for more info.
mendon99 is offline   Reply With Quote
Old 10-04-2005, 03:00 PM   #48
thanks for your help. Where did you get that stuff to mold the peice on the bottom the the cluster and what is it?
Old 02-25-2006, 10:08 PM   #49
What kind of glue did you use to attach the polyurethane brackets to the cluster? Where did you buy the polyurethane (what other suggestions do you have about the polyurethane)?
SmurfLeech is offline   Reply With Quote
Old 02-26-2006, 08:08 PM   #50
Send a message via AIM to cleanmax
looks good man
cleanmax is offline   Reply With Quote
Old 02-27-2006, 05:55 AM   #51
eng92's Avatar
Quote:
I made a large mold which encompassed the entire front half of the gauge cluster. The brackets were molded right to the cluster.
I heavily scored the bracket attachment points on the cluster with a dremel before putting the cluster in the mold. I brushed on three thin layers of polyurethane construction adhesive into the mold cavities for the brackets; allowing it to dry thoroughly between coats. The remaining voids in the bracket cavities were filled with regular 5-minute epoxy.
Once everything was dry, I cut the mold off and cleaned up the shape of the mounting points a little with a dremel. The last step was just drilling a hole through each bracket for the mounting screws.
Old 02-27-2006, 04:49 PM   #52
Proud Maxima Owner
Trajiksmax's Avatar
Send a message via Yahoo to Trajiksmax
Very gifted I admire anyone who can understand vehicle wiring. I never can and never will. Right on!!
__________________
-Trajiks9
-Trajiksmax
Trajiksmax is offline   Reply With Quote
Old 11-05-2009, 04:01 PM   #53
Jedi Knight Academy
Send a message via AIM to maxprivate
gear display in 2001 cluster to work with 4th gen
It's been a while, Eng92 Im doing the 2001 cluster swap in my 4th gen. Do you know if I would need the PSN switch from the 2001 max to get the gear diplay in the cluster to light and display the gear im in? Or can I just tap into the Inhibitor switch in my 97 to signal the 2001 cluster to light each gear position. Im AUTO btw.
maxprivate is offline   Reply With Quote
Old 11-05-2009, 04:13 PM   #54
i want a new gauge cluster!!! 00 or 01 would work too
__________________
DIAMONDS98SE is offline   Reply With Quote
Old 11-05-2009, 07:48 PM   #55
I'm a Faulker
Conrad283's Avatar
Send a message via AIM to Conrad283
Quote:
Quote:
This thread is 4 years old
__________________
Conrad283 is offline   Reply With Quote
Old 11-05-2009, 08:33 PM   #56
Jedi Knight Academy
Quote:
yeah Im aware of that. how does this help me?
Old 11-16-2009, 11:49 AM   #57
Quote:
Originally Posted by eng92 View Post
The only problem really is the coolant temp gauge. On the 02/03, the ecu supplies a voltage signal to the cluster for water temp. On the 4th gen, there is a separate water temp sensor that is used by the gauge cluster and the auto air conditioning. The ecu uses its own sensor. Therefore the circuitry is not built in to the 02/03 cluster to convert the sensor resistance into a voltage that the gauge can display.
I am thinking about doing this cluster swap into a 4th gen and was wondering, everything should be functional and is a matter of splicing wires except for the water temp and trip display on the 4th gen ECU?
I know the gas mileage meter probably won't happen, but I was thinking, we know the 5.5gen cluster's temp gauge won't work off the independent auto a/c / temp gauge sensor in the 4th and 5th gen. But what the one that the ECU uses? What if a wire was tapped into that signal that goes to the 4th gen ECU and then ran to the 5.5gen cluster? Would that work or is the ECU's temp sensor completely different as well?
__________________
|1997 Maxima SE|5sp|Pebble Beige|Sec.&Conv. package|SE Leather package|Cold weather package|
|00vi|VAFC2|Warpspeed B pipe|fenderwell CAI|KYB AGX/Tein S.Techs|I30 headrests & autodim|Hardwired Passport 8500|6000K 35w HIDs|
modenaf1 is offline   Reply With Quote
Old 11-16-2009, 05:24 PM   #58
Send a message via MSN to Blackwind
not gonna work. you can use the 2000/2001 maxima or the I30 which im using. the A33 B's set up is too dependent on the ECU in order for this mod to be worth the time. A33 A's are closer to the A32 .
__________________
"9 out of 10 Housewives approve of this product."
Blackwind is offline   Reply With Quote
Old 11-17-2009, 03:32 AM   #59
Bummer, I love the silvery color of the 5.5 cluster. Speaking of which, I was just looking for clusters on ebay and I came across this: http://cgi.ebay.com/ebaymotors/00-01...#ht_2413wt_903
It just says 00/01, but I noticed it is a 5th gen cluster but silvery like the 5.5. Is this one an AE cluster? Does anyone know if Anniversary Editions got different clusters than the rest of the 5th gens?
__________________
Old 11-17-2009, 05:11 AM   #60
Looks just like mine, minus the gear selector.
__________________
Current: AE KT3 MT | 5.5 HIDs | Fog-Light Rewire
Old: 96 KH3 MT | Fog-Light Rewire (sold 11/9/09)
AEMAXIMA01 is offline   Reply With Quote
Old 11-17-2009, 06:25 PM   #61
Jedi Knight Academy
I have the exact same cluster from a 2001 and mine is the AE. It has the silver gauges just like in the pic. Extremely cheap price but if you are looking on doing the cluster swap you will need the plug in the back of the cluster, this one doesnt show them in the pic. Make sure you get one that includes the plugs with enough wire to tap into.
Old 11-18-2009, 03:13 AM   #62
Awesome, I think I will keep my eye out for a 5th gen at the junkyard and cut the harnesses for the cluster out and then try to get the AE cluster.
Does anyone know if the 5th gen cluster requires that you make a mold for the bottom mounting points like the 5.5gen cluster?
__________________
Old 11-18-2009, 04:46 AM   #63
Jedi Knight Academy
I believe you will have to break off the bottom mounting tabs from your 4th gen cluster and epoxy them to the 5th gen cluster. take a look, theres a thread about installing a 5thgen cluster in a 4th gen by Tavarish. He didn't use the top mounting tab.
Old 11-18-2009, 09:33 PM   #64
Jedi Knight Academy
2001 AE cluster swap in 97 max
Does anyone know if there is a way to add an ambient sensor to the 2001 cluster that will display temperature in the digital display? Im working on the 4th gen to 5th gen cluster swap. Also has anyone tried enlarging the the opening of the lighting bulb holders to 194. I know MetalMaxima has soldered on the 194 bulbs but Im looking on just enlargening the hole and use the 194 bulb and holder so its just plug and play.
Old 11-19-2009, 05:23 PM   #65
I've a 97 with manual odometer. Can I replace it with a gauge that has a digital odometer without modifying any wiring? I saw this blacked-out gauge from a much later model JDM A32 Cefiro.
jason_10 is offline   Reply With Quote
Old 11-19-2009, 06:54 PM   #66
Jedi Knight Academy
Quote:
I dont think anyone with Analog 4th gen cluster has done this yet. Im in the process of doing mine. Im using a 2001 AE cluster so I guess I will be the first if I get it to work. I wish people that have done this would help out. I guess its just a matter of comparing the diagrams for the digital odometer and sending the correct wires on the 2001 cluster to power and ground. However you will loose the ability to use cruise control since the 4th and 5th gen ASCD operate differently. Can anyone contest this?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
