How often should I change my spark plug wires?
Old 05-13-2001, 06:06 AM
Hercules's Avatar
I bought my 96 Maxima a few months back with 80K miles on it. I made a tune up which replaced the filters and the spark plugs (NGK). I haven't changed the spark plug wires though. Is there a way that I can check if the wires are still good? Or should I change it according to the mileage?
What brand should I go for if I need to replace it? How much do they cost? Any input is appreciated. Thanks.
Hercules is offline
Old 05-13-2001, 06:17 AM
ny96max's Avatar
We dont have spark plug wires. The motor uses ignition-coils that clip to a wiring harness from the ignition system. You will know if the wiring is bad cause the motor will be missfiring,have lots of hesitation and idle like *hit. All you have to change out is the plugs to NGK from Nissan.
If you have this problem its probably due to a burnt-out coil. I had this problem when doin my 60k tune-up. Took me about a week and $200 in new sensors to figure out it was the coil, $70.
Ant
ny96max is offline
Old 05-13-2001, 02:19 PM
max808's Avatar
If you need to check if they are still good, chances are they are still good. You'll know by misfirng.
max808 is offline
Old 05-13-2001, 02:28 PM
Sonic's Avatar
Like ny96maxse said, we DO NOT have spark plug wires.
Sonic is offline
Old 05-13-2001, 02:39 PM
Hercules's Avatar
Silly me, haha. I was misleaded by those guys at the repair shop. Thanks to you guys for clarifying!
Hercules is offline
Old 05-13-2001, 02:42 PM
Sonic's Avatar
And while we are at it, we also don't have a timing belt, we have a chain.
Sonic is offline
Old 05-13-2001, 06:27 PM
i SeE what you did therE
redmaxpa007's Avatar
i think the guys at the shop were trying to get some more monrey out of you...
redmaxpa007 is offline
Old 05-13-2001, 09:25 PM
D-DOT's Avatar
I think he should take it back, let them do the work and when their finish tell them you want to keep your old wires too then sew the hell out of them
D-DOT is offline
Old 05-14-2001, 08:01 AM
ajaffee
Sew?
Sew the hell out of them? Why? Is it better if they are all attached to each other with thread?
Old 05-14-2001, 08:25 AM
Re: Sew?
i was thinking the same thing.... j/k
Old 05-14-2001, 09:07 AM
NisMax95's Avatar
Re: Sew?
Yeah, of course it is.. Then they can't run when you call their bluff! Sew 'em up and make 'em pay!!!
NisMax95 is offline
Old 05-14-2001, 10:21 AM
Sonic's Avatar
Sew them up and then whip them with the timing belt!!
Sonic is offline
Old 05-14-2001, 11:41 AM
medicsonic......i would love to see that!!
The Frye
09-02-2021 11:03 AM
mvm062
11-30-2020 09:00 AM
cruce91
09-20-2015 10:23 AM
sdotcarter
09-02-2015 09:53 PM
maximusrising
09-02-2015 09:55 AM
Quick Reply: How often should I change my spark plug wires?
